Heated chip with music from outer space vco
Page 1 of 1 [3 Posts]
zipzap
PostPosted: Sat Jun 03, 2006 2:32 am    Post subject: Heated chip with music from outer space vco Reply with quote  Mark this post and the followings unread
Hi
Has anyone used the heated chip methode with rays vco design?
http://www.musicfromouterspace.com/analogsynth/August2003VCO.html
I don´t get the right tempco (at a price i want to afford) so i thought i could use the method doepfer uses in their A110 with the ca3046.
http://www.doepfer.de/a110_tec.htm
Should work more or less and i think if the chip gets a nice isolation jacket it shouldn´t coast too much current (hope so).
Only thing i´m concerned about is trimming the vco, because the trimmers in rays and the doepfer vco show some little differences. Shouldn´t matter, right?
toppobrillo
PostPosted: Sat Jun 03, 2006 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
heat it!
zipzap
PostPosted: Sun Jun 04, 2006 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
i take that for a yes.
Tell you how it worked when i get to it. Another thing is the fet which i can´t find anywhere around here. Supposed to be a mpf102 or 2n5457. Do you think a bf245b will work?
