Inventor
Audio files: 267
Posted: Sat May 30, 2009 6:43 pm Post subject:
Close Encounters Subject description: five notes and a pause |
Here are the guitar notes for the Close Encounters UFO song:
| Code: |
1 - A 440.00 string 1 5th fret
2 - B 493.88 string 1 7th fret
3 - G 392.00 string 1 3rd fret
4 - G 196.00 string 3 open
5 - D 293.66 string 2 11th fret
Play them and enjoy! (note: (pun intended) i need to repair my guitar before i can make an audio sample, sigh).
DrJustice
Joined: Sep 13, 2004 Posts: 2114 Location: Morokulien
Posted: Sun May 31, 2009 5:33 pm Post subject:
Re: Close Encounters Subject description: five notes and a pause |
Thanks for reminding me of the notes - I just had a little Close Encounter jam
Here's a tip for making it easier to play. Instead of the big moves and the open string, you can hold your hand in the same position, only moving your fingers, as you would normally play a scale in one position. Use the index finger on fret 5, the ring finger on fret 7 and the pinky on fret 8. Here's a tab:
| Code: |
E|---5--7--------------
B|---------8-----------
G|---------------7-----
D|------------5--------
A|---------------------
E|---------------------
DJ
Inventor
Audio files: 267
Posted: Sun May 31, 2009 6:17 pm Post subject:
Coolness DJ and thanks! I can't wait ti fix my geetar but first i have to unpack in my new apt.
Inventor
Audio files: 267
Posted: Sat Jun 13, 2009 9:21 pm Post subject:
Now that the guitar is all working, invention and everything, I was doing my own UFO jam and enjoying it immensely. This is a good little riff to know, and I'm planning to play it on my show next week!
Inventor
Audio files: 267
Posted: Tue Jun 16, 2009 11:50 am Post subject:
| Code: | Thanks to my friends Rob and Are (and me also) for figuring out the following five notes and their fingering, the UFO theme from the movie "Close Encounters".
First Position: The Greeting
Second Octave
3 - G 392.00 string 2 8th fret
4 - G 196.00 string 4 5th fret
5 - D 293.67 string 3 7th fret
Tab:
1 ---5---7---------------
2 -----------8-----------
3 -------------------7---
4 ---------------5-------
5 -----------------------
6 -----------------------
Put your index finger on fret 5, your ring finger on fret 7, and your pinkie finger on fret 8. That way you can play it like a scale, moving across the neck but not up and down. There are also other positions on the neck where you can get the same notes but in a different octave. For example:
Second Position: The Mother Ship
First Octave
1 - A 220.00 string 3 2nd fret
2 - B 246.94 string 3 4th fret
3 - G 196.00 string 4 5th fret
4 - G 98.00 string 6 3rd fret
5 - D 146.83 string 5 5th fret
Tab:
1 -----------------------
2 -----------------------
3 ---2---4---------------
4 -----------5-----------
5 -------------------5---
6 ---------------3-------
That one is the lowest octave version on a six string guitar with standard tuning. It can also be played with one hand position, just put the index finger on the 2nd fret and so on. Here is another one:
Third Position: Earth's Response
Second Octave (same notes as First Position)
1 - A 440.00 string 2 10th fret
2 - B 493.88 string 2 12th fret
3 - G 392.00 string 3 12th fret
4 - G 196.00 string 5 10th fret
5 - D 293.67 string 4 12th fret
Tab:
2 ---10--12--------------
3 -----------12----------
4 -------------------12--
5 ---------------10------
This third version can be fingered with just the index finger on fret 10 and the ring finger on fret 12. Then finally the first two of the above three versions can be played 12 frets higher as follows:
Fourth Position: The Scout Ship
Third Octave
1 - A 880.00 string 1 17th fret
2 - B 987.77 string 1 19th fret
3 - G 783.99 string 2 20th fret
4 - G 392.00 string 4 17th fret
5 - D 587.33 string 3 19th fret
Tab:
1 ---17--19--------------
2 -----------20----------
3 -------------------19--
4 ---------------17------
and
Fifth Position: Earth's Jam
1 - A 440.00 string 3 14th fret
2 - B 493.88 string 3 16th fret
3 - G 392.00 string 4 17th fret
4 - G 196.00 string 6 15th fret
5 - D 293.67 string 5 17th fret
Tab:
3 ---14--16--------------
4 -----------17----------
5 -------------------17--
6 ---------------15------
Try them all, then mix them up at different tempos and have yourself a UFO jam session!
Les
