 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
M185/Metropolis inspired stage sequencer
Voltita
PostPosted: Fri Dec 24, 2021 11:43 am    Post subject: M185/Metropolis inspired stage sequencer Reply with quote  Mark this post and the followings unread
This is my first patch ever shared, so please feel free to comment it and give improvement ideas.
My N185 Sequencer is RYK M185 or Metropolis inspired stage sequencer with 3 sequence lines in my example patch. I have never had access to the examples, but they gave me the main idea for this patch to have the SeqTimes-module that sets the number, how many times the clock pulse received from the master clock is repeated on each stage to tigger gate signal.
1) SeqPitch sequencer module obviously holds the given note over one stage (mapped to E Effect/1 knobs). The buttons can be used to trigger glide.
2) SeqTimes sequencer defines the length of each stage (mapped to E Effect/2 knobs). Buttons (should) allow you to bypass the stage without clock pulse triggering gate signal.
3) SeqMod sequencer module (mapped to E Effect/3 knobs) offers then additional modulation line for e.g. filter cutoff, LFO rate, etc. The buttons tigger halving of the clock pulse trigger on the stage. I.e. without halving the 4 clock pulse long stage would play all notes "....", but when halved only every second ".-.-"
Length of the 3 sequence lines are mapped under B LFO/3 knobs and as usual - using uneven lengths on sequence lines will result in happy accidents. Using maximum 8 step length is however recommended due to limited knob mappings.
Rest of the patch is just put together to demonstrate the sequencer functionality.
185StepSequencer.pch2
Correct version uploaded
 Filename:  185StepSequencer.pch2
 Filesize:  8.08 KB
 Downloaded:  186 Time(s)
