 Forum index » Clavia Nord Modular » G2 Performances - Completed
Tezzm
Page 1 of 1 [3 Posts]
Unfed
G2 patch files: 11
PostPosted: Wed Jan 25, 2006 1:45 am    Post subject: Tezzm Reply with quote  Mark this post and the followings unread
here's the first real performance i made on the G2. it's complete enough to be 'played' as-is, but could still use some work. it's not meant to be played from the keyboard, all patches are sequences so just hit Run and go from there.
here's a brief description of what's going on:
- variations for slots A and B (C is blank for now) are controlled by midi CCs sent from three parallel 4-bar sequencers in slot D. variation #1 in the first two slots are muted to allow for 'rests'. this acts as a sort of pseudo-wavesequencer or rhythm splicer. in slot D variations 1-7 sort of build up in activity while variation #8 has all sequencers set to 'clear' to allow for manual switching by using the handy assigned (though generically labelled) knobs on page A1. i'd suggest spending time with variation 8.
- audio from slots A and B has been routed internally to a sort of 'master fx' section in slot D. you'll find controls on page A1 (slot D) for slot volume/mute as well as filter freq controls for the assignable outputs.
Tezzm001.prf2
 Filename:  Tezzm001.prf2
 Filesize:  15.62 KB
 Downloaded:  1203 Time(s)
Audio files: 261
PostPosted: Wed Jan 25, 2006 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
You got some nice sounds going on, some of the drum things you posted before were also nice.
cebec
G2 patch files: 31
PostPosted: Wed Jan 25, 2006 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, some cool sounds/sequences and i like how you 'sequenced' the variations.
