5U Front Panel for A Quad Voltage Quantizer
kindredlost
PostPosted: Thu Jun 30, 2011 1:27 pm    Post subject: 5U Front Panel for A Quad Voltage Quantizer Reply with quote  Mark this post and the followings unread
Here is a tentative layout using Front Panel Express for a 2 space wide 5U (MOTM) format panel.
This layout uses a single DPDT switch in substitute for the two SPDT's. It also has drilled panel holes to mount the PCB's parallel to the front panel. The first PCB is stacked 38mm back and each PCB is stacked 13mm behind the next one. Barely enough room to clear the electrolytic capacitors. Total distance of the boards behind the front panel is less than 4 inches including the components on the last board. Pretty compact.
Below are two format to view it in. A PDF for general viewing and an FPD for use in Front Panel Express.
MFOS QUAD QUANT.fpd
 Filename:  MFOS QUAD QUANT.fpd
 Filesize:  1.93 KB
 Downloaded:  122 Time(s)
MFOS QUAD QUANT.pdf
 Filename:  MFOS QUAD QUANT.pdf
 Filesize:  27.85 KB
 Downloaded:  150 Time(s)
