Banana Jacks
Page 1 of 1 [2 Posts]
Ali M
PostPosted: Tue Jan 26, 2010 4:43 am    Post subject: Banana Jacks Reply with quote  Mark this post and the followings unread
I am thinking about trying to make my Yusynth smaller by using 4mm banana jacks.
Do I just connect the signal outputs to them, and leave the ground unconnected?
Will this effect the quality of the signal?
Thanks
Ali
yusynth
PostPosted: Tue Jan 26, 2010 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
If the modules are connected to the common ground (0V) of a power supply, just connect the inputs/outputs directly to your banana sockets;
If the modules are not sharing a common ground (0V) then you must add a banana socket for the ground of the module.
Because the levels in a modular is much higher than the usual line levels, the y are more immune to noise.
Yves
