Question about Roland td-3 drumset
Page 1 of 1 [7 Posts]
guitar_player
PostPosted: Fri Mar 10, 2006 4:31 am    Post subject: Question about Roland td-3 drumset Reply with quote  Mark this post and the followings unread
Hi! Three days ago i've bought a new drumset Roland td-3 kv. It costed 1150 euros. It's great.
I'm really happy. I can play at home! I have a question: how to connect additional sounds
to my td-3 module. One forum (http://drumset.bravehost.com) says, that it's possible, but i don't
how to do it.
PostPosted: Fri Mar 10, 2006 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
That dumset.bravehost thingie isn´t a forum. What I am seeing is this:
I am pretty sure you are seeing the same.
Flickr
Audio files: 204
PostPosted: Sun Mar 19, 2006 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup, the same thing...
paul e.
PostPosted: Sun Mar 19, 2006 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
you will need a Roland Trigger-->MIDI convertor....
Spiral Recordings
opg
PostPosted: Mon Mar 20, 2006 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Not possible with any drum brain. This is one of my biggest pet peeves (why didn't I mention it in the Pet Peeve thread?). You'll need a trigger to MIDI convertor like paul said, and then connect it to a sampler or your computer.
Or you could try to build a drum brain / sampler and then brag about it for months but never actually quite finish it like I did.....
Seriously, everything is finished except for the code for the GUI and a USB input. So far, you have to load sounds via a serial port.
http://27b-6.lathan.org
mi_dach
PostPosted: Mon Mar 27, 2006 4:14 am    Post subject: trigger-midi converter Reply with quote  Mark this post and the followings unread
If using a trigger->midi converter, and samples on a computer, how much latency is acceptable in the system? I tolerate 10ms on my guitar, but Im wondering if that much would totally destroy the feel of drumming?
opg
PostPosted: Mon Mar 27, 2006 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a very low latency on my computer, and I have a Dell with a Pentium 4 (definitely under 1GHz), 512 MB of RAM, and a M-Audio Audiophile 2496 sound card. It works perfectly, and I'm not even using real electronic drums - just some that I built with triggers, mousepads, and PVC.
