zipzap
Joined: Jan 31, 2003 Posts: 18197 Location: Durham, NC
Audio files: 212
Posted: Wed Feb 01, 2006 11:20 am Post subject:
The attenuator network you are using is a fancy example. If you change the values of any resistor, you should change all others by the same factor or percentage.
In audio mixer applications, it is OK to use anthing from 10K to about 100K. Much lower and you start using too much current, and much higher and you start getting noise problems. What's important is the ratios. Mixers generally have unity gain at the summing amplifiers.
In order to get the unity gain, make sure the summing resistors are the same size as the feedback resistor that goes from the negative op-amp node to the output.
The IC Op-amp Cookbook by Walter Jung is a great source of information about this topic. Highly recommended.
http://www.amazon.com/gp/product/0138896011/104-6772110-1387166?v=glance&n=283155 |
zipzap
Posted: Wed Feb 01, 2006 7:53 pm Post subject:
shure, i didn´t make myself clear enough. I want to change all resistors and keep the amplification the same. I have a big little pile of 100k resistors here and i´m not sure if i want to use them for all my summing apps.(and order a pile of 100k pots) thats why i´m askimg. If you look at different shematics you see 10 to 100k, just as you said. For cv its probably no big deal, but with audio it might be... Does 100k resistance give 2x the noise of 50k? It´s to late right now, but i think i´ll do some mesurering tomorrow. |
Audio files: 212
Posted: Wed Feb 01, 2006 8:01 pm Post subject:
zipzap wrote: | shure, i didn´t make myself clear enough. I want to change all resistors and keep the amplification the same. I have a big little pile of 100k resistors here and i´m not sure if i want to use them for all my summing apps.(and order a pile of 100k pots) thats why i´m askimg. If you look at different shematics you see 10 to 100k, just as you said. For cv its probably no big deal, but with audio it might be... Does 100k resistance give 2x the noise of 50k? It´s to late right now, but i think i´ll do some mesurering tomorrow. |
The 100K resistors will do just fine. There will be no where near 2X the noise of 50K. The noise calculation is quite complex. I would not worry about it at all. If you were using 1 M or 10 M then maybe there might be some concern, but the newer low power op amps perform much better in this respect that the older ones. Really, it's not a thing to be concerned about.
If you use 100K summing resistors, just be sure to use 100K feedback resistors too. I'm sure that is your intension. Then the gain will be the same. Put a 10 pf or 20 pf capacitor across the feedback resistor. This is sometimes called a compensation capactor. It will reduce the chance of your circuits from picking up noise from close radio transmitters or other sources of RF interference. _________________ --Howard
my music and other stuff |
