 Forum index » Clavia Nord Modular » G2 Performances - Completed
Unbounded
Page 1 of 1 [5 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Aug 13, 2008 9:29 pm    Post subject: Unbounded
Subject description: chill glitch
I've been experimenting with random step generators which produce a new note on each clock. Earlier ideas implemented a bounds check and limit so the note sequence wouldn't wander into the very low or high range and stay there.
This produced some undesired/unnatural effects at the boundaries.
This solution is more gentle, and skews the probability that the next step is up or down proportional to how far from center the current note is. The circuit is in blue in the VA of slot A
Unbounded.prf2
chill glitch
 Filename:  Unbounded.prf2
 Filesize:  16.08 KB
 Downloaded:  1669 Time(s)
Audio files: 262
PostPosted: Mon Aug 18, 2008 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting circuit, it seems to give a nice tension when the algorithm goes uphill.
Alexander
G2 patch files: 4
PostPosted: Mon Aug 18, 2008 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wonderful patch, it sounds so so good..
I enjoy serial music a lot and the melodic part serves as a great generator. I still have a hard time figuring the patch out, how the pad seems to follow the melodic gestures, is that just me, or was it intended that way? The more I listen the more questions come up, great stuff!
I still have a long way to go with my patches, you are a great inspiration.
http://husc-sound.com
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Aug 18, 2008 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
The pad takes 50% of every 5th gate from the melody and just plays whatever note value is present at the time.
See the three modules in the last column of slot A VA.
cheers
iPassenger
G2 patch files: 78
PostPosted: Tue Aug 26, 2008 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice work. Smile
iP (Ross)
