Buchla 218 VC-able Portamento - Works!
Page 1 of 2 [39 Posts]
vtl5c3
PostPosted: Thu Jun 28, 2007 9:57 am    Post subject: Buchla 218 VC-able Portamento - Works! Reply with quote  Mark this post and the followings unread
Last night I finally tested the slew circuit that I cloned from the Buchla 218 keyboard. I'm happy to say that it works. I've posted the schematic and a couple of sound samples below. I may have to do a bit of fine tuning... if nothing else I will try smaller cap values, since it's pretty easy to get way too much portamento going.
Update: I've uploaded the PCB layout, for those who like to roll their own.
 Filesize:  276.41 KB
 Viewed:  984 Time(s)
PCB Layout. Works!
 Filesize:  174.78 KB
 Viewed:  950 Time(s)
218_slew_01.mp3
 Filename:  218_slew_01.mp3
 Filesize:  229.46 KB
 Downloaded:  1829 Time(s)
218_Slew_02.mp3
 Filename:  218_Slew_02.mp3
 Filesize:  140.08 KB
 Downloaded:  1592 Time(s)
buchla_218_Slew_parts.pdf
Parts layout. Corrected diode part number.
 Filename:  buchla_218_Slew_parts.pdf
 Filesize:  43.72 KB
 Downloaded:  1475 Time(s)
StephenGiles
PostPosted: Thu Jun 28, 2007 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting - I was waiting for Jeff Beck to crash in! Have you heard him make similar sounds!
StephenGiles
PostPosted: Thu Jun 28, 2007 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a sample of Jeff Beck doing just that
http://www.4shared.com/file/18815193/15b17a7/JBeck.html
His fingers, a whammy bar and a Rat distortion!
bubblechamber
PostPosted: Thu Jun 28, 2007 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for posting
krisp14u
PostPosted: Fri Jun 29, 2007 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers for that vtl5c3 I will have a go at this 1 over the weekend
paul D
Paul Darlow
www.krisp1.com
StephenGiles
PostPosted: Sat Jun 30, 2007 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not quite sure if I needed to have bothered (subjunctivo!) with the Jeff Beck sample - a lot of synth players would give their right arm to play like that!!
Quad
PostPosted: Sat Jun 30, 2007 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting!
What is the difference between Ground and N Ground? and what is L1 & L2?
thanks!
vtl5c3
PostPosted: Sat Jun 30, 2007 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Quad wrote:
Thanks for posting!
thanks!
Noisy ground and regular (quiet?) ground. Buchla often had separate grounds in his modules. As you can see they join together on this PCB. No need to worry about the differences. L1 & L2 are ferrite beads, same as you find on most prefab DIY PCBs these days. You can use low value resistors or jumpers if you don't have ferrite beads.
Romeo
Fernando
PostPosted: Tue Jul 10, 2007 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I missed the thread.
wow, thank you so much!
(actually the "wow" was a "fantastico" before being slewed)
Is the 4.7uF capacitor that you are refering to?
maybe is the control of the LED's vactrol what should be finetuned...?
_
Dave Manley
PostPosted: Sun May 04, 2008 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I was looking for the 218 schematics yeseterday and couldn't find them in the usual places. Are they online somewhere?
-Dave
P.S. Is there anything Buchla couldn't (wouldn't?) do with a vactrol? Very Happy
cbm
PostPosted: Sun May 04, 2008 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sort of like Serge and the LM3900.
-C
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
vtl5c3
PostPosted: Fri May 09, 2008 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you need the entire 218 schematic set? I don't think it's online, but I have them. Could have sworn I got them off the web at some point.
R.
-Dave
cbm
PostPosted: Fri May 09, 2008 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quite a few older Buchla schemos:
http://rubidium.dyndns.org/~magnus/synths/companies/buchla/
Chris Muir
Dave Manley
PostPosted: Sat May 10, 2008 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I was studying the Easel and the 218 is a key part of it. The 216 and 217 are online at Magnus' site, but the 218 is absent. It would be a good addition to his pages if available.
How many pages total are there in the 218?
CJ Miller
PostPosted: Tue May 27, 2008 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool... I was just looking over slew/portamento ideas, and I was surprised how few are VC-able.
In the schematic, it calls for a 6V Zener diode. But on your PCB diagram it says 1N5224. Isn't this a 2.8V Zener? What Zener did you use here? I don't know how crucial it is, as I have neither anyway. I'm a vactrol n00b and I don't want to fry them.
Nice efforts studying Buchla's work! Most of his stuff makes my head spin.
vtl5c3
PostPosted: Tue May 27, 2008 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Good question. I'll have to check my work when I get home. You're correct that the 1N5224 is a 2.8 Zener. It should read 1N5233. Thanks for pointing it out.
R.
haxster
PostPosted: Sun Nov 16, 2008 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is the type of vactrol used critical? Would a VTL5C4 be okay to use. I am new to vactrols.
doctorvague
PostPosted: Sun Nov 16, 2008 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
The VTL5C4 would be slower than the usual VTL5C3 that Buchla uses. It's not spec'd here but I'm assuming it is a VTL5C3 in this circuit. The 'slower' would just be response to control changes, not the portamento itself. IOW, if you wanted quick turn-on and turn-off of portamento via control voltages it will have more lag time, especially the turning off or quick turning down of the portamento. Kinda like portamento'd portamento. Shocked
Phil
doctorvague's youtube channel
vtl5c3
PostPosted: Sun Nov 16, 2008 3:25 pm    Post subject: Schematics Reply with quote  Mark this post and the followings unread
Forgot that I was gonna post them, but here they are.
218 Schem Page 1
 Filesize:  2.07 MB
 Viewed:  1395 Time(s)
Buchla 218 Page 2 Schem
 Filesize:  2.86 MB
 Viewed:  1205 Time(s)
Buchla 218 Board Part Placement
 Filesize:  2.2 MB
 Viewed:  1092 Time(s)
probablyjoel
PostPosted: Sun Dec 07, 2008 9:47 am    Post subject: dumb newbie question... Reply with quote  Mark this post and the followings unread
What type of offboard components are you using for the control inputs? Just standard 1/4" jacks?
vtl5c3
PostPosted: Sun Dec 07, 2008 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm using 1/8th inch jacks. Nothing fancy.
probablyjoel
PostPosted: Sun Dec 07, 2008 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you! One more question...I'm not so familiar with the buchla... how do the control inputs differ from the input? If i use it for my 4017 step sequencer, would it work through the normal input or through the control input?
vtl5c3
PostPosted: Sun Dec 07, 2008 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Whatever CVs you'll be processing go into the normal input. The CV input controls how much portamento is applied to the processed voltage.
probablyjoel
PostPosted: Sun Dec 07, 2008 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
So i would need another CV control to control the level of portamento? What types work best as controllers? Sorry if this is super obvious... I'm still a newbie:).
vtl5c3
PostPosted: Sun Dec 07, 2008 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can use the manual control to set a portamento amount, but the value only changes when you turn the knob. To CV control it, run an LFO into it, have a second analog sequencer control it, or even aftertouch from a keyboard... really any CV source will work.
