Triangle to Sine
Page 1 of 1 [2 Posts]
G2 patch files: 626
PostPosted: Fri Jun 09, 2006 3:58 am    Post subject: Triangle to Sine Reply with quote  Mark this post and the followings unread
This block converts a triangle to a pretty good sine wave using the following
if tri >= 0
sine = tri * (2 - tri)
else
sine = tri * (2 + tri)
Tri2Sin.pch2
convert triangle to sine
 Filename:  Tri2Sin.pch2
 Filesize:  1.26 KB
 Downloaded:  1409 Time(s)
selvmarcus
G2 patch files: 39
PostPosted: Sun Jun 11, 2006 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
I found out the ShpStatic module in 2nd mode-position carries a builtin version of this.
Greetings,
Marcus
Edit: Actually, it´s even better for converting higher frequencies. More terms in the expansion series?
tri2sin_builtin.pch2
ShpStatic module as triangle2sine converter (2nd position)
 Filename:  tri2sin_builtin.pch2
 Filesize:  1.33 KB
 Downloaded:  986 Time(s)
Something with this universe is somehow perfectly sound and in order.
