Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Fri Aug 19, 2005 2:26 pm Post subject:
soundlab stripboard |
hey, Im curently building a soundlab from stripboard and if thought id draw it along the way, The drawings not complete yet and I havnt cheked for errors or tested anything, im not sure if im doing it the most efficient way either, but seeming as noones done it yet. evenually ill have a drawing that will join all the bits up, I just wanted to show it off its pretty useless at the moment as this is the biggest thing ive tackled with stripboard. Tell us if you find any errors, maybee theres a better way to lay it out?. Its based on using the wireing diagram Ray gave for for the front panel.
www.bent-hology.com/sharedfiles/soundlabbackup.pdf
btw this sound lab is genious thanks ray!! |
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Posted: Fri Aug 19, 2005 9:37 pm Post subject:
WOW.
first when i read the subject i thought this was a joke.
but the i looked at the .PDF and it makes perfect sense now.
this is so cool if you want to ad some more modules for SL
hope you get this drawn and checked
thanks. all this SL-thing is growing every day and i like it
dnny _________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
Wild Zebra
Posted: Mon Aug 22, 2005 6:15 am Post subject:
Very nice. I agree with dnny it'll be very cool for anyone who
wants to add some modules on. Or start a new
Very impressive and nice work. _________________ "your stripes are killer bro" |
Clack
Posted: Mon Aug 22, 2005 6:29 am Post subject:
ive tested the LFO and it works, the er noise doesnt i need to look at it it could just be a bust IC or quiet transistor, you could quite easily create 2 x LFos from one board the circuits are quite evenly divided each half. you would have to duplicate some of the IC's to make new modules though in some cases as some parts ( ie osc2 shares the LF442 IC with the AR ). Im also translating rays matrixed keyboard design( i hope he doesnt mind me doing all this ) I will eventually make them so you can modules but i have to get the basic one working! |
Wild Zebra
Posted: Mon Aug 22, 2005 6:45 am Post subject:
The noise could quite possibly be the tranny. I had about 10 laying around and some of them seemed to produce very little noise. _________________ "your stripes are killer bro" |
Clack
Posted: Mon Aug 22, 2005 6:49 am Post subject:
i dunno, its made about a second of noise then faded , like somthing is not discharging. |
dnny
Posted: Wed Aug 31, 2005 12:24 am Post subject:
Re: soundlab stripboard |
those pages are nice - are those your pages ?
i like very much those hot boxes - and the DIY-machines.
i have some guestions :
sound shoes ? are those kind of triggers whit piezos ? or whats inside?
and is there any posibility for sound sample ?
daniel _________________ Association of experimental electronics
www.koelse.org
Clack
Posted: Wed Aug 31, 2005 1:17 pm Post subject:
they were just peizos , i then attached it to an amp. I am planning on creating a trigger signal though to see if i can attach it to a soundlab, should be cool walk and make noise!!
by the way im 'Stuff_and_that' on experamental anonamous , i really want to see your led scope |
Macaba
Posted: Wed Aug 31, 2005 2:10 pm Post subject:
yupyupoh wrote: |
What is this? A forum? It sounds most intriguing. |
dnny
Posted: Wed Aug 31, 2005 2:50 pm Post subject:
Macaba wrote: |
yes its a forum :
The experimentalists anonymous forum
yupyupoh wrote: |
by the way im 'Stuff_and_that' on experamental anonamous , i really want to see your led scope ...
... I am planning on creating a trigger signal though to see if i can attach it to a soundlab, should be cool walk and make noise!! |
oh well nice to know people are having so many identities on web . . .
i´m trying to stick whit this "dnny" -nick on every place -
whit the Sound Lab Mini-Synth Drum Trigger -mod you can trigger SL whit piezos.
yeah the scope is comming . . . so litle time and so much to do . . . i just got one order of those sequencers i made recently - so first things first -
but i will show the results when i get some
www.koelse.org
Macaba
Posted: Wed Aug 31, 2005 3:05 pm Post subject:
That forum is like, totally cool. |
dnny
Posted: Sat Sep 03, 2005 4:45 am Post subject:
i have found some errors in the VCA
i assume that under the LM13700 there goes a cut on the stripes?
the power pins 6 (-V) and the 11 (+V) are ignored ?
the pin 11 is now connected to Ground. but it should be connected to +V
the pin 9 is now connected to +V but it should be not connected.
the pin 6 should be connected to -V
LM13700 data sheet
all the other things on VCA seems to be ok.
i will try to build this on stripboard soon. so we can see how it works
www.koelse.org
Clack
Posted: Sat Sep 03, 2005 5:48 am Post subject:
ah right thanks , i think i corrected it as i have built it, but ill check it out. the one posted is a bit dated, I just updated it ( now includes half done keyboard circuit! )
so far ive built
noise + lfo
vca
vcf
only the lfo is fully working and tested though , i just got a scope! so it should be esier now |
Posted: Sat Sep 03, 2005 6:06 am Post subject:
Hey,
I like the layouts you've done. I was going to separate them out like that to, but I just kept adding more to the one board and ended up with the whole thing. I've just sent Ray a copy of the layout, he should have it up on his site soon.
If you're into stripboarding, I'd definately checkout Lochmaster. It's a nice little program for designing stripboards.
www.abacom-online.de
See ya,
Andrew _________________ What makes a space ours, is what we put there, and what we do there. |
Clack
Posted: Sat Sep 03, 2005 10:25 am Post subject:
well i just built and tested osilator 1 and it seems to work I get a sawtoth , but er its way up the top of the range i had to put the vertical position knob right to the bottom to view it on the scope do you think its ok?? if this happens does this means that the oscilations hare happening way above 0 volts ? i need to listen to it!
edit : dont worry i found out it has to be on AC |
