Random Gates Circuit using 4093 & 4013
Page 1 of 1 [7 Posts]
gasboss775
PostPosted: Sun Apr 23, 2017 1:20 pm    Post subject: Random Gates Circuit using 4093 & 4013 Reply with quote  Mark this post and the followings unread
2 fast oscillators of different frequencies are combined by in one case an OR gate and in another an XOR gate. Snapshots of this complex waveform are captured by the 4013 D type flip flop at a rate determined by the tempo clock. This could also be from an external clock.
I will add the other 1/2 of the 4013 later, the one shown deals with the output of the XOR gate, the other will deal with the output of the OR gate.
 Filesize:  158.19 KB
 Viewed:  519 Time(s)
Audio files: 706
PostPosted: Sun Apr 23, 2017 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am intrigued by your XOR gate, haven't tried to figure it out yet though. Are those actually zenerdiodes
and if so do they have the same voltage ? Sampling high frequency oscillators does indeed work well for
'random' especially when you throw a couple in the mix. A shift register with a high frequency oscilator
connected to the data input also works nice and you can attach a resistor network to it to create a semi-
analog signal.
Audio files: 279
PostPosted: Mon Apr 24, 2017 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
The XOR was explained here : http://electro-music.com/forum/topic-68544.html - interesting thing :-)
gasboss775
PostPosted: Mon Apr 24, 2017 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
analog signal.
The Diodes are Schottky diodes which have a lower forward voltage than regulars. Probably not strictly necessary here & I expect 1n4148's would work as well.
I tried your idea with the shift register in the past using a 4094 8 bit SR. I found there was a problem with the outputs being unsteady whilst the clock remained in the high state. That is the data was being routed through to the output whilst the clock was high rather than being sampled at the rising edge of the clock pulse. Maybe the problem is just with the 4094, I haven't tried other SR's yet.
Audio files: 706
PostPosted: Mon Apr 24, 2017 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
oh shottky diodes, that makes sense, I mixed up my diode symbols Embarassed Yeah, regular diodes should do fine
but it's always good to keep the voltage drop to a minimum.
I am somewhat surprised it doesn't work with a CD4094 it even has an extra latch, I guess I should do some experiments
with it. It seems to work fine with a 4015, I like connecting one of those flickering teacandle LEDs to the data input. Wink
gasboss775
PostPosted: Mon Apr 24, 2017 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wonder if I had a bad batch of 4094's as I'm sure that I tried more than one. I do have a few 4015's so I'll give this a go.
Where do you get the flickering teacandle LED's, I haven't seen those before?
Audio files: 706
PostPosted: Mon Apr 24, 2017 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I get those LEDs out of electronic teacandles, I think the last time I bought some they came in a pack of 4 for €1,-
You can also get the LEDs separately on ebay in a variety of colors.
