 Forum index » Clavia Nord Modular » G2 Patches - Completed » Drum
My live drum machine
Page 1 of 1 [14 Posts]
kara
G2 patch files: 5
PostPosted: Wed Oct 29, 2008 7:34 am    Post subject: My live drum machine
Subject description: with a lot of help from members here !
This is the drum machine I'll use for my live setup.
I realy didn't invent a lot, it's based on a machine downloaded from here and where I integrated a couple concepts on advice of members of this forum (thank you very much).
It should be rather simple to understand, otherwise even I wouldn't understand it Very Happy
Kick and snare have each a fixed pattern and a 'accidental' pattern of which the step can or can not be triggered.
The velocity step sequencer of the snare allso changes the sound of the snare hit and the sound of the Hihats.
The hihat sequencer handles both open&closed Hihat depending on the position of the slider.
All this in a effort to make it sound as less as possible as a fixed drum sequencer.
I didn't assign any parameters to knobs as I suppose that everybody would prefere his proper organisation.
mymachinedrumV4.pch2
A live drumbox
 Filename:  mymachinedrumV4.pch2
 Filesize:  4.51 KB
 Downloaded:  1828 Time(s)
Free samples, Vsti's and Artist hosting at www.kara-moon.com
Music forum at www.kara-moon.com/forum
cebec
G2 patch files: 31
PostPosted: Wed Oct 29, 2008 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one! It definitely sounds more natural than a typical drum machine.
dorremifasol
G2 patch files: 49
PostPosted: Wed Oct 29, 2008 9:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds familiar Very Happy
I like the idea about the "accidental" pattern!
Albert
kara
G2 patch files: 5
PostPosted: Thu Oct 30, 2008 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the basic drum machine is yours dorremifasol Cool
I liked the logical construction of it and decided to extend it.
In the next version i'll propably add some accidentals to the hihats too.
k
kara
G2 patch files: 5
PostPosted: Thu Oct 30, 2008 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Next version, added controlled/random changes to the HiHats.
With thanks to ian for the explination how the valswith works.
[edit] I had some other ideas to expand it, but i'm running out of VA cycles. What a shame.....
k
mymachinedrumv5.pch2
With variations on the Hihats
 Filename:  mymachinedrumv5.pch2
 Filesize:  5.01 KB
 Downloaded:  1601 Time(s)
PostPosted: Thu Oct 30, 2008 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like it's time to dive into performance mode instead of a patch mode!
kara
G2 patch files: 5
PostPosted: Fri Oct 31, 2008 12:40 am    Post subject: Reply with quote  Mark this post and the followings unread
True !
But first I'm making a derivate specialy oriented for live DJ's Very Happy
Roland Kuit
G2 patch files: 127
PostPosted: Fri Oct 31, 2008 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
hi kara, nice work. i added a gater to it.
mymachinedrum with gating.pch2
 Filename:  mymachinedrum with gating.pch2
 Filesize:  5.4 KB
 Downloaded:  1669 Time(s)
kara
G2 patch files: 5
PostPosted: Fri Oct 31, 2008 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice touch Roland, again I've learned something Cool
I understand what the gater in the main output stream does, but what do the 4 constant values connected to the 4-1switch do ?
k
Roland Kuit
G2 patch files: 127
PostPosted: Fri Oct 31, 2008 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
the 4 constant modules , each with an other level, are going into the switch module. the switch module is switching the patterns:)
kara
G2 patch files: 5
PostPosted: Fri Oct 31, 2008 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
A yes, I see now, it gives the possibilty to switch the random pattern.
Thanks
k
Roland Kuit
G2 patch files: 127
PostPosted: Fri Oct 31, 2008 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
hi, an other trick is making reset slices. in the next example i added one.
mymachinedrum with gating-resetter.pch2
 Filename:  mymachinedrum with gating-resetter.pch2
 Filesize:  5.71 KB
 Downloaded:  1919 Time(s)
kara
G2 patch files: 5
PostPosted: Sat Nov 01, 2008 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Great addition Roland.
Sounds like a real drummer.
I'm really looking forward to your workshop
k
dorremifasol
G2 patch files: 49
PostPosted: Sat Nov 01, 2008 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now that's getting pretty interesting Very Happy
Albert
