More blue modulation inputs!
Page 1 of 1 [2 Posts]
Do you want these enhancements?
Yes
100%
 100%  [ 11 ]
No
0%
 0%  [ 0 ]
Total Votes : 11
Tim Kleinert
G2 patch files: 236
PostPosted: Sun May 01, 2005 9:45 am    Post subject: More blue modulation inputs! Reply with quote  Mark this post and the followings unread
There are quite some modules where crucial parameters can not be modulated, but only be set via tweaking the corresponding knobs.
(Sure, there's the trick with CC#-assignments and the CtrlSeq module, but this is somewhat impractical in use, as it limits a patch to a specific slot, uses MIDI bandwidth and mem% if you use alot of it -and I do sometimes.)
I do not see any logic in this limitation, and have often run into situations where it caused problems. So this is my wish:
Some modules where blue mod inputs for the parameters are desperately needed:
String oscillator: mod inputs for damping and decay. This is important! Most often you wan't to "empty out" the waveguide once a key is released. As it is, this ain't possible without the aforementioned workaround. (Would make this module way more useful for other phM-applications too!)
EQs: Sweeping EQs with envelopes and LFOs -there's so much hidden fun there!
Reverb: Yes sir! I need this very often and have seen many patches in the "noodle department" who need it too.
...these are just a few that come to mind. Please feel free to add more -and vote "yes" Wink
Audio files: 213
PostPosted: Sun May 01, 2005 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sweeping the EQs would be neat... Smile
