OTA - Operational Transconductance Amplifiers
Page 1 of 1 [6 Posts]
Sethkaine
PostPosted: Mon Sep 28, 2015 3:00 am    Post subject: OTA - Operational Transconductance Amplifiers
Subject description: I want to know everything about OTA
Hi OTA Lovers,
I will talk about OTA - Operational Transconductance Amplifiers.
I have build the VCO-1 from Thomas Henry. Without the 2k thermistor but with 2x 1k in series around the expo converter transistors.
I have breadboarded the Thomas Henry VCF-1 without the PNP expo converter for now. But with one 100k pot to -/+ 12v center tap binded with 22k to each two OTA from LM13700. For now the VFC-1 sound nicely with a touch of resonance as I like.
ref. here:
http://www.birthofasynth.com/Thomas_Henry/Pages/VCO-1.html
http://www.birthofasynth.com/Thomas_Henry/Pages/VCF-1.html
My questions :
1. I want to know if with a different expo (like the one from R. Schmitz) the VCF will sound the same ?
2. Someone has already build the NPN expo converter from René Schmitz ?
ref. here:
http://schmitzbits.de/expo_tutorial/index.html
my youtube channel - https://www.youtube.com/user/SethKaine/videos
my paper mix - https://paper.fiftythree.com/1865071
m.o
PostPosted: Mon Sep 28, 2015 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The (static) sound itself would be the same, what might differ slightly is the response to CV (you might hear a difference when applying an envelope), but in theory: expo is expo...
ref. here:
Yes you'll find if you study other VCOs (sawtooth type) that this is pretty much a standard configuration.
(And if you rearrange the components slightly in the TH design you'll see it's also is similar).
NPN configurations like this will 'sink' current into the collector of the output transistor, while PNP configs such as the one in TH VCO 'sources' (pushes out) current - different directions.
The expo in the TH VCO needs a positive current to control the 3080 (OTA), which in turn emits a positive or negative current at it's output depending on the state of it's +/- inputs - this output current 'size' is what is controlled by the expo (it's the same mA amount wether it's positive or negative).
This current is what makes the op-amp IC3a to charge/discharge the C3 capacitor at a steady rate.
Sethkaine
PostPosted: Sat Oct 03, 2015 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you for your very interesting explication. I will study it closer and make tests.
Audio files: 654
PostPosted: Sun Oct 04, 2015 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Just came across this on my harddrive, maybe it's useful.
UsingOTAs2.pdf
Understanding and using 'OTA' op-amp ICs by Ray Marston
 Filename:  UsingOTAs2.pdf
 Filesize:  608.96 KB
 Downloaded:  215 Time(s)
L´Andratté
PostPosted: Tue Oct 06, 2015 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mucho gracias, Phobos!
bugbrand
PostPosted: Wed Oct 14, 2015 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
For people interested in OTAs, this could be an interesting/useful doc, recently published::
Minimizing distortion in OTAs
http://www.openmusiclabs.com/files/otadist.pdf
http://www.bugbrand.co.uk
