cant find exact values
Page 1 of 1 [9 Posts]
neo644
PostPosted: Wed May 03, 2006 12:22 pm    Post subject: cant find exact values Reply with quote  Mark this post and the followings unread
hey, i'm having trouble finding the exact values for some caps and resistors.
will my sound lab work if i use the other values instead (to the left are the original values, to the right the ones i could find)
ceramic capacitors:
1 uF --> polyester cap 1uf
2 uF --> polyester cap 2uf
tantalum capacitor:
2 uF --> 2.2 uF
resistors:
20k --> 22k
2M --> 2.2M
3M --> 3.3M
475 ohm --> 470 ohm (for correct 1v/oct mod)
500 ohm --> 560 ohm
620 ohm --> 680 ohm
thanks!
Pehr
PostPosted: Wed May 03, 2006 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've used 2 uF tantalum and it wirks fine. I found 1 uF ceramic cap but for the 2uF I used two 1uF in parallell.
If you don't find 0,25W resistors with good values try the 0,6W resistors. There seem to be more values of those... Cool
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
otcx
PostPosted: Fri May 05, 2006 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
From 0.6w resistors u can find right values easily. These works fine,
but use much more current. Also u can substitute caps as long value stay within 10%. I have almost all resistors 0.6w 1% and Soundlab works fine.
PostPosted: Sat May 06, 2006 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Just thought I should point out they don't use more current, they can handle more current before they burn. So over-rated resistors are always fine.
The 475-->470 is fine as it hangs off one side of the trimmer anyway, so the extra 5R can be dialled up later (if needed)
You can find 20K, 510R & 620R in the E24 series (1% metal wound usually follow this series)
Substituting polys for ceramic caps is fine.
And 2u2 is fine for a 2uF tant.
The 2M and the 3M I made by putting 1M*2 standing upright and 1M2+1M8 standing upright. I don't think they are that critical anyway, so 2M2 and 3M3 would probably be fine.
neo644
PostPosted: Sun May 07, 2006 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
hthanks. i also did that for the 1M resistores. i add up 1M * 2 and 1M * 3
for 620k i added up 470k + 150k
and for the 500ohm i'll have to use 100 * 5, thats going to be a bit ugly though
Pehr
PostPosted: Sun May 07, 2006 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
For 500 Ohm you could use two 1 kOhm resistors in parallell, that's 500 Ohm too Cool
1000*1000/(1000+1000)=500
YouTube channel
flickr photostream
neo644
PostPosted: Sun May 07, 2006 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
jejeje yea i didnt remember the parallel resistor calculation
is it?
R1 * R2 * RN
R1 + R2 + RN
Pehr
PostPosted: Sun May 07, 2006 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
YouTube channel
flickr photostream
neo644
PostPosted: Sun May 07, 2006 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
of course it was something like that! jejeje
thanks!
