Seqchord
Page 1 of 1 [6 Posts]
wakyct
Audio files: 12
PostPosted: Sun Feb 14, 2021 8:24 pm    Post subject: Seqchord Reply with quote  Mark this post and the followings unread
I've tried a few things, but I can't figure out how the Seqchord chord sequencer works (it's one of the few modules with no help file).
It seems like patching a trigger (say, a LFO) to the gate input should step through the four chords, using whatever audio input you've patched in as the sound source. If I patch an oscillator into audio input and then patch the Seqchord output to audio out I just get the osc's pure tone though.
Would appreciate any pointers, thank you!
edit: OK, I think I might have the wrong idea -- you don't send audio through the Seqchord, but use the signals coming out of it to control the frequencies of oscillators?
Audio files: 274
PostPosted: Mon Feb 15, 2021 6:25 am    Post subject: Re: Seqchord Reply with quote  Mark this post and the followings unread
Indeed, it makes control signals meant to control frequencies with.
You are right, that module could use a couple of words for the help Rolling Eyes
wakyct
Audio files: 12
PostPosted: Mon Feb 15, 2021 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't quite have the idea of the outputs yet, it seems like the first chord affects multiple outputs while the second chord has no effect. Does the module actually step through the chords? I haven't figured that part out yet.
I've attached a screenshot of what I have so far.
 Filesize:  22.03 KB
 Viewed:  2601 Time(s)
Audio files: 274
PostPosted: Mon Feb 15, 2021 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I should step when connecting a clock to the gate input. The active inputs are there to be able to make steps (in)active.
Edit: undo that ... it works differently ... will come back with an example after figuring out what it actually does Shocked
Audio files: 274
PostPosted: Mon Feb 15, 2021 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, this seems to be like I intended it to be used ...
Edit: Updated the help text for the module too, this wil be in the next release, and for now can only be seen @ https://bluehell.nl/wren/modules.html#1216
chord-seq-example.wren
Wren chord sequencer example
 Filename:  chord-seq-example.wren
 Filesize:  24.82 KB
 Downloaded:  256 Time(s)
wakyct
Audio files: 12
PostPosted: Mon Feb 15, 2021 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great example Jan thanks!
It seems like the four outputs send the same signal? Are they there to work with the chain inputs in the top right of the module?
edit: Just saw the help text...I think that explains it. Thanks again!
