5-channel Attenuverting AC/DC Mixer PROFESSIONAL PCBs
Page 4 of 7 [162 Posts]
PostPosted: Thu Dec 06, 2007 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
so here is the documentation:
draft v1
drapdap
PostPosted: Fri Dec 07, 2007 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
this is really nice, just read the pdf. i guess i`m late to ask for two boards. am i?
robert
PostPosted: Fri Dec 07, 2007 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
no, you don't (check PMs).
PostPosted: Fri Dec 07, 2007 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
upDATE: PCBs are scheduled to arrive on 13 DEC 07 due to holiday (thanksgiving) when i placed the order.
PostPosted: Sun Dec 09, 2007 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
just tried a capture tool on my PC oscilloscope. these little vids show waht attenuvertion does on a cntered ramp/saw and how it affects a ADSR (without the offset that could be added using a 2nd input for that function):
ramp/saw
ADSR
bubblechamber
PostPosted: Sun Dec 09, 2007 10:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks great, if you keep this pace up I'm going to have 2 rows of Fonik modules this time next year.
thanks a lot and keep up the great work.
David
PostPosted: Wed Dec 12, 2007 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
boards arrived today. i just started populating one. my stock run out of some parts (blame it on the klee i am currently building), they will hopefully be in mail tomorrow.
Sound
PostPosted: Wed Dec 12, 2007 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oeee oe oe oe oeee oeeee! Very Happy
sonicwarrior
PostPosted: Wed Dec 12, 2007 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
That looks good.
So you are using AutoGround (I only know the german "AutoMasse" from SPrint Layout) now for keeping the pollution of the environment lower? Smile
EdisonRex
Audio files: 172
PostPosted: Wed Dec 12, 2007 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like your typically nice layout. I can wait a while, given the backlog I need to fix. Hopefully your build will work. Smile
Garret: It's so retro.
PostPosted: Wed Dec 12, 2007 11:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
i got some PMs concerning payment recently. i want to let you know that i won't take any money before i tested the PCB to prove it working (will hopefully happen tonight) and i am ready to ship them.
sonicwarrior wrote:
That looks good.
actually no GND pane, just a pane without any connection to the circuit, but yes: less pollution.
mono-poly
PostPosted: Thu Dec 13, 2007 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Great work Matthias!!
BTW i will check the stuff you did for me tonight Smile
PostPosted: Thu Dec 13, 2007 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
so i finally got it working. you won't believe it! what a horrible evening. 1st i put in the IC backwards (holy smoke!) and then 2nd i recognized after all a mistake in the documentation that let me wire the sockets with GND and tip switched!
however, the PCBs are fine. i am not, i will have to go to bed now...
sleeping
PostPosted: Sat Dec 15, 2007 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
check your PMs...
Wink
PostPosted: Sat Dec 15, 2007 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Attention: there is something that i almost forgot to mention, after populating the PCB.
The footprints for the connectors are a little bit to close to each other, thus you might not be able to use connectors, unless they can be lined up in rows (mine cannot).
So one will have to partly (edit) wire it up in a conventional way like CGS or MFOS PCBs.
Hope you're fine with that. (If not, PM me)
Sound
PostPosted: Tue Dec 18, 2007 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I just have received mine. Very Happy
softfin
PostPosted: Tue Dec 18, 2007 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
My boards came today too. You're the fastest, Fonik!! salut
sonicwarrior
PostPosted: Tue Dec 18, 2007 9:05 am    Post subject:   Reply with quote  Mark this post and the followings unread
Got mine, too. Cool
PostPosted: Tue Dec 18, 2007 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm still waiting for the ferry to cross the water Rolling Eyes
ACHTUNG!
PostPosted: Tue Dec 18, 2007 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
tom, don't be envious. sound and softfin paid on dec 14th! they have been very fast, too.
the early bird catches the worm, as we say in teutonia...
TheAncientOne
PostPosted: Tue Dec 18, 2007 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Matthias
Mine arrived today and they look great.
I'm having the same problem as you, it seems - the Klee has eaten all my spare connectors, (and it's still saying 'Feed me!'), I bet it will want a front panel next.....
Best wishes
Mike
PostPosted: Thu Dec 20, 2007 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Confused Mike, you get yours two days before me? I bet these went to the outer Hebrides first before getting here?? Shocked Laughing
Great boards Matthias! Thanks Very Happy
ACHTUNG!
xpmtl
PostPosted: Thu Dec 20, 2007 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
boards arrived today. thanks fonik
http://sdiy.xpmtl.net
PostPosted: Thu Dec 20, 2007 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
And I got mine today! Excellent! Very Happy
Flickr
b-funk
PostPosted: Fri Dec 21, 2007 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
mine arrived today...
thank you matthias.
best wishes,
tobias
