 Forum index » DIY Hardware and Software » Musical Interfaces
CV keyboard
Page 1 of 1 [3 Posts]
JoeMorris
PostPosted: Wed Aug 12, 2009 7:15 am    Post subject: CV keyboard Reply with quote  Mark this post and the followings unread
As a long term project I'm hoping to put together a custom monophonic analogue keyboard synth using a variety of DIY modules from various designers.
One thing I'm having trouble with is the keyboard itself. I want it to be fully analogue, so no MIDI involved, but I can't seem to find much info about control voltage based keyboard solutions anywhere... I'm probably going to base it on a Fatar keybed, but with regards controller/interface circuitry I'm a little stumped. Ideally I'd like velocity control too... Is this possible? I'm probably a little out my depth here, but that's how I learn quickest....
jean-louise
PostPosted: Mon Aug 17, 2009 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
there is a doepfer kit. they mention fatar keybeds on the website, so that should work
http://www.doepfer.de/A100CGK.htm
, and there's the mfos Single Buss 1V/Octave Keyboard Controller:
http://www.musicfromouterspace.com/analogsynth/SINGLEBUSSKEYBOARD2007/SINGLEBUSSKEYBOARD2007.php
(i think you'd have to use another, simpler keyboard for that)
sizone
Audio files: 48
PostPosted: Mon Nov 23, 2009 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my voltage summing setup. Has a few advantages, it's dirt cheap, mindlessly easy to build and requires a minimum of components. It's also very compact, you get a little more than an octave (15 notes) using just four switches (theoretically it could be doubled, giving you 255 notes with 8 switches). With decent trimmers (I only had some garbage one-turn ones to experiment with) and some tweaking on the summing/inverting opamp stages it should be possible to get fairly accurate 12 tet tuning out of if. I call it The Left Hand of Creation after a line from Doom Patrol.
Also a pic of what it looks like assembled on perfboard minus the opamp.
 Filesize:  115.55 KB
 Viewed:  587 Time(s)
 Filesize:  412.32 KB
 Viewed:  347 Time(s)
