 Forum index » Clavia Nord Modular » Bugs
SysEx dump problem
Page 1 of 1 [6 Posts]
alfredsolax
PostPosted: Mon Sep 03, 2007 10:17 am    Post subject: SysEx dump problem
Subject description: ...don't understand why...
Hi everyone! This is the issue:
1- loaded the 1:68 factory "GrabBass NL2"
2- hit record on sequencer (I use MOTU Digital Performer)
3- tweak the sound
4- hit shift+"Dump one" button on G2X
So, when I hit play on sequencer the G2X say "Dump failed!"
I've noticed that no other patches makes this mess...
I've also reloaded the original banks, thinking somethings corrupted...
I work on a Mac with OSX.4.10, G2X is 1.40 and the editor too.
Thank you all, guys! This is a forum with a capital F!!!
Fede
www.federicosolazzo.com
Audio files: 268
PostPosted: Mon Sep 03, 2007 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, what makes the patch different from others? Is it a big one? Sorry but I know nothing about he factory presets ... I don't have 'm even ...
alfredsolax
PostPosted: Mon Sep 03, 2007 10:36 am    Post subject: The patch... Reply with quote  Mark this post and the followings unread
The messy patch...
Fede
GrabBass NL2.pch2
This is the 1:68 factory patch...
 Filename:  GrabBass NL2.pch2
 Filesize:  3.54 KB
 Downloaded:  1162 Time(s)
Audio files: 268
PostPosted: Mon Sep 03, 2007 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Nothing special I see ... is just the typical patch I'd say ... weird.
alfredsolax
PostPosted: Mon Sep 03, 2007 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, but if you try to dump it, the G2X fails!
Why?!?
Anybody knows an hardware reset? I didn't find it...
Fede
Audio files: 268
PostPosted: Mon Sep 03, 2007 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I believe you Very Happy
Why?!?
I don't know ...
I know not of it's presence either, other than the power switch ...
The thing is that if you have one patch that won't work with the dumps it probably is a bug in the OS that will not be solved by resetting the machine in any way.
Is it possible for you to use another work flow maybe? Like sending a bank/patch select from the computer instead of the whole patch. You'd have to store the tweaked patches in the synth then of course.
