Modular G2 Demo v1.40 blocks at welcome screen
Page 1 of 1 [5 Posts]
anarki
PostPosted: Fri Jul 31, 2020 4:44 am    Post subject: Modular G2 Demo v1.40 blocks at welcome screen Reply with quote  Mark this post and the followings unread
I am using the Nord Modular G2 Demo v1.40 on Windows 10. When I start the G2 editor, I get a message window (see Attachment), but I can't close this window, when I click on “OK”.
How can I fix this problem?
Thanks in advance!
Anarki
 Filesize:  65.24 KB
 Viewed:  17 Time(s)
Audio files: 262
PostPosted: Fri Jul 31, 2020 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. I had not used it in ages, but it still works here on win10 .. maybe try the windows compatibility trouble shooter?
locate the executable (in Program Files (x86)\Clavia), right click on it and from the popup menu select "Troubleshoot compatibility"
anarki
PostPosted: Fri Jul 31, 2020 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
No, that didn't fix the problem
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sat Aug 22, 2020 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am surprised that the solution from Blue Hell is not working. Did you tried to reinstall it?
You can probably remove (or close it automaticaly) this window by editing the software with reshacker.
Or you can find few edited versions here on the forum (with this windows edited). You can try them too.
dorremifasol
G2 patch files: 49
PostPosted: Mon Aug 31, 2020 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Works great here with the latest Windows 10 update.
Check if you have too many audio devices.
Albert
