issues with the AR
Page 1 of 1 [24 Posts]
PostPosted: Wed Jun 28, 2006 5:02 am    Post subject:  issues with the AR
Subject description: AR timing cap questions
Hi all,
I have some problem with the AR:
The attack and the release times are VERY long, independent from the times set by the pots.
    I suggest a faulty cap C3 and i want to replace it. Should it be a tantal and why? Could i use a electrolytic instead (and why not)?
At pin5 ic2-b i got the voltage rising from approx. +0.1V, which is okay, i think. At pin7 ic2-b the voltage rises from -9V!?
    Could it be, that the trigger pulse from C1 is missing? (I only have a softwarescope which is a mess to handle with)
Any comments appreciated
Matthias
PostPosted: Wed Jun 28, 2006 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd check that the pots are connected properly first. It's easy to get something like that mixed up and use one end as a wiper (which would give you those exact symptoms)
PostPosted: Wed Jun 28, 2006 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your suggestions.
Well, as to say for the SL the Wipers and the CWs of both pots are connected correctly to the timing Cap C3 and pin5 of IC2. Meanwhile i replaced the tantalum by a electrolytic cap. No difference.
Audio files: 213
PostPosted: Wed Jun 28, 2006 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
For ARs and such, virtually any type of capacitor should do, but watch the polarity, of course. Electrolytics are used where you need a lot of capacitance in a little space, like power supply caps, but they aren't all that stable - so you might expect there value to change more rapidly than something like a ceramic or mylar type.
Random story: I built a 5V power supply one time and wired up the electrolytic cap backwards. It worked fine for about two years, then one day it blew up. If I would have had the misfortune to have been working with my face close to it at the time, I might not be here today. Fortunately nobody was hurt, but I was completely freaked out. It was a big explosion - could have been really bad in the wrong circumstances.
PostPosted: Wed Jun 28, 2006 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, i checked the polarity of the timing cap. I then checked the trigger pulse at C1/R4 and as far as i could tell from the softwarescope its really there. I checked the pot wiring again and found it is as it should be. I checked the pot themselves (1M) and they are working.
Seems there is no way for me to localize the malfunction so i will check versa netlist...
PostPosted: Thu Jun 29, 2006 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
We can take another approach and based on the fact you gave that both the attack AND release times are longer than expected, check any circuit that is common to both functions.
First, check the value of R6, 500 ohm resistor. Also, check its wiring. This is a common charge and discharge circuit path. If this resistor is >> than 500 ohms and >> R10/11, then you would get the very symptoms you are observing.
Does the circuit behave in both triggered AND gated modes?
If so, then go to the bare minimum of circuitry to operate and set the circuit in GATE mode, NO REPEAT, and use the manual pushbutton. Make sure pin 2 of IC1 is switching to 9 volts when pushed and 0V released.
I will stop for now until you check these items ...
Good luck ...
PostPosted: Thu Jun 29, 2006 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup, thats correct.
Bill
PostPosted: Thu Jun 29, 2006 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi bill,
thank you very much for these hints. they help me understand the circuit and locate the problem.
unfortunately i am rushed up to my ears in stuff to deal with these days, but i hope to check your sugstions tomorrow.
i should add that the pots seem to have no influence on the attack and release times anyhow - strange.
again thank you very much for taking care
PostPosted: Thu Jun 29, 2006 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi bill,
Sure, I understand. We all get busy. Well, I am off for a few days from work so lets see what we can do to get you up and running. Try my suggestions and I will note that the pots have literally no effect. Hmmm, OK then.
Bill
PostPosted: Fri Jun 30, 2006 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
hi bill,
i checked the value of R6 and i suddenly noticed that the D10 diode behind the attack pot was reversed.
i must overlooked that before, i guess, diodes don't change their direction by themselves naturally;-)
the diode is panelmounted and hidden by a cable tangle of panel to board wiring - nevertheless awkward. didn't wanted to waste your time.
thank you very much again
Audio files: 213
PostPosted: Fri Jun 30, 2006 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, the old backwards diode problem. Very Happy
Anyway, glad you found the problem. The one trait of a technical wizard - they never give up.
party time!
PostPosted: Fri Jun 30, 2006 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations,
there's only one thing more rewarding than a circuit that works perfectly first time. That's finding out why it didn't! Very Happy
There's no better way of learning how to troubleshoot something than to do some troubleshooting! Wink
Audio files: 213
PostPosted: Fri Jun 30, 2006 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Before I studied engineering at school, a friend, George Gibson, thought me electronics. He said the most important lession is, "Never expect it to work when you first turn it on." If you just keep that in mind you'll go far. Wink
PostPosted: Fri Jun 30, 2006 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very good advice Mosc.
Complex circuits really do demand a certain level of respect.
It makes sense that the chances something will behave exactly as expected decrease exponentially with component count.
Therefore, "If it works first time, you're not trying hard enough." Cool
Maybe we could write a book, 'Zen and the art of electron flow' Laughing
Audio files: 213
PostPosted: Fri Jun 30, 2006 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
That rule has served me well in programming too. A corollary:
If it works the first time, you haven't found the problem yet.
PostPosted: Fri Jun 30, 2006 10:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, great! Good job. No waste of time at all, this is what we're all about, helping each other. Let us know how the synthesizer comes out. Very Happy
Bill
PostPosted: Fri Jun 30, 2006 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
A BIG ring of truth there
PostPosted: Sat Jul 01, 2006 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Bill
you can see it here:
http://electro-music.com/forum/topic-11872.html
it will have an incorporated power supply and midi2cv converter (EFM 3505). the power supply pcb is etched, populated and tested. the midi2cv is populated and has to be tested. i will implement it next week.
there is still an issue with vco2. it is tuned several octaves higher than vco1. first i thought it could be some failure in the cv circuit (i implemented the 1V/oct mod) but the voltages at the pins of IC5 and IC6 are the same. i will check all values and connections next week...
PostPosted: Sat Jul 01, 2006 9:32 am    Post subject:   Reply with quote  Mark this post and the followings unread
Wow, thats nice! Your front panel came out great! The close-up shot photo is impressive.
I am sure the VCO issue will be resolved soon. Most likely a wrong component value somewhere.
Bill
PostPosted: Sat Jul 01, 2006 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Something interesting I noticed the other day.
Even though I'm pretty well organised, component wise, I keep finding 2K resistors in my 1K slot and vice-versa. The difference between the brown and red which they use on the 1% metal film resistors can sometimes be nothing at all. (sometimes the red looks brown and the brown looks red! Confused ) And, no, I'm not colour blind. Wink
These days I check anything borderline with a meter just in case.
PostPosted: Sun Jul 02, 2006 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
that's what i'm gonna do next week, though i used only resistors directly from a strap... but who knows? anything happens.
Pehr
PostPosted: Sun Jul 02, 2006 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Both my Sound Labs worked perfectly the first time I used them Rolling Eyes
I guess I'm lucky... Razz
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Audio files: 213
PostPosted: Sun Jul 02, 2006 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
It's always better to be lucky than good. Laughing
PostPosted: Sun Jul 02, 2006 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle "K" says:
Yes, and It gets worse when working with surface mount resistors (or capacitors) since they have no markings on them at all. I use special made tweezers that are connected to an ohm (capacitance) meter when placing them on a circuit board to confirm their value [each leg is electrically isolated].
You don't see surface mount components now in synthesizer kits but eventually they will creep in. For DIY projects, I am starting to spin printed circuit boards using surface mount technology for many reasons.
Here is an example of a website that carries SMT training kits:
[there are many venders]
http://www.web-tronics.com/belefrimsiki.html
I don't want to get too far off topic. Very Happy
Bill
