 Forum index » Online Music
PHOBoS - The Valley of Salie
Audio files: 705
PostPosted: Thu May 13, 2021 9:04 pm    Post subject: PHOBoS - The Valley of Salie
Subject description: a re-hearsel in one part
dwarf
 Filesize:  1.27 MB
 Viewed:  239 Time(s)
PHOBoS - The Valley of Salie.wav
PHOBoS - The Valley of Salie (a re-hearsel in one part)
 Filename:  PHOBoS - The Valley of Salie.wav
 Filesize:  15.99 MB
 Downloaded:  545 Time(s)
PostPosted: Sun May 16, 2021 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Er, is this piece really 1 minute, 35 seconds? Just asking, because a lot of your pieces are much much longer... like the epic & fun "Flubber Dubber" at 2 hours 16 minutes! Anyway, it's cool.
.: james :.
Audio files: 705
PostPosted: Sun May 16, 2021 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for listening!, and yes that's correct.
It's a re-hearsel so you can re-hear it multiple times and make it as long as you wish Wink
I do actually have a longer pre-hearsel but need to sort that out.
Audio files: 705
PostPosted: Mon May 17, 2021 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
some background info on how this piece was created:
I started with a self playing patch which also made use of my recently coded midi looper.
While this patch was playing I recorded a part of it and using ACID music studio I played it back as a short loop.
Oh and I also added a looped sound of a closing door with some effects.
So now I had the live patch and a looped section of it playing together and I recorded another part of that.
This was also added in ACID music studio as a loop so now I had the live patch and 2 loops playing.
It was recorded again, added, recorded again added, for a total of 4 or 5 times. I'm not sure if the 5th one got
in because that's when ACID became unresponsive (of course I also hadn't saved it yet). Luckely it did keep
playing so I recorded some of it and that was cut into a looping section and posted here.
I also did some things with the different loops, one was reversed, one was pitched down, there is shorter loop
in there and I also added some delay and made panning and EQ adjustments.
