 Forum index » Clavia Nord Modular » G2 Performances - Noodles
A lot of vintage tape-echo sounds
Page 1 of 1 [10 Posts]
Rob
G2 patch files: 109
PostPosted: Fri Dec 29, 2006 5:51 pm    Post subject: A lot of vintage tape-echo sounds Reply with quote  Mark this post and the followings unread
Noodle that produces a lot of organic vintage tape-echo sounds. Just let it run for a while.
Personally I like to record it for some time and then do some cut and pasting, looping or sampling, to save the most interesting parts.
TapeEchoSounds.pch2
Noodle that produces a lot of vintage tape-echo sounds. Let it run for a while.
 Filename:  TapeEchoSounds.pch2
 Filesize:  4.82 KB
 Downloaded:  3273 Time(s)
cebec
G2 patch files: 31
PostPosted: Fri Dec 29, 2006 9:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some really great sounds are coming out of this after a short while!
PostPosted: Mon Jan 01, 2007 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, a nice one !
cappy2112
PostPosted: Tue Jan 02, 2007 11:53 pm    Post subject:
Subject description: perf using two of Rob's 'tape' patches
Not really sure why I did this, partly because both patches in this perf involve tape-related sounds.
I took Rob's tapeechosounds_143 patch and ran it's output into the RevoxA77 patch. http://electro-music.com/forum/viewtopic.php?highlight=revox&t=7442
It may not make much sense, but the combination of these patches makes some interesting sounds.
I played a lot with the Revox A77 patch and noticed that when the signal in the right channel in the Revox patch is low amplitude or even missing for a short time, you still hear some neat sounds.
A minor change- I added a little S&H to interrupt the signal in the right channel.
I also experimented with adding more voices in Slot A, but the sound can get somewhat cacophonous at times, so I think mono sounds "less crowded".
Ok- after an hour+ of this, I'm ready for some non-evolving pads, or even just white noise Smile
TapeEcho2Revox.prf2
 Filename:  TapeEcho2Revox.prf2
 Filesize:  9.5 KB
 Downloaded:  3381 Time(s)
PostPosted: Wed Jan 03, 2007 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome patch Rob Very Happy
It's VERY Tod Docstader indeed. Very very nice.
(works great on the G2 demo too- although not very well on the OSX partition. XP runs it very nicely, (but then it is 2.16 GHz Shocked ). Shame on you Clavia! Twisted Evil )
sheridan
Audio files: 27
PostPosted: Fri Jan 12, 2007 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Very interesting! Very Happy Hey Rob, is the only sound source that one noise module? (Apart from the delays) If it is, that makes this patch even more amazing! Very Happy
transformer Sheridan
PostPosted: Fri Jan 12, 2007 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well it makes sense because after all, Tod Dockstader used only 'found sounds' and 3 reel to reel tape machines. No synthesisers or any of that mumbo-jumbo Shocked Very Happy )
Essentially that's what this patch is. A lot of sped-up and slowed-down tape machines Cool
G2 patch files: 626
PostPosted: Fri Jan 12, 2007 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is the self modulated OscC1 in the bottom right as well. Still an amazing range of interesting sounds though.
Vader77
PostPosted: Sun Jan 29, 2017 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi can anyone tell me the function of the curious serial Mix2-1B routings? Do they serve as a filter or eq or something as I've seen folk do similar with other patches. Cant get my head around their inputs being fed into the outputs too.
thanks
PostPosted: Sun Jan 29, 2017 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
There is nothing special with the mixers, the feedback just introduces one sample of time delay. The delayed signal is ten recursively mixed with the other input signal(s). This results in the implementation of a digital filter.
https://en.wikipedia.org/wiki/Digital_filter
