thru zero VCO
Page 1 of 2 [29 Posts]
gabbagabi
PostPosted: Tue May 17, 2016 12:09 pm    Post subject: thru zero VCO
Subject description: 4. (SAW) Version added
I drew up and soldered this,
but Iam not shure if this is "thru zero ish" enough, because not all (or no) of the zero crossings are looking so nice roundish like i saw it elsewhere
i really like to haer your opinions
cheers bb
gabbagabi
 Filesize:  93.38 KB
 Viewed:  706 Time(s)
 Filesize:  59.77 KB
 Viewed:  537 Time(s)
vladosh
Audio files: 33
PostPosted: Fri May 20, 2016 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
those shapes look interesting for such a small parts count , congrats on the build , could you post some recording from the oscillator , thanks for sharing
gabbagabi
PostPosted: Fri May 20, 2016 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
i hope u can hear something interresting out of it Smile
in some i applied a static sinus lfo and sweeped with the cv from -15V to +15V
in some i changed the freq of the sinus lfo and applied a adsr triggered by hand
Dist Sin VCO LFO 20HZ Sin.mp3
 Filename:  Dist Sin VCO LFO 20HZ Sin.mp3
 Filesize:  108.98 KB
 Downloaded:  710 Time(s)
dist sin vco sin lfo adsr.mp3
 Filename:  dist sin vco sin lfo adsr.mp3
 Filesize:  1.55 MB
 Downloaded:  681 Time(s)
saw vco variable sin lfo hand adsr.mp3
 Filename:  saw vco variable sin lfo hand adsr.mp3
 Filesize:  1.76 MB
 Downloaded:  671 Time(s)
SAW VCO sin lfo 111hz plus minus 15V cv sweep.mp3
 Filename:  SAW VCO sin lfo 111hz plus minus 15V cv sweep.mp3
 Filesize:  407.35 KB
 Downloaded:  675 Time(s)
SIN VCO sin lfo 111hz plus minus 15V cv sweep.mp3
 Filename:  SIN VCO sin lfo 111hz plus minus 15V cv sweep.mp3
 Filesize:  525.31 KB
 Downloaded:  691 Time(s)
vladosh
Audio files: 33
PostPosted: Fri May 20, 2016 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
modulations sound rich , thanks for the sound samples , cheers
soundworker
PostPosted: Fri Jun 17, 2016 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
TZ VCO can go to 0 herz, oszillation stops. Only TZ VCO can do.
Modulation TZ produces FM-sounds when modulation is going TZ.
In your soundsamles I can´t hear either.
Its seem you are discharching the integration cap depending of sign of modulation CV, but it is not going through zero. It produces a rich color of waveforms. For real TZ you need a cap in the plus and minus part.
klangbauköln
Electric Druid
PostPosted: Sat Jul 16, 2016 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
klangbauköln
Sorry, but I don't agree. Both the images and the sound samples seem to confirm that's through zero to me. The images clearly show the waveform slowing down towards zero, hitting zero at 0V, and then reversing, as you'd expect.
Similarly, the sound samples sound pretty "FM" to me. Ok, 111Hz isn't a high enough frequency to give you the type of clanging metallic noise you might expect, but it definitely sounds like FM.
It seems like there might be an improvement to be made to try and get the offsets of the two directions identical so that there's no glitch when it crosses over, but given the small number of components, I think it's impressive already.
Tom
Electric Druid Synth and Pedal DIY website
Moosgummi
PostPosted: Tue Aug 30, 2016 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I don´t really get what´s going on here, but the offset differences are only on the saw wave. I guess it´s a result of the resistor change needed to magically create the saw...
Could a capacitor on the output even this out, or is more magic needed?
Well, I should just build this great simple circuit and try it myself, right?
Edit: Another thing I don´t understand is how the pitch pot works. If I put it to ie 8V, shouldn´t it always stay positive with a +/- 5V input?
soundworker
PostPosted: Mon Sep 05, 2016 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Look what I found:
 Filesize:  42.17 KB
 Viewed:  397 Time(s)
gabbagabi
PostPosted: Mon Sep 12, 2016 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
why i got no eMail notification on your posts? Anyway.
I used the Hangover yesterday to going back to this circuit.
First i found a second TZVCO Idea in the folder that ive forgott totally, starting point was the nicolas3141 supersimple saw vco.
Then i played around with offset compensation for the SAW, by using a double switch.
After that i had some fun by simulating the modulation of some points in the circuit.
@soundworker: nice find, and for osamu a, lets say, "easy" design Wink
@moosgummi: you are rigth, i was thinking about that myself to, may the pitch polarity should follow something, but what: the LFO polarity? hm, i guess TCVCOs living of modulations (that are going thru Zero pitchCV ), otherwise they just producing waveform like "normal" vco do. we will see where it goes...
@fyi: the trick with the SAW-Switch is taken from elektor, A. van Ginneken "präziser VCO" (precise VCO), http://sites.prenninger.com/elektronik/elektor/halbleiterheft-inhalt/elektor-1980, it is also in one of there "30x Schaltungen" books
 Filesize:  166 KB
 Viewed:  436 Time(s)
gabbagabi
PostPosted: Sun Aug 13, 2017 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
moin!
While listening to the Specials, which is always a sign of a profound hangover, i had the great idea to update some schemos.
attached u find the new version of my TZVCO.
in and output buffers nor waveshapers are included.
enjoy yourself,
its later then u think
cheers
gabbagabi
 Filesize:  88.43 KB
 Viewed:  415 Time(s)
L´Andratté
PostPosted: Sat Aug 19, 2017 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice in it´s simplicity, this is linear cv I suppose? What is the cv voltage range?
Definitly will give this a try as a replacement for the woolaston saw vco in my battery powered synth-to-go!
gabbagabi
PostPosted: Wed Aug 23, 2017 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for your interrest.
yes it has linear response. The Input voltage range is only limited by the opamp u use. A good one +/-15V otherwise something like +/-12V.
I see tzvcos more as additional vcos, cos the real vco tasks you can serve better with the classical designs.
keep in mind that u need at least an other vco in front of the tzvco to make sense of the thru zero funktion
a minimal setup in my opinion would contain: classic vco, tzvco, 2xadsr, 2xvca
what iam doing so far is:
pitch adsr - vco- [vca-adsr]- tzvco -
[final vca-adsr]
and iam more than happy with it, since this i never was thinking that i need a filter (anymore? Smile)
in the next days i will make some sound samples
cheers, gabbagabi
gabbagabi
PostPosted: Sun Aug 27, 2017 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
ok
first: basic tone, sin-out of common vco feed into tzvco. just to visualize the shape of the wave.
Second: saw-out of common vco with ADSR-Pitch feed into a modulated VCA to tzvco- tcvco tri output. Hand crancked modulation sense pot on tzvco.
Third: Adsr is modulating the pitch of the common vco and the VCA , VCA out to TZVCO In. Then i switched from low(635pfF+2,2nF) to high (635pF). Hand crancked modulation sense pot on tzvco.
Fourth: out of common vco feed into modulated VCA then tzvco, i changed the modulationg waveforms from Sine - tri -saw to rec( i handmodulated the pw a little bit)
For me analog FM is kind of "unstable" even more if u work with more then two oscilators and feedback. So my own rule is if u find a nice sound - press instantly record, u will never find it back.
Second thing is u cant play it "tonaly". Just record that sound and than may pitch it in the DAW.
gl,
hf
 Filesize:  72.38 KB
 Viewed:  314 Time(s)
gabbagabi tzvco basic sinus.mp3
 Filename:  gabbagabi tzvco basic sinus.mp3
 Filesize:  61.35 KB
 Downloaded:  647 Time(s)
Patch tri out - saw mod.mp3
 Filename:  Patch tri out - saw mod.mp3
 Filesize:  518.78 KB
same adsr patch switch from low to high.mp3
 Filename:  same adsr patch switch from low to high.mp3
 Filesize:  1.26 MB
 Downloaded:  649 Time(s)
sinusout-mod-by-sin_tri_saw_rec.mp3
 Filename:  sinusout-mod-by-sin_tri_saw_rec.mp3
 Filesize:  457.96 KB
 Downloaded:  632 Time(s)
gabbagabi
PostPosted: Mon Oct 16, 2017 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
new version
edit: startframe of the gif has more information now
 Filesize:  135.18 KB
 Viewed:  430 Time(s)
 Filesize:  829.79 KB
 Viewed:  468 Time(s)
Ricko
Audio files: 27
PostPosted: Tue Oct 17, 2017 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Lovely to see minimal designs! (Not that there is anything wrong with elaborate designs, if it represents good engineering, of course.)
Rick
gabbagabi
PostPosted: Thu Dec 14, 2017 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thx Rick!
Today i add a saw tzvco.
cheers, bb
 Filesize:  117.51 KB
 Viewed:  435 Time(s)
 Filesize:  904.83 KB
 Viewed:  330 Time(s)
Ricko
Audio files: 27
PostPosted: Thu Dec 14, 2017 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice trick with the comparators!
(Oops I misread them; I thought you had put inverting halfwave rectification, adding this at twice the signal level, so that the negative saw got reflected about 0V. That would be a nice circuit too.)
gabbagabi
PostPosted: Sat Dec 16, 2017 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Rick,
good idea and i will make a note about it, but i guess i will stick to the comparators.
I have putted two comparators because after the first one u could find some "ripples" in the square wave (there where the Saw touches gently the 0V line), after the second they where boosted out.
R11 and R12 in the schemo have probably wrong values, they are more likely 10k or 100k, have to confirm this.
I would call this first version of this circuit "the precise one". I have already simulated a component saving version, which is expected to be less precise.
I have attached a preview of it.
a nice weekend for us all
cheers, bb
 Filesize:  93.09 KB
 Viewed:  342 Time(s)
gabbagabi
PostPosted: Mon Mar 05, 2018 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
of course the idea of inverting the signal after the integrator and before the trigger can be applied to a saw-vco as well
 Filesize:  125.69 KB
 Viewed:  318 Time(s)
PostPosted: Wed Mar 07, 2018 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I really like to follow the process of design of this VCO, but the voltages you mention in this diagram are confusing to say the least..
my synth
gabbagabi
PostPosted: Wed Mar 07, 2018 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry Embarassed i thought nobody is listening Smile
the green one is the CV
the red one we could call the RAW-SAW
the blue one is the final result after processing it with a trigger which changes polarity when the voltage of the raw-saw (not the frequency) goes thru zero.
a part of that rectangle signal is then mixed thogether with the RAW-SAW to center it around 0V.
PostPosted: Wed Mar 07, 2018 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Haha, no I mean the voltages you place at the opamps, like vcc, vdd, 15v and -15v.
Some just seem to float and not connected to anything Wink
my synth
gabbagabi
PostPosted: Wed Mar 07, 2018 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
got it,
thx for the head up.
will be better in comming schemos.
cu
elcoco
PostPosted: Tue Mar 13, 2018 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow these look great, I'll have to give them a try to hear tem in person. Any idea if running this off 12v would work as well as 15?
gabbagabi
PostPosted: Wed Mar 14, 2018 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
u need a dual supply
they are designed for +/-15V
it will run from +/-12V
only the amplitude wil not be 5Vpp
a bit less
please let us know how it turned out
at the moment i have no energy in the workshop
so i cant go for further testing these days
the triangle versions are all fully tested
only the first saw version i had on breadboard, like u can see there is a "real-life-scopie"
cheeres, bb
gabbagabi
