 Forum index » Instruments and Equipment » MAX/MSP - Pd
Simplistic cabasa~ Patch
Page 1 of 1 [5 Posts]
telstarmagikistferrari
Audio files: 43
PostPosted: Fri Jan 09, 2009 3:28 pm    Post subject: Simplistic cabasa~ Patch Reply with quote  Mark this post and the followings unread
Here's a little patch I made using cabasa~ .. I'm new at MAXMSP, but I found it usable in a minimalistic way. I can't find the original patch right now, but if anyone wants to see under the hood I'll find it. I think cabasa~ might require an external library (rtc-lib? not sure). Thanks for any comments. Don't ignore the mod wheel kludge. Smile
View user's profile Send private message Visit poster's website Yahoo Messenger
Audio files: 278
PostPosted: Fri Jan 09, 2009 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see no patch, did the upload fail?
Audio files: 43
PostPosted: Mon Jan 12, 2009 10:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
let me try this again..
*edit*
maxed out quota? i'll try again later.
Audio files: 278
PostPosted: Tue Jan 13, 2009 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
telstarmagikistferrari wrote:
maxed out quota?
Indeed, I gave you some more space ... thought it might be a file extension issue.
Audio files: 43
PostPosted: Tue Jan 13, 2009 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Blue Hell.. your work is appreciated around here.
Here's that patch, folks:
Cabasa.pat-build.zip
 Filename:  Cabasa.pat-build.zip
 Filesize:  83.22 KB
 Downloaded:  263 Time(s)
