today> Twyndyllyngs Live via Ninjam tonight Chez Mosc
Spectral Wave Morph
G2 patch files: 626
PostPosted: Mon Dec 19, 2005 10:31 pm    Post subject: Spectral Wave Morph Reply with quote  Mark this post and the followings unread
Some time to kill while waiting for the sitter. This patch which should run on the G2 Demo, morphs from sine – triangle – square – sawtooth or rather the PM equivalents.
As Kassen pointed out in another topic, morphing can be done in the time domain, like a simple cross fade or in the frequency domain. The latter involves a smooth transition between the harmonic spectrum. I’m not sure how much difference this actually makes with these simple waveforms. The patch itself fades in a 2:1 PM modulator (triangle then square like) which is then cross faded into a 1:1 or self modulation (sawtooth like).
FDOMMORPH.pch2
morphing between (spectrums) of sine tri square saw
 Filename:  FDOMMORPH.pch2
 Filesize:  1.37 KB
 Downloaded:  1505 Time(s)
