Help with Dual Balanced (ring) Modulator / Soundtronics kit
Page 1 of 1 [8 Posts]
bassculture
PostPosted: Fri Jun 30, 2017 1:27 am    Post subject: Help with Dual Balanced (ring) Modulator / Soundtronics kit Reply with quote  Mark this post and the followings unread
Hello all !
i am building some yusynth modules.
Boards are good quality & shipping was fast Wink
A have trouble with the ring mod >
Both sides are showing similar behaviour
althought measurements on 2nd amp of TL072 1 & 2 are not the same.
behaviour is : no (ring mod at) output, only very low level input 1 + 2
(bleedthrought i suppose - approx 20x less level than input )
I'm using a +/- 15V Power Supply
here are my voltages :
TL072 n1:
0
7,29
7,27
-14,87
0
0
-0.05
+15.15
MC1496 n1 :
-4,16
-0,59
-0,62
-4,19
-14,34
14,56
0
15
0
15
0
14,56
0
-14,86
TL072 n2 :
0
6,22
6,21
-14,86
0
0
-0.24
+15,16
MC1496 n 2 :
-4,19
-4,90
-4,9
-4,24
-13,17
+12,41
0
13,04
0
13,05
0
12,45
0
-14,87
bassculture
PostPosted: Fri Jun 30, 2017 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
pictures below >>
 Filesize:  1.97 MB
 Viewed:  364 Time(s)
bassculture
PostPosted: Fri Jun 30, 2017 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
/// and posting this as a reminder...
If Yves Usson is around >
what does he meant by "this module can be used as voltage controlled distortion or clipping module"
modulating Audio w/ Fixed CV is the way ?
then it'll clip in the TL072 first stage ?
yusynth
PostPosted: Wed Jul 05, 2017 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
It seems that the ground pad of the input connector misses a track to actually connect it to the ground, thus the 1.5K (R8 and R30) is not connected to the ground although it should be. Connect a wire between the ground pad pf this connector to the closest ground track.
There is also a missing track between R16 and the ground track.
Sorry about that I will have this corrected and will publish an erratum on Soundtronics
Yves
bassculture
PostPosted: Sat Jul 08, 2017 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you very much for your quick reply !
someone has to crash-test those new PCB's ! this is DIY after all Wink
I'll try this and post pictures as soon as i can get back to the soldering desk !
bassculture
PostPosted: Sat Jul 08, 2017 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Corrections done.
Here is a picture of them >
 Filesize:  459.38 KB
 Viewed:  325 Time(s)
Audio files: 279
PostPosted: Sat Jul 08, 2017 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice solder work too :-)
bassculture
PostPosted: Mon Jul 10, 2017 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
@bluehell
thanks !
