3 Channel mixer
Page 1 of 1 [5 Posts]
Satindas
PostPosted: Sat Jul 09, 2011 4:32 pm    Post subject: 3 Channel mixer
Subject description: unused input?
just looking at the the artwork for the 3 channel mixer and there appears to be provision for an additional input channel. Is there any reason why not to use it ? Would I have to change any of the input resistor values and U1a feedback resistor?
Thanks !
vinnui
PostPosted: Sat Jul 09, 2011 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 1U 3 ch mixer, and the 2U 4 channel mixer uses the same PCB. Check out the 2U version, if you need more inputs, and gain control.
Satindas
PostPosted: Sun Jul 10, 2011 2:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Vinnui ! I seem to be in the habit of missing the obvious at the moment Embarassed
vinnui
PostPosted: Sun Jul 10, 2011 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I've made a PCB, based on Yves's schematics, which includes 8 inputs (with 120K onboard resistors). I'm using this PCB for my modular.
8 input mixer.zip
Yusynth mixer with 8 inputs. (Eagle schematics/board + PDF PCB file)
 Filename:  8 input mixer.zip
 Filesize:  355.95 KB
 Downloaded:  341 Time(s)
Satindas
PostPosted: Sun Jul 10, 2011 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Vinnui that looks good ! Not sure if I need all 8 inputs though. I'm building a basic system for a friend with just 2 VCO's. I think 4 inputs should be fine Wink
