Saw Animator V2 PCB Error
Page 1 of 1 [2 Posts]
Sebo
PostPosted: Wed Apr 12, 2017 4:35 pm    Post subject: Saw Animator V2 PCB Error Reply with quote  Mark this post and the followings unread
Hi Yves:
I discovered an error in the new PCB for the Saw Animator (V2).
The +V of U5 (the most right TL072) is connected to pin 7 instead of pin 8.
Is an easy fix, just cut the trace between the +V rail to pin 7 then solder a bridge to pin 8.
Great module by the way Smile
Sebo
My Music:
yusynth
PostPosted: Fri Apr 14, 2017 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Sebo, I'll check that and correct it
Yves
