Capacitor in positive feedback of comparator?
Page 1 of 1 [6 Posts]
Feifer
PostPosted: Tue Jun 13, 2017 1:51 pm    Post subject: Capacitor in positive feedback of comparator? Reply with quote  Mark this post and the followings unread
So I can't for the life of me figure out what this cap (C4, upper right corner) is doing. I've never seen a set up like this before and when running a simulation of it, it sets up an oscillation on the comparator. Does anyone know the reason for it? Ray didn't say why he included it.
Audio files: 706
PostPosted: Tue Jun 13, 2017 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those small capacitors in the feedback loop are usually added to suppress high frequency oscillations.
I don't know why it would cause an oscillation when you simulate it.
Audio files: 279
PostPosted: Tue Jun 13, 2017 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the negative feedback path it would add some integration, which would (help to) suppress oscillations.
In the positive feedback path (as used here) it adds some differentiation. This is usually used to speed up output switching, but it has a tendency to make the thing unstable (into an oscillator).
In this case I'd assume the simulation to be less than perfect. So just leave it out for simulation, and do add it in when you'd actually build it (and maybe adjust it after checking on the scope what happens in practice).
Feifer
PostPosted: Tue Jun 13, 2017 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
If it's there to just speed up output switching on the op amp, how about using an actual comparator there instead? Would there still be a need for it if a different device is able to switch 1000 times faster alone?
Audio files: 706
PostPosted: Wed Jun 14, 2017 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, didn't know that. Smile
Audio files: 279
PostPosted: Wed Jun 14, 2017 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure, why not change things, it would probably save the capacitor indeed .. and it's a good way to learn things too :-)
There may be price issues, voltage range issues, input impedance issues ... check datasheets ... no idea why it was done as done with a TL .. but such can (and probably does) work fine.
And as said, the simulation may be less than perfect, so experiment best with the real thing.
