Arduino Hardware Software Synthesizer
Page 1 of 1 [2 Posts]
slabman
PostPosted: Fri Jul 18, 2008 2:25 am    Post subject: Arduino Hardware Software Synthesizer Reply with quote  Mark this post and the followings unread
On Gieske's website - http://gieskes.nl/instruments/?file=hard-soft-synth-1
- Uses Lookup tables
- 7 selectable instruments.
- 3 effects (chopper, ring modulator, legato bit-crusher).
- 8 step potentiometer sequencer.
- etc
'It started out as a experiment to make a DSP with a atmel using the arduino language. But the sound quality was kind of low. so then I changed directions to make it more into a synthesizer. It uses lookup tables, to generate its sound. I never used lookup tables before. So i generated my lookup tables with PHP, and it seems to be working fine.'
Joel
PostPosted: Fri Jul 18, 2008 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Think I've seen that before but nice link - just wish there were some more details or source code available Wink
He does link to some interesting stuff though - http://gieskes.nl/instruments/files/hard-soft-synth-1/links.txt
