ElectroNotes 129 TZVCO PCB Layout
Page 1 of 4 [77 Posts]
Goto page: 1, 2, 3, 4 Next
forbin
PostPosted: Mon Mar 08, 2010 8:24 pm    Post subject: ElectroNotes 129 TZVCO PCB Layout Reply with quote  Mark this post and the followings unread
Here is a Press'n'Peel layout for the TZVCO from Bernie Hutchins as decribed in the ElectroNotes 129. Bernie has given me the OK to put this out here for anybody to use in a non-commercial manner. Please read all the notes and especially his original excellent article. There is a lot to be learnt by going through this circuit! I will post a TIFF of the PCB as well as it is often easier than getting the scaling right from a PDF!
ElectroNotes129_ThroughZeroVCO.pdf
Layout
 Filename:  ElectroNotes129_ThroughZeroVCO.pdf
 Filesize:  427.14 KB
 Downloaded:  2031 Time(s)
forbin
PostPosted: Mon Mar 08, 2010 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a GIF -- it was smaller then the TIFF. Has the advantage for drawings that you don't get the artifacts that JPEG produces... it is at 300 dpi by the way...
 Filesize:  99.01 KB
 Viewed:  755 Time(s)
Danno Gee Ray
PostPosted: Mon Mar 08, 2010 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you by chance have a component side drawing?
forbin
PostPosted: Mon Mar 08, 2010 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is in the PDF -- in the first post...
Luka
PostPosted: Mon Mar 08, 2010 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
great!
shame i just made 3 teezers
maybe ill do 3 of these also Smile
problemchild
melbourne australia
Pehr
PostPosted: Tue Mar 09, 2010 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice!
3080 though, but I could always put a 13700 on a protoboard beside. Very Happy
Any BOM? panel wiring diagram?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
andrewF
PostPosted: Tue Mar 09, 2010 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Pehr wrote:
Nice!
Has to be a 3080, have a read of the notes.
Thanks Forbin
I tried to lay this out a while ago but found it very tricky. now I don't have to
Sebo
PostPosted: Tue Mar 09, 2010 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
Thank a lot for the layout!!!
Can I use a 2SA798 instead the SSM2220?
Sebo
My Music:
andrewF
PostPosted: Tue Mar 09, 2010 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
yep, my vero-board version uses a 2sa798
Sebo
PostPosted: Tue Mar 09, 2010 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, Thank you.
Sebo
My Music:
frijitz
Audio files: 54
PostPosted: Tue Mar 09, 2010 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll be happy to refund your money if you are unhappy with them.
Ian
Luka
PostPosted: Tue Mar 09, 2010 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
i very much doubt i'll be unhappy with them ian Smile
hopefully i will have them all going tonight too as i just got my shipment of 10turn pots Smile
comment was more in reference to having a wide selection of TZ modules instead of putting all eggs in one basket, no reference to singular qualitative preference
problemchild
melbourne australia
vtl5c3
PostPosted: Wed Mar 10, 2010 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool, Forbin! I built a pair of these VCOs many moons ago and love them.
philpeery
PostPosted: Sat Mar 13, 2010 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, this is totally cool! I've always wanted to build the EN tzo! Thanks Forbin for doing this layout! It looks like a very nicely done PCB. Has anone put it together yet? I have all the semi's, and am just wondering how it sounds! If anyone has it running, PLEASE post a few sound clips. Once I get one (or two, or four!) running, I will do the same.
-Phil
frijitz
Audio files: 54
PostPosted: Sun Mar 14, 2010 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks to me like OTA-1 does not need to be a 3080. OTA-2 does need to be a 3080, because it uses the the special W. Jung trick. You could replace the VCA with a 13700-based one.
Ian
forbin
PostPosted: Sun Mar 14, 2010 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
True Ian -- i did contemplate quite a few changes -- especially making the integrator and the sine converter an LM13700. It does make the PCB a bit more of a nightmare! With 3080's still being a few dollars from Futurlec I decided to keep it faithfull to the original... Now having built it... and debugged my stuff ups in laying it out... I would not really change that much!
Sound
PostPosted: Mon Mar 15, 2010 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice project forbin. Very Happy
Ian what is the W. Jung trick? I see in the schematics other use for the negative supply. In which Jung book or where is explained it?
forbin
PostPosted: Mon Mar 15, 2010 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it was in the Unique IC OpAmp Applications. A colleague had all of these and I have a very vague recollection of reading a bit of it years ago. See: http://waltjung.org/Walts_Books.html Unfortunately for me he is on the other side of the world these days...
The technique was also used in another free electronotes, number 72, the Timbre Modulator. See: http://electronotes.netfirms.com/EN72TM.pdf
The EN#72 article alludes to a more detailed analysis of the 3080 supply control techniques in EN#63 -- which I have never read, but Bernie may well be willing to make it available...
Sound
PostPosted: Mon Mar 15, 2010 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks forbin
Sebo
PostPosted: Tue May 11, 2010 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Forbin:
I just read in your blog that you missed some resistor in your TZ VCO PCB design.
http://forbinthesynthesizer.blogspot.com/2010/02/through-zero-plane.html
Do you corrected the PCB layout posted here?
If not, could you name what resistors are missing?
Thank you.
Sebo
My Music:
forbin
PostPosted: Tue May 11, 2010 9:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The posted layout is fixed. I moved a couple of bits slightly as well as i found some tracks a little bit too close to each other. If you look at the photo on the blog and the layout on the PDF file i think that you will notice the slight changes in a couple of the IC's... Certainly a lot less painful layout than the 921B... my work colleague keeps suggesting 4 layers! which is fine for BGA's but a complete cop-out for through hole!
PostPosted: Wed May 12, 2010 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Personally, with the amount of blood, sweat and tears that went into the R&D of the Teezer, I would suggest that it would be 100 (if not more?)-fold, better bet, to invest in Ian's design?
Forgot to add, thx for the PCB anyway Forbin, it's always nice to see new projects! Very Happy
Just my 2 pence
ACHTUNG!
Sebo
PostPosted: Wed May 12, 2010 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Forbin!!!
I will be etching the PCB soon.
Sebo
My Music:
synthmonger
PostPosted: Wed May 12, 2010 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Etched a board tonight and the sizing came out wrong for me. I think the pcb layout needs to be a bit larger to accommodate the ICs and resistors better. Also, the spacing between the ground plane and traces could be a bit wider.
I'll let you know how it goes when I finish this tomorrow.
Youtube!
modular demos!
Whacky tunes!
PostPosted: Thu May 13, 2010 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Why don't you send a PNG file instead? TIFF's are huge, but sending a gif is causing problems too (because if you say that the dimensions of a TIFF are going to be 2cm x 3cm, that's what you will get!)
On the other hand, a PNG works more like a Jpeg, in that it is a compressed format, but it retains many of the characteristics that a TIFF would retain (including no artefacts), yet is much smaller.
You could also send a DXF/DWG file, but the best kind of information is vector-based, because of there being a mathematical relation between points (vectors), so in theory, you should get the correct result every time. At the end of the day, a vector is best, because there is no pixelation of the image, just nice solid black lines.
I really don't get why people don't use PNG files more often. I've heard that the ONLY browser not to support PNG has been Internet Explorer, but then times have changed quite a lot since then, and Microsoft now, are even condemning Flash! I've never had a problem with PNG, and use it all the time.
ACHTUNG!
