phasor not a ramp?
Page 1 of 1 [13 Posts]
cebec
G2 patch files: 31
PostPosted: Thu Aug 31, 2006 6:13 pm    Post subject: phasor not a ramp? Reply with quote  Mark this post and the followings unread
miniAudicle 0.1.3.5 (alpha)
the phasor outputs a sine and i'm told class 'phasor' has no member 'width'
anyone else?
ge
PostPosted: Thu Aug 31, 2006 6:52 pm    Post subject: Re: phasor not a ramp? Reply with quote  Mark this post and the followings unread
anyone else?
Doh. That's a bug. 'phasor' is indeed putting out a sine! Shocked
This affects everything running 1.2.0.6, including miniAudicle, audicle, command line chuck, tapestrea.
The fix is in CVS, and will be in 1.2.0.7.
The 'width' was not meant to be there as the documentation claims, though we can add it as such? or we can just remove that part in the documentation.
Thanks for reporting this. 1.2.0.7 is in the works, among other things, we are going to get a few more native UGen's as suggested in discussions on the mailing list, many out-of-the box filters (lpf, hpf, bpf, brf, etc.).
cebec
G2 patch files: 31
PostPosted: Thu Aug 31, 2006 7:03 pm    Post subject: Re: phasor not a ramp? Reply with quote  Mark this post and the followings unread
anyone else?
my pleasure! and can't wait. thumright
kijjaz
PostPosted: Fri Sep 01, 2006 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
oh.. it is? i haven't tried phasor yet.. lol.
as an end-user, it'd be cool to have presets in lpf hpf.. also..
(lol ..)
Kassen
PostPosted: Fri Sep 01, 2006 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah! Easy filters! ChucKian acid explosion with crash cymbals!
Will this one also bring my much coveted multiple outputs under Win?
Note to fresh ChucKers; multiple (as in more then two) outputs under Windows seems to have a issue... That is to say; as far as we know it doesn't work anywhere. It'd be cool if Win-based ChucKers that are able to get more then two outputs (you can see this using "chuck --probe") would report this because our Princetonian friends don't have big soundcards on their windows test computers.
Kassen
kijjaz
PostPosted: Fri Sep 01, 2006 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
oh yeah.. i've got this problem also.
my windows laptop's connecting to an emagic a26 usb audio interface
it has 6 analog outputs.. but chuck plays well.
but my another desktop computer with RME Hammerfall Multiface
(8 analog in/out, 8 adat in/out, headphone out, spdif in/out)
chuck fails to play anything there.
ge
PostPosted: Fri Sep 01, 2006 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
We so want to get to the bottom of this. Unfortunately, as you noted, we don't have multi-channel sound cards for our windows machines. We have like a ton of Edirols FA-101 (10x10) but need to install a firewire card on the computer first! The best we can do now is to debug remotely, which often works.
I second this!
ge
PostPosted: Fri Sep 01, 2006 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, ChucK actually works with this card on 6 channels out?
Doh. Even stereo? Can you provide a log output of this? (run with -v5) Perhaps you already tried this, but sometimes playing with the buffersize helps.
Thanks for the info! We shall get to the bottom of this, someday. Soon.
Kassen
PostPosted: Sat Sep 02, 2006 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I can chime in here; I used to have that emagic card before upgrading to my current EMU. The emagic only gives it's full 6 outputs in Asio mode (and it can only be in one mode at a time) and hence I'm quite sure there won't be 6 outputs coming from it in ChucK at the moment.
I liked it at the time though; for the money and that time it was a nice card.
Kassen
kijjaz
PostPosted: Sun Sep 03, 2006 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm chuck probing on my windows (with RME Hammerfall Multiface installed)
chuck found 16 device(s) ...
[chuck]: ------( chuck -- dac1 )---------------
[chuck]: device name = "HDSP Analog Out (1+2)(1) (emulated)"
[chuck]: probe [success] ...
[chuck]: # output channels = 2
[chuck]: # input channels = 0
[chuck]: # duplex Channels = 0
[chuck]: default device = YES
[chuck]: natively supported data formats:
[chuck]: 16-bit int
[chuck]: supported sample rates:
[chuck]: 100 Hz
[chuck]: 100000 Hz
and so on.. all 8 analog out, 8 ADAT out, SPDIF out are like this..
(supported sr = 100, 100000hz)
but it works well with PC on-board soundcard:
------( chuck -- dac15 )---------------
device name = "SoundMAX Digital Audio"
probe [success] ...
# input channels = 2
# duplex Channels = 2
default device = NO
8-bit int
16-bit int
11025 Hz
22050 Hz
44100 Hz
but the hammerfall DSP settings panel shows that the interface's working at 44100
trying with emagic a26 (plug-in to usb)
------( chuck -- dac2 )---------------
device name = "Emagic A26 "
probe [success] ...
default device = NO
8-bit int
16-bit int
22050 Hz
44100 Hz
------( chuck -- dac5 )---------------
probe [success] ...
default device = NO
8-bit int
16-bit int
22050 Hz
44100 Hz
running powerup2 with many channels still makes emagic a26 plays stereo..
yeah Kassen is right.
ge
PostPosted: Mon Sep 04, 2006 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
kijjaz wrote:
[color=#114477]i'm chuck probing on my windows (with RME Hammerfall Multiface installed)
[chuck]: 16-bit int
[chuck]: 100 Hz
[chuck]: 100000 Hz[/size]
Indeed the sample rate is very fishy. We've had reports of this before, especially on certain multi-channel cards. I will get in touch with folks about this. We also gotta get us some cards on windows!
ge
PostPosted: Mon Sep 04, 2006 8:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the cases where the soundcard doesn't work, or doesn't work for the specified number of channels, what is the log output? Can you run chuck with the desired flags plus --log5 and post the output of the logger? Thanks!
kijjaz
PostPosted: Tue Sep 05, 2006 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
with the RME Hammerfall Multiface..
i run chuck but didn't force it to play in any samplerate
(so it's 44100)
the output with errors are like this:
[chuck]:(5:INFORM): setting thread priority to: 5...
[chuck]:(2:SYSTEM): RtApiDs: callback thread error...
[chuck]:(5:INFORM): | (RtApiDs: Unable to lock buffer during playback (Primary Sound Driver): Invalid parameter..)
[chuck]:(5:INFORM): | closing overridden - continuing...
and so on.
- thanks and cheers - kijjaz
