Recent Changes - Search:
go to the forum
Contents
Site
Help
« mar 2022 · jul 2022 »
    add a calendar item
    Help / Todo
    Help.Todo History
    Hide minor edits - Show changes to output
    2013-04-14 17:04 [UTC-7] by Blue Hell -
    Changed line 3 from:
    %rfloat% (:toggle toc hide="hide table of contents" show="show table of contents" button=0:)
    to:
    %rfloat% (:toggle toc init=hide hide="hide table of contents" show="show table of contents" button=0:)
    2013-04-14 17:00 [UTC-7] by Blue Hell -
    Changed lines 3-5 from:
    >>rframe font-size:smaller<<
    to:
    >>id=toc
    2013-03-31 20:25 [UTC-7] by Blue Hell -
    Changed line 166 from:
    ??~Blue Hell?? 2013-03-31 18:25 [UTC-7] See [[Help.SiteSpecificMarkup#ntoc34 | there]] for a fix of this.
    to:
    ??~Blue Hell?? 2013-03-31 18:25 [UTC-7] ~ See [[Help.SiteSpecificMarkup#ntoc34 | there]] for a fix of this.
    Changed lines 162-163 from:
    !!!Brackets in user names
    to:
    !!!Brackets in user names - done
    Added line 166:
    2013-03-06 18:31 [UTC-7] by Blue Hell -
    Changed line 321 from:
    !!!Different tables
    to:
    !!!Different tables - done
    Added line 326:
    [[~Blue Hell]] 2013-03-06 16:31 [UTC-7] ~ lookup tables completed ... I hope ;-)
    2013-03-04 18:34 [UTC-7] by Blue Hell -
    Changed line 314 from:
    :-) thanks! [[~Blue Hell]]
    to:
    thanks :-) [[~Blue Hell]]
    2013-03-04 18:33 [UTC-7] by Blue Hell -
    Changed lines 314-316 from:
    !!!Radio info
    [[~Blue Hell]] 2013-03-03 18:44 [UTC-7] ~ as in 'what's on the radio now', the markup will be [={_now_playing_}=] - it needs to be implemented, it now looks like {_now_playing_}.
    to:
    !!!Radio info
    - done
    [[~Blue Hell]] 2013-03-03 18:44 [UTC-7] ~ as in 'what's on the radio now', the markup will be [={_now_playing_}=] - it needs to be implemented, it now looks like ... {_now_playing_} ... done!
    Changed line 309 from:
    !!!logo radio.electro-music.com
    to:
    !!!logo radio.electro-music.com - done
    Added line 312:
    ->done.. best I could get the color. [Q].
    2013-03-03 20:50 [UTC-7] by Blue Hell -
    Changed line 315 from:
    [[~Blue Hell]] 2013-03-03 18:44 [UTC-7] ~ as in 'what's on the radio now', the markup will be [={_now_playing_}=] - it needs to be implemented.
    to:
    2013-03-03 20:49 [UTC-7] by Blue Hell -
    [[~Blue Hell]] 2013-03-03 18:44 [UTC-7] ~ as in 'what's on the radio now', the markup will be [={_now_playing_}=] - it needs be implemented better.
    to:
    !!!radio info
    to:
    !!!Radio info
    Changed lines 318-319 from:
    !!!easier tables
    [[~Blue Hell]] 2013-03-03 18:44 [UTC-7] ~ I've made easier tables, but this still needs some work - want to be able to have lookup tables to translate cell data from the type specified in the column header. The lookup should be specified from the wiki, there now only is one lookup type, and the translation is fixed now in the php code.
    to:
    !!!Different tables
    [[~Blue Hell]] 2013-03-03 18:44 [UTC-7] ~ I've made different tables, but this still needs some work - want to be able to have lookup tables to translate cell data from the type specified in the column header. The lookup should be specified from the wiki, there now only is one lookup type, and the translation is fixed now in the php code.
    This will make it easy to import data from a spreadsheet; export as CSV data and them paste that into a data section. I will have to work out the ; row separators as well.
    2013-03-03 20:44 [UTC-7] by Blue Hell -
    Changed line 303 from:
    !!!Multiple inclusions
    to:
    !!!Multiple inclusions - done
    Changed lines 305-308 from:
    to:
    [[~Blue Hell]] 2013-03-03 18:44 [UTC-7] this seems to work okay now.
    Added lines 314-319:
    !!!radio info
    !!!easier tables
    2013-03-03 00:10 [UTC-7] by Blue Hell -
    to:
    Added line 302:
    Changed lines 307-313 from:
    to:
    [[~Blue Hell]] 2013-03-02 22:10 [UTC-7] ~ needs be moved to Site.Icons
    2013-03-03 00:07 [UTC-7] by Blue Hell -
    Changed line 297 from:
    !!timestamps again
    to:
    !!!timestamps again
    Changed line 302 from:
    to:
    2013-03-03 00:06 [UTC-7] by Blue Hell -
    Added lines 294-306:
    !!timestamps again
    [[~Blue Hell]] 2013-03-02 22:06 [UTC-7] ~ ?action=diff pages (History) still show server time stamps.
    [[~Blue Hell]] 2013-03-02 22:06 [UTC-7] ~ Need a mechanism to avoid multiple inclusions for .js and .css stuff
    2013-02-28 21:36 [UTC-7] by Blue Hell -
    Changed line 265 from:
    !!!Make date time user local - done
    to:
    !!!Make date and time user local - done
    2013-02-28 21:35 [UTC-7] by Blue Hell -
    Changed line 273 from:
    markup(
    to:
    Markup(
    Changed line 277 from:
      "<span class='xldt'>$1  $2</span>"
    to:
      "<span class='xldt'>$1  $2</span>"                       // Use two spaces to avoid double substitutions
    Added line 279:
    2013-02-28 21:32 [UTC-7] by Blue Hell -
    Changed line 266 from:
    [[~Blue Hell]] 2013-02-28 16:56 [UTC-7] ~ Change date time presentation to be in user local time instead of server time. This can only work if the user has JavaScript enabled, otherwise date time will still be presented in server time e.g. like 2013-02-28  16:56 [UTC-7].
    to:
    [[~Blue Hell]] 2013-02-28 16:56 [UTC-7] ~ Change date time presentation to be in user local time instead of server time. This can only work if the user has JavaScript enabled, otherwise date time will still be presented in server time i.e. like 2013-02-28  16:56 [UTC-7].
    2013-02-28 21:30 [UTC-7] by Blue Hell -
    Changed line 285 from:
    This does not work in IE - it does not like iterating the DOM on a name attribute - ok, will change to use class instead of name - now it has the same problem that IE has, it wont accept ISO time strings to set a Date object.
    to:
    This does not work in IE - it does not like iterating the DOM on a name attribute - ok, will change to use class instead of name - now it has the same problem that Safari has, it wont accept ISO time strings to set a Date object.
    2013-02-28 21:29 [UTC-7] by Blue Hell -
    [[~Blue Hell]] 2013-02-28 16:56 [UTC-7] ~ Change date time presentation to be in user local time instead of server time. This can only work if the user has JavaScript enabled, other wise date time will still be presented in server time e.g. like 2013-02-28  16:56 [UTC-7].
    to:
    2013-02-28 21:28 [UTC-7] by Blue Hell -
    Changed lines 281-396 from:
    (which assumes all wiki time stamps to stricly be in the format yyyy-mm-dd hh:mm [UTC-7]) and some JavaScript in [[JavaScript.FixDates]]
    <script type='text/javascript' src='http://electro-music.com/wiki/pub/common.js'></script>
    <script type="text/javascript">
      function parseISO8601String( dateString)
        var timebits =
          /^([0-9]{4})-([0-9]{2})-([0-9]{2})T([0-9]{2}):([0-9]{2})(?::([0-9]*)(\.[0-9]*)?)?(?:([+-])([0-9]{2})([0-9]{2}))?/;
        var m = timebits.exec( dateString);
        var resultDate;
        if( m)
          var utcdate =
            Date.UTC(
              parseInt( m[ 1]),
              parseInt( m[ 2]) - 1,                      // months are zero-offset (!)
              parseInt( m[ 3]),
              parseInt( m[ 4]), parseInt( m[ 5]),        // hh:mm
              ( m[ 6] && parseInt( m[ 6]) || 0),          // optional seconds
              ( m[ 7] && parseFloat( m[ 7]) * 1000) || 0  // optional fraction
          // utcdate is milliseconds since the epoch
          if( m[ 9] && m[ 10])
            var offsetMinutes = parseInt(m[9]) * 60 + parseInt( m[ 10]);
            utcdate += ( m[ 8] === '+' ? -1 : +1) * offsetMinutes * 60000;
          resultDate = new Date( utcdate);
        else
          resultDate = null;
        return resultDate;
      function fix_digits( num)
        if( num < 10)
          return '0' + num;
        else
          return num;
      function replace_dates()
        var dates = document.getElementsByClassName( "xldt");
        var stamp;
        var parts;
        var date;
        var time;
        var time_zone;
        var year;
        var month;
        var day;
        var hour;
        var minute;
        var tz;
        var len;
        var dt;
        var dts;
        var tzsign;
        var tzdata;
        var now;
        for( var i = 0; i < dates.length; i++)
          stamp    = dates[ i].innerHTML;
          parts    = stamp.split( ' ');
          date      = parts[ 0];
          time      = parts[ 1];
          time_zone = parts[ 3];
          parts    = date.split( '-');
          year      = parts[ 0];
          month    = parts[ 1];
          day      = parts[ 2];
          parts    = time.split( ':');
          hour      = parts[ 0];
          minute    = parts[ 1];
          tz        = time_zone.substr( 4);
          len      = tz.length;
          tz        = tz.substr( 0, len - 1);
          tzsign    = tz.substr( 0, 1);
          tzdata    = tz.substr( 1, 2);
          if( tzdata.length < 2)
            tzdata = '0' + tzdata;
          tz        = tzsign + tzdata + '00';
          dts      = year + '-' + month + '-' + day + 'T' + hour + ':' + minute + ':00.000' + tz;
          dt        = new Date( parseISO8601String( dts));
          year      = dt.getFullYear();
          month    = fix_digits( dt.getMonth() + 1);
          day      = fix_digits( dt.getDate());
          hour      = fix_digits( dt.getHours());
          minute    = fix_digits( dt.getMinutes());
          dt        = year + '-' + month + '-' + day + ' ' + hour + ':' + minute;
          dates[ i].innerHTML = dt;
      addLoadEvent( replace_dates);
    </script>
    that then is included in [[Site.Footer]] to get it into all pages. Date time presentation will then be fixed after page load for these who have JavaScript enabled.
    to:
    (which assumes all wiki generated time stamps to adhere strictly to that semi-ISO format) and some JavaScript in [[JavaScript.FixDates]] which then is included in [[Site.Footer]] to get it into all pages. Date time presentation will then be fixed after page load for these who have JavaScript enabled.
    2013-02-28 20:46 [UTC-7] by Blue Hell -
    Changed lines 290-291 from:
       var timebits = /^([0-9]{4})-([0-9]{2})-([0-9]{2})T([0-9]{2}):([0-9]{2})(?::([0-9]*)(\.[0-9]*)?)?(?:([+-])([0-9]{2})([0-9]{2}))?/;
    to:
       var timebits =
    Changed line 405 from:
    Ok, seems fixed for all four now by using parseISO8601String from [[http://stackoverflow.com/questions/439630/how-do-you-create-a-javascript-date-object-with-a-set-timezone-without-using-a-s } here]].
    to:
    Ok, seems fixed for all four now by using parseISO8601String from [[http://stackoverflow.com/questions/439630/how-do-you-create-a-javascript-date-object-with-a-set-timezone-without-using-a-s | here]].
    2013-02-28 20:45 [UTC-7] by Blue Hell -
    Changed line 288 from:
    to:
    Changed lines 290-317 from:
       if( num < 10)
          return '0' + num;
        else
          return num;
        var dates = document.getElementsByName( "xldt");
        var stamp;
        var parts;
        var date;
        var time;
        var time_zone;
        var year;
        var month;
        var day;
        var hour;
        var minute;
        var tz;
        var len;
        var dt;
        var dts;
        var tzsign;
        var tzdata;
        var now;
    to:
        var resultDate;
        if( m)
    Changed lines 295-311 from:
        date      = parts[ 0];
          time      = parts[ 1];
          year      = parts[ 0];
          month
        = parts[ 1];
          day      = parts[ 2];
          hour      = parts[ 0];
          minute    = parts[ 1];
          len      = tz.length;
    to:
         var utcdate =
           Date.UTC(
              parseInt( m[ 1]),
            parseInt( m[ 3]),
    Changed lines 305-307 from:
    to:
          if( m[ 9] && m[ 10]
    Changed lines 309-310 from:
    to:
    Changed lines 312-324 from:
          dt        = new Date( Date.parse( dts));
    to:
        else
          resultDate = null;
    Added line 318:
       return resultDate;
    Added lines 321-390:
        if( num < 10)
          return '0' + num;
        else
          return num;
        var stamp;
        var parts;
        var date;
        var time;
        var time_zone;
        var year;
        var month;
        var day;
        var hour;
        var minute;
        var tz;
        var len;
        var dt;
        var dts;
        var tzsign;
        var tzdata;
        var now;
          date      = parts[ 0];
          time      = parts[ 1];
          year      = parts[ 0];
          month    = parts[ 1];
          day      = parts[ 2];
          hour      = parts[ 0];
          minute    = parts[ 1];
          len      = tz.length;
    Changed lines 392-393 from:
    </script>@]
    to:
    </script>
    Added lines 404-405:
    2013-02-28 20:12 [UTC-7] by Blue Hell -
    Changed line 364 from:
    This does not work in IE - it does not like iterating the DOM on a name attribute - ok, will change to use class instead of name.
    to:
    2013-02-28 19:57 [UTC-7] by Blue Hell -
      "<span name='xldt'>$1  $2</span>"
    to:
    Changed lines 364-365 from:
    This does not work in IE - it does not like iterating the DOM on a name attribute.
    to:
    Added lines 367-368:
    It works in FF and Chrome.
    2013-02-28 19:45 [UTC-7] by Blue Hell -
    Changed lines 362-367 from:
    This gives a JavaScript error when displaying JavaScript.FixDates, seems ok on all other pages though - it be so for now.
    to:
    This does not work in Safari - it does not accept ISO time strings to set a Date object it seems.
    2013-02-28 19:25 [UTC-7] by Blue Hell -
    Changed lines 360-361 from:
    that then is included in [[Site.Footer]] to get it into all pages. Date time presentation will then be fixed after page load for thise who have JavaScript enabled.
    to:
    2013-02-28 19:07 [UTC-7] by Blue Hell -
    Added lines 271-272:
    $TimeFmt = '%F %R [UTC-7]';                // semi ISO 8601 time format
    Changed line 281 from:
    to:
    2013-02-28 19:05 [UTC-7] by Blue Hell -
    Changed lines 279-358 from:
    and some JavaScript in [[JavaScript.FixDates]], that then is included in [[Site.Footer]] to get it into all pages.
    to:
        if( num < 10)
          return '0' + num;
        else
          return num;
        var stamp;
        var parts;
        var date;
        var time;
        var time_zone;
        var year;
        var month;
        var day;
        var hour;
        var minute;
        var tz;
        var len;
        var dt;
        var dts;
        var tzsign;
        var tzdata;
        var now;
          date      = parts[ 0];
          time      = parts[ 1];
          year      = parts[ 0];
          month    = parts[ 1];
          day      = parts[ 2];
          hour      = parts[ 0];
          minute    = parts[ 1];
          len      = tz.length;
    </script>@]
    2013-02-28 19:03 [UTC-7] by Blue Hell -
    Added lines 267-279:
    This involves some markup in config.php
    markup(
      'date_and_time',
      'block',
      '/(\d\d\d\d-\d\d-\d\d\s\d\d:\d\d)\s(\[UTC-7\])/',
    2013-02-28 18:59 [UTC-7] by Blue Hell -
    Changed line 116 from:
    Also see [[http://support.google.com/webmasters/bin/answer.py?hl=en&answer=76401]] .. ok made some changes to wikilog.php to get in a couple of rel='nofollow' thingies.<br><br>[[~Blue Hell]] 2013-02-12 15:09 [UTC-7] seems to work mow.
    to:
    Also see [[http://support.google.com/webmasters/bin/answer.py?hl=en&answer=76401]] .. ok made some changes to wikilog.php to get in a couple of rel='nofollow' thingies.<br><br>[[~Blue Hell]] 2013-02-12 15:09 [UTC-7] seems to work now.
    2013-02-28 18:58 [UTC-7] by Blue Hell -
    Changed lines 264-265 from:
    !!!Make date time user local = done
    to:
    2013-02-28 18:57 [UTC-7] by Blue Hell -
    to:
    to:
    2013-02-28 18:56 [UTC-7] by Blue Hell -
    Changed lines 260-266 from:
    [[~Blue Hell]] 2013-02-27 13:35 [UTC-7] ~ editing of sections from a larger page and also stubbing section instead of whole articles.
    to:
    Changed line 260 from:
    [[~Blue Hell]] 2013-02-27 13:35 [UTC-7] ~ editing of dections from a larger page and also stubbing section instead of whole articles.
    to:
    2013-02-27 17:18 [UTC-7] by Blue Hell -
    2013-02-27 15:35 [UTC-7] by Blue Hell -
    Added lines 258-260:
    !!!Section editing
    2013-02-26 20:13 [UTC-7] by Blue Hell -
    Changed line 253 from:
    !!!Stubs
    to:
    !!!Stubs - done
    Changed line 254 from:
    [[~Blue Hell]] 2013-02-26 17:51 [UTC-7] ~ I did add stub markup but it does not work ... see [[Main.Chatter]]
    to:
    [[~Blue Hell]] 2013-02-26 17:51 [UTC-7] ~ I did add stub markup but it does not work ... see [[Main.Chatter]] .. right it just works ... just can't have category / stub as a stub ... that'd go recursive too prolly ...
    2013-02-26 19:52 [UTC-7] by Blue Hell -
    [[~Blue Hell]] 2013-02-26 17:51 [UTC-7] ~ I did add stub markup but it does not work ....
    to:
    2013-02-26 19:51 [UTC-7] by Blue Hell -
    Added lines 250-255:
    !!!Stubs
    2013-02-25 19:56 [UTC-7] by Blue Hell -
    Changed line 240 from:
    !!!RSS feeds
    to:
    !!!RSS feeds - done
    2013-02-25 19:37 [UTC-7] by Blue Hell -
    Changed lines 243-245 from:
    An example : [[Site.AllRecentChanges?action=rss&count=25 | RSS feed]] for the most recent changes
    to:
    An example : [[Site.AllRecentChanges?action=rss&count=25 | RSS feed]] for the most recent changes or {_rss_} for a feed on this page.
    Done for now, but markup is likely to change into something like [={_rss_ params}=], see [[Help.SiteSpecificMarkup]] for more on this.
    2013-02-25 17:55 [UTC-7] by Blue Hell -
    Changed line 243 from:
    An example : [[/wiki/pmwiki.php?n=Site.AllRecentChanges?action=rss&count=25 | RSS feed]] for the most recent changes
    to:
    2013-02-25 17:54 [UTC-7] by Blue Hell -
    to:
    2013-02-25 17:41 [UTC-7] by Blue Hell -
    Changed lines 247-249 from:
    [[~Blue Hell]] 2013-02-25 15:40 [UTC-7] ~ For backups see http://www.pmwiki.org/wiki/PmWiki/BackupAndRestore and http://www.pmwiki.org/wiki/Cookbook/RecentUploadsLog for a recent uploads log
    to:
    [[~Blue Hell]] 2013-02-25 15:40 [UTC-7] ~ For backups see http://www.pmwiki.org/wiki/PmWiki/BackupAndRestore and http://www.pmwiki.org/wiki/Cookbook/RecentUploadsLog for a recent uploads log - For now I'm just backing up on my home server.
    2013-02-25 17:40 [UTC-7] by Blue Hell -
    Added lines 237-239:
    Deleted line 240:
    Added lines 242-247:
    !!! Backups
    2013-02-25 15:47 [UTC-7] by Blue Hell -
    Changed line 239 from:
    [[~Blue Hell]] 2013-02-25 13:43 [UTC-7] ~ RSS is built in, but to make it work nicely it will needs some work, see http://www.pmwiki.org/wiki/PmWiki/WebFeeds for that.
    to:
    [[~Blue Hell]] 2013-02-25 13:43 [UTC-7] ~ RSS (rss,atom,dc and rdf formats) is built in, but to make it work nicely it will needs some work, see http://www.pmwiki.org/wiki/PmWiki/WebFeeds for that.
    2013-02-25 15:45 [UTC-7] by Blue Hell -
    Added line 5:
    (:num:)
    Deleted line 6:
    (:num:)
    Added lines 236-239:
    !!!RSS feeds
    Added lines 1-2:
    !!The Dreams
    Added line 5:
    (:toc:)
    Deleted line 6:
    (:notoc:)
    Deleted lines 8-10:
    !!The Dreams
    (:toc:)
    Deleted lines 235-238:
    !!!RSS feeds
    Added line 4:
    (:notoc:)
    2013-02-25 15:44 [UTC-7] by Blue Hell -
    Deleted lines 0-1:
    !!The Dreams
    Deleted line 2:
    (:toc:)
    Added lines 6-8:
    !!The Dreams
    (:toc:)
    2013-02-25 15:43 [UTC-7] by Blue Hell -
    !!!RSS feeds
    2013-02-24 18:41 [UTC-7] by Blue Hell -
    Changed line 184 from:
    !!!html5 canvas
    to:
    !!!html5 canvas - done
    2013-02-24 18:40 [UTC-7] by Blue Hell -
    Changed lines 211-212 from:
    !!!Page classification
    to:
    !!!Page classification - done
    Changed line 215 from:
    [[~Blue Hell]] 2013-02-24 09:35 [UTC-7] ~ right, this seems built in already with [=[[!subject]]=] markup: http://www.pmwiki.org/wiki/PmWiki/Categories
    to:
    [[~Blue Hell]] 2013-02-24 09:35 [UTC-7] ~ right, this {-seems-} {+is+} built in already with [=[[!subject]]=] markup: http://www.pmwiki.org/wiki/PmWiki/Categories
    2013-02-24 11:35 [UTC-7] by Blue Hell -
    Changed lines 213-215 from:
    [[~Blue Hell]] 2013-02-19 18:40 [UTC-7] ~ tagging ... that is classifying pages .. and auto indices for that ... maybe http://www.pmwiki.org/wiki/Cookbook/Tagger or something alike.
    to:
    2013-02-23 21:59 [UTC-7] by Blue Hell -
    Changed line 9 from:
    todos, dones and don'ts (un-wishes), a wish list .. I wish for a dream.
    to:
    todos, dones and don'ts (un-wishes), a wish list .. I wish for a how to dream.
    2013-02-23 21:44 [UTC-7] by Blue Hell -
    todos, dones and don'ts (un-wishes), a wish list.
    to:
    2013-02-23 21:38 [UTC-7] by Blue Hell -
    Changed line 11 from:
    Also have a look at [[Help.SiteSpecificMarkup]], the info is spread a bit over two places.
    to:
    Also have a look at [[Help.SiteSpecificMarkup | The HowTo]], the info is spread a bit over two places.
    2013-02-23 21:37 [UTC-7] by Blue Hell -
    Changed lines 1-2 from:
    !!The wish list
    to:
    !!The Dreams
    to:
    2013-02-23 21:35 [UTC-7] by Blue Hell -
    to:
    2013-02-23 21:34 [UTC-7] by Blue Hell -
    Changed line 13 from:
    Please feel free to add requested functionalty here - at the end of the page, and please use a short subject line preceded by some exclamation marks .. top level entries have three [=!!!=] nestlings, subs four [=!!!!=], etc. ... this keeps the TOC going and also it'll keep links like [[Help.Todo#ntoc13]] working (yeah I know they should have been symbolic .. still these are used in a couple of places).
    to:
    Please feel free to add requested functionalty here - at the end of the page, and please use a short subject line preceded by some exclamation marks .. top level entries have three [=!!!=] exclamation marks, subs four [=!!!!=], etc. ... this keeps the TOC going and also it'll keep links like [[Help.Todo#ntoc13]] working (yeah I know they should have been symbolic .. still these are used in a couple of places).
    Please feel free to add requested functionalty here - at the end of the page, and please use a short subject line preceded by some exclamation marks .. top level entries have 3 [=!!!=] nestlings more ... this keeps the TOC going and also it'll keep links like [[Help.Todo#ntoc13]] working (yeah I know they should have been symbolic .. still these are used in a couple of places).
    to:
    2013-02-23 21:32 [UTC-7] by Blue Hell -
    !!todos
    to:
    !!The wish list
    and dones .. actually, and don'ts!
    to:
    2013-02-23 21:25 [UTC-7] by Blue Hell -
    Please feel free to add requested functionalty here - at the end of the page, and please use a short subject line preceded by some exclamation marks .. top level entries have 3 [=!!!=] nestlings more ... this keeps the TOC going and also it'll keep links like [[Help.Todo#ntoc13]] working (these are used in a couple of places).
    to:
    2013-02-23 21:24 [UTC-7] by Blue Hell -
    Please feel free to add requested functionalty here - at the end of the page, and please use a short subject line preceded by some exclamation marks .. top level entries have 3 [=!!!=] nestlings more ... this keeps the TOC gong.
    to:
    2013-02-23 21:21 [UTC-7] by Blue Hell -
    Added lines 17-18:
    Anyways here is the dreams:
    Deleted lines 19-22:
    Added lines 16-19:
    2013-02-23 21:20 [UTC-7] by Blue Hell -
    Changed lines 13-15 from:
    to:
    The idea is to mostly have feature requests here, and a manual for working stuff [[Help.SiteSpecificMarkup | there]] as good as it goes ...
    2013-02-23 21:18 [UTC-7] by Blue Hell -
    Added lines 12-13:
    2013-02-23 13:01 [UTC-7] by Blue Hell -
    2013-02-23 11:19 [UTC-7] by Blue Hell -
    Changed line 227 from:
    to:
    NOTE: there can only be one clock element on a page.
    2013-02-23 11:15 [UTC-7] by Blue Hell -
    Added lines 194-197:
    [[~Blue Hell]] 2013-02-23 09:15 [UTC-7] ~ Seems fixed, see [[Help.SiteSpecificMarkup#ntoc19 | Site specific markup]] for details.
    Changed line 225 from:
    This uses an JavaScript file /wiki/pub/clock/clock.js that is included into the page by code in config.php, the markup builds a table that will display the clock, and then then JavaScript window.onload event is set to execute the clock startup - this code is added to the wiki footer, also in config.php.
    to:
    This uses an JavaScript file /wiki/pub/clock/clock.js that is included into the page by code in config.php, the markup builds a {-table-} paragraph that will display the clock, and then then a JavaScript window.onload event is set to execute the clock startup - this code is added to the wiki footer, also in config.php.
    2013-02-20 20:51 [UTC-7] by Blue Hell -
    Changed line 192 from:
    *[[Help.Todo#ntoc23 | item 23]]
    to:
    *[[Help.Todo#ntoc23 | todo item 23]]
    2013-02-20 20:50 [UTC-7] by Blue Hell -
    * item 23
    to:
    2013-02-20 20:49 [UTC-7] by Blue Hell -
    to:
    * item 23
    2013-02-20 20:47 [UTC-7] by Blue Hell -
    Changed lines 188-191 from:
    Also see http://electro-music.com/wiki/pmwiki.php?n=PmWiki.CustomMarkup , http://www.pmwiki.org/wiki/PmWiki/Functions and http://www.pmwiki.org/wiki/Cookbook/JavaScript-Editable?from=Cookbook.Javascript
    to:
    Also see
    *http://www.pmwiki.org/wiki/PmWiki/Functions
    *http://www.pmwiki.org/wiki/Cookbook/JavaScript-Editable?from=Cookbook.Javascript
    2013-02-20 20:46 [UTC-7] by Blue Hell -
    Changed line 188 from:
    Also see http://electro-music.com/wiki/pmwiki.php?n=PmWiki.CustomMarkup and http://www.pmwiki.org/wiki/PmWiki/Functions
    to:
    2013-02-20 20:43 [UTC-7] by Blue Hell -
    to:
    2013-02-20 20:35 [UTC-7] by Blue Hell -
    to:
    2013-02-20 19:24 [UTC-7] by Blue Hell -
    Added lines 10-11:
    2013-02-20 19:21 [UTC-7] by Blue Hell -
    Deleted lines 175-190:
    !!!Clock - with GMT / local time - done
    [[~Blue Hell]] 2013-02-20 16:49 [UTC-7] GMT / local clock support
    use
      [={_clock_}=]
    to get
    {_clock_}
    which shows your current local time as set for your computer and the current GMT (or UTC) time along with it - assuming your PC clock runs on time, and assuming you have JavaScript enabled for this page.
    Added lines 199-216:
    use
      [={_clock_}=]
    to get
    {_clock_}
    2013-02-20 18:58 [UTC-7] by Blue Hell -
    Added lines 199-200:
    [[~Blue Hell]] 2013-02-20 16:58 [UTC-7] Ported the GMT / local time clock over to the wiki, as a first JavaScript exercise.
    2013-02-20 18:56 [UTC-7] by Blue Hell -
    Changed line 176 from:
    !!!Clock
    to:
    2013-02-20 18:51 [UTC-7] by Blue Hell -
    Changed lines 183-188 from:
    to get {_clock_}
    to:
    to get
    {_clock_}
    2013-02-20 18:49 [UTC-7] by Blue Hell -
    !!Clock
    to:
    !!!Clock
    Added lines 173-183:
    !!Clock
    use
      [={_clock_}=]
    to get {_clock_}
    2013-02-19 21:24 [UTC-7] by Blue Hell -
    Changed line 55 from:
    !!Donate page - done
    to:
    !!!Donate page - done
    2013-02-19 21:23 [UTC-7] by Blue Hell -
    Changed lines 1-4 from:
    !todos
    to:
    !!todos
    Changed lines 9-13 from:
    !!Colors
    - done
    to:
    !!Colors - done
    Changed lines 23-24 from:
    !!Inlined audio - done
    to:
    !!!Inlined audio - done
    Changed lines 32-33 from:
    !!Inlined video - done
    to:
    !!!Inlined video - done
    Changed lines 41-42 from:
    !!Import forum posts
    to:
    !!!Import forum posts
    Changed lines 48-49 from:
    !!Import forum avatars
    to:
    !!!Import forum avatars
    Changed lines 64-65 from:
    !!Forum colors - done
    to:
    !!!Forum colors - done
    Changed lines 73-74 from:
    !!Photo gallery - done
    to:
    !!!Photo gallery - done
    Changed lines 84-85 from:
    !!Runtime warnings - done
    to:
    !!!Runtime warnings - done
    Changed lines 93-94 from:
    !!More runtime warnings - done
    to:
    !!!More runtime warnings - done
    Changed lines 102-103 from:
    !!Google being overactive - done
    to:
    !!!Google being overactive - done
    Changed lines 113-114 from:
    !!Random pages - done
    to:
    !!!Random pages - done
    Changed lines 122-123 from:
    !!Even more warnings - done
    to:
    !!!Even more warnings - done
    Changed lines 133-134 from:
    !!Wiki opened up - done
    to:
    !!!Wiki opened up - done
    Changed lines 138-139 from:
    !!Talk pages - done
    to:
    !!!Talk pages - done
    Changed lines 147-148 from:
    !!A fuck up - done
    to:
    !!!A fuck up - done
    Changed lines 154-155 from:
    to:
    Changed lines 161-162 from:
    !!Blocklists - done
    to:
    !!!Blocklists - done
    Changed lines 170-171 from:
    !!MOTD
    to:
    !!!MOTD
    Changed lines 176-177 from:
    !!html5 canvas
    to:
    !!!html5 canvas
    Changed lines 187-188 from:
    !!Formulas
    to:
    !!!Formulas
    Changed line 194 from:
    to:
    2013-02-19 21:19 [UTC-7] by Blue Hell -
    Changed lines 14-15 from:
    !!Colors
    to:
    !!Colors - done
    !!Inlined audio
    to:
    !!Inlined video
    to:
    Changed lines 55-56 from:
    !!Donate page
    to:
    !!Forum colors
    to:
    !!Photo gallery
    to:
    !!Runtime warnings
    to:
    to:
    to:
    !!Random pages
    to:
    to:
    Changed lines 128-132 from:
    !!Wiki opened
    up
    to:
    [[~Blue Hell]] 2013-02-19 19:19 [UTC-7] Probably the code will just need a handful more @ warning killers.
    !!Wiki opened
    up - done
    !!Talk pages
    to:
    !!Talk pages - done
    !!A fuck up
    to:
    !!A fuck up - done
    Changed line 161 from:
    !!Blocklists
    to:
    !!Blocklists - done
    2013-02-19 21:15 [UTC-7] by Blue Hell -
    Added lines 12-13:
    Added line 15:
    Added lines 21-22:
    Added line 24:
    Added lines 30-31:
    Added line 33:
    Added lines 39-40:
    Added line 42:
    Added lines 45-47:
    Added line 49:
    Added lines 53-54:
    Added line 56:
    Added lines 61-63:
    Added line 65:
    Added lines 71-72:
    Added line 74:
    Added lines 82-83:
    Added line 85:
    Added lines 91-92:
    Added line 94:
    Added lines 100-101:
    Added line 103:
    Added lines 111-112:
    Added line 114:
    Added lines 120-121:
    Changed lines 129-145 from:
    # wiki opened up - [[~Blue Hell]] 2013-02-16 14:22 [UTC-7] opened up the wiki to be editable by all forum members, members of the forum's WikiAdmin group can now use the '''?action=attr''' links (so they can set passwords and stuff); the admin stuff proper is still left to forum admins only.
    # talk pages - [[~Blue Hell]] 2013-02-16 17:03 [UTC-7] ~ {-look into automatic talk page link management.-}<br><br>[[~Blue Hell]] 2013-02-16 17:58 [UTC-7] added it to the page  menu as a Discuss link.
    # a fuck up - [[~Blue Hell]] 2013-02-17 14:52 [UTC-7] ~ had managed to fuck up the calendar and the new toc thingie .. seems ok again now.
    # brackets in user names - [[~Blue Hell]] 2013-02-17 16:22 [UTC-7] ~ Forum user names with brackets ("[" and/or "]") in them are not properly handled by the standard [=[[~user name]]=] markup, this also means that the tilde expansions do not work properly on such names.
    # blocklists - [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ {-the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed.-}<br><br>[[~Blue Hell]] 2013-02-17 19:46 [UTC-7] ~ seems to work now .. see [[SiteAdmin.Blocklist]] - needs some cleanup and a check to see if it is not user editable ... the word **extremely_very_dirty word_that_really_needs_to_be_blocked** can not be entered now ... not without the space anyway.
    # MOTD - [[~Blue Hell]] 2013-02-17 20:50 [UTC-7] ~ Something MOTD like ... or get that from the forum. The forum markup around MOTD things would not make much sense here.
    # html5 canvas - [[~Blue Hell]] 2013-02-19 14:38 [UTC-7] ~ html5 canvas support? see; http://www.pmwiki.org/wiki/Cookbook/HTML5Extensions - this has some security implications for clients ... also the recipe would define a canvas, but I don't see how it would be controlled without allowing general JavaScript ... and I'm not sure I'd want that ... maybe for WikiAdmins only ... if such protection could be set. <br><br>Group membership can be checked, added some stuff to config.php to do it [[Help.SiteSpecificMarkup  | easier]], and added [[Help.Memberships | this page]] to help sort out membership issues.<br><br>So in PHP code user's rights can be checked to decide upon inclusion of certain features ... like inclusion of html and javascript in markup. Will also need some html headers to be changed/changeable to allow for some .js file inclusions.
    # formulas - [[~Blue Hell]] 2013-02-19 17:57 [UTC-7] ~ Formulas ... see http://www.pmwiki.org/wiki/Cookbook/Formula
    # page classification - [[~Blue Hell]] 2013-02-19 18:40 [UTC-7] ~ tagging ... that is classifying pages .. and auto indices for that ... maybe http://www.pmwiki.org/wiki/Cookbook/Tagger or something alike.
    to:
    !!Wiki opened up
    !!Talk pages
    [[~Blue Hell]] 2013-02-16 17:03 [UTC-7] ~ look into automatic talk page link management.
    !!A fuck up
    !!Blocklists
    [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed.
    !!MOTD
    !!html5 canvas
    !!Formulas
    2013-02-19 21:09 [UTC-7] by Blue Hell -
    Changed lines 62-68 from:
    # more runtime warnings - [[~Blue Hell]] 2013-02-04 ~ {-on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save-}<br><br>[[~Blue Hell]] 2013-02-05 18:29 [UTC-7] Solved, some other warnings and notices killed too, grep source code for blue_hell.
    # google overactive - [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] ~ {-see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this needs a fix.-}<br><br>I've added Disallow: /wiki/pmwikiki.php?n=*?logdate=*$ to /home/mosc/electro-music.com/html/robots.txt - let's see if that works ... [[~Blue Hell]] 2013-02-11 13:02 [UTC-7]<br><br>Also see [[http://support.google.com/webmasters/bin/answer.py?hl=en&answer=76401]] .. ok made some changes to wikilog.php to get in a couple of rel='nofollow' thingies.<br><br>[[~Blue Hell]] 2013-02-12 15:09 [UTC-7] seems to work mow.
    # random pages - [[~Blue Hell]] 2013-02-14 18:20 [UTC-7] ~ {-fix the random page thingie in that it shows the actual page instead of Site / Random Page-}<br><br>[[~Blue Hell]] 2013-02-16 16:24 [UTC-7] fixed by installing the power tools' plist and random thingies.
    # even more warnings - [[~Blue Hell]] 2013-02-15 14:15 [UTC-7] ~ {-page history was generating warnings from pagerev.php.-}<br><br>[[~Blue Hell]] 2013-02-15 14:15 [UTC-7] Fixed now, had to change the code a bit.
    to:
    [[~Blue Hell]] 2013-02-04 ~ on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save
    [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] ~ see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this needs a fix.
    Also
    !!Random pages
    [[~Blue Hell]] 2013-02-14 18:20 [UTC-7] ~ fix the random page thingie in that it shows the actual page instead of Site / Random Page
    [[~Blue Hell]] 2013
    -02-15 14:15 [UTC-7] ~ page history was generating warnings from pagerev.php.
    2013-02-19 21:05 [UTC-7] by Blue Hell -
    Added line 17:
    Deleted line 18:
    Changed lines 23-35 from:
    # inlined video - [[~Blue Hell]] 2013-02-02 ~{-support for inline video ... some sort of a player thing - maybe html5 will be good enough-}<br><br>done 2013-02-03 [[~Blue Hell]]
    # import forum posts - [[~Blue Hell]] 2013-02-02 ~ a tool to import forum posts
    # import forum avatars - [[~Blue Hell]] 2013-02-02 ~ a tool to import avatar images from the forum
    # donate page - [[~Blue Hell]] 2013-02-02 ~ {-finish the donate [[http://electro-music.com/wiki/pmwiki.php?n=Main.Donate | thingie]]-}<br><br>done 2013-02-04 [[~Blue Hell]]
    # forum colors - [[~Blue Hell]] 2013-02-02 ~ {-Get the colors to better match the forum style-} :: done 2013-02-02 [[~Blue Hell]]
    # photo gallery - [[~Blue Hell]] 2013-02-03 ~ {-get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 [[~Blue Hell]] working on a manual thing now ... didn't like the cookbook stuff yet see [[Albums.Albums | Albums]] - all the images are in now, index work to do and captions ...-}<br><br>[[~Blue Hell]] 2013-02-10 17:28 [UTC-7] done for now.
    # runtime warnings - [[~Blue Hell]] 2013-02-04 ~ {-on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187-}<br><br>[[~Blue Hell]] 2013-02-05 18:29 [UTC-7] solved, see next item.
    to:
    !!Inlined video
    [[~Blue Hell]] 2013-02-02 ~ support for inline video ... some sort of a player thing - maybe html5 will be good enough
    !!Donate page
    [[~Blue Hell]] 2013-02-02 ~ finish the donate [[http://electro-music.com/wiki/pmwiki.php?n=Main.Donate | thingie]]
    !!Forum colors
    [[~Blue Hell]] 2013-02-02 ~ Get the colors to better match the forum style
    !!Photo gallery
    [[~Blue Hell]] 2013-02-03 ~ get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList
    !!Runtime warnings
    [[~Blue Hell]] 2013-02-04 ~ on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187
    2013-02-19 21:01 [UTC-7] by Blue Hell -
    Deleted line 12:
    Changed lines 1-3 from:
    !todos and dones .. actually, and don'ts!
    to:
    !todos
    2013-02-19 21:00 [UTC-7] by Blue Hell -
    Added lines 1-2:
    Deleted lines 8-9:
    Added lines 1-7:
    !!Contents
    (:toc:)
    (:num:)
    (:indent:)
    Changed lines 10-12 from:
    # colors - [[~Blue Hell]] 2013-02-02 ~ {-try add support for color electroblue-}<br><br>done 2013-02-02 [[~Blue Hell]]
    # inlined audio - [[~Blue Hell]] 2013-02-02 ~ {-support for inlined audio ... some sort of a player thing - maybe html5 will be good enough-}<br><br>done 2013-02-02 [[~Blue Hell]]
    to:
    !!Colors
    [[~Blue Hell]] 2013
    -02-02 ~ try add support for color electroblue
    done 2013
    !!Inlined audio
    [[~Blue Hell]] 2013
    -02-02 ~ support for inlined audio ... some sort of a player thing - maybe html5 will be good enough
    2013-02-19 20:57 [UTC-7] by Blue Hell -
    Changed lines 3-45 from:
    # [[~Blue Hell]] 2013-02-02 ~{-try add support for color electroblue-}<br><br>done 2013-02-02 [[~Blue Hell]]
    # [[~Blue Hell]] 2013-02-02 ~ {-support for inlined audio ... some sort of a player thing - maybe html5 will be good enough-}<br><br>done 2013-02-02 [[~Blue Hell]]
    # [[~Blue Hell]] 2013-02-02 ~{-support for inline video ... some sort of a player thing - maybe html5 will be good enough-}<br><br>done 2013-02-03 [[~Blue Hell]]
    # [[~Blue Hell]] 2013-02-02 ~ a tool to import forum posts
    # [[~Blue Hell]] 2013-02-02 ~ a tool to import avatar images from the forum
    # [[~Blue Hell]] 2013-02-02 ~ {-finish the donate [[http://electro-music.com/wiki/pmwiki.php?n=Main.Donate | thingie]]-}<br><br>done 2013-02-04 [[~Blue Hell]]
    # [[~Blue Hell]] 2013-02-02 ~ {-Get the colors to better match the forum style-} :: done 2013-02-02 [[~Blue Hell]]
    # [[~Blue Hell]] 2013-02-03 ~ {-get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 [[~Blue Hell]] working on a manual thing now ... didn't like the cookbook stuff yet see [[Albums.Albums | Albums]] - all the images are in now, index work to do and captions ...-}<br><br>[[~Blue Hell]] 2013-02-10 17:28 [UTC-7] done for now.
    # [[~Blue Hell]] 2013-02-04 ~ {-on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187-}<br><br>[[~Blue Hell]] 2013-02-05 18:29 [UTC-7] solved, see next item.
    # [[~Blue Hell]] 2013-02-04 ~ {-on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save-}<br><br>[[~Blue Hell]] 2013-02-05 18:29 [UTC-7] Solved, some other warnings and notices killed too, grep source code for blue_hell.
    # [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] ~ {-see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this needs a fix.-}<br><br>I've added Disallow: /wiki/pmwikiki.php?n=*?logdate=*$ to /home/mosc/electro-music.com/html/robots.txt - let's see if that works ... [[~Blue Hell]] 2013-02-11 13:02 [UTC-7]<br><br>Also see [[http://support.google.com/webmasters/bin/answer.py?hl=en&answer=76401]] .. ok made some changes to wikilog.php to get in a couple of rel='nofollow' thingies.<br><br>[[~Blue Hell]] 2013-02-12 15:09 [UTC-7] seems to work mow.
    # [[~Blue Hell]] 2013-02-14 18:20 [UTC-7] ~ {-fix the random page thingie in that it shows the actual page instead of Site / Random Page-}<br><br>[[~Blue Hell]] 2013-02-16 16:24 [UTC-7] fixed by installing the power tools' plist and random thingies.
    # [[~Blue Hell]] 2013-02-15 14:15 [UTC-7] ~ {-page history was generating warnings from pagerev.php.-}<br><br>[[~Blue Hell]] 2013-02-15 14:15 [UTC-7] Fixed now, had to change the code a bit.
    # [[~Blue Hell]] 2013-02-16 14:22 [UTC-7] opened up the wiki to be editable by all forum members, members of the forum's WikiAdmin group can now use the '''?action=attr''' links (so they can set passwords and stuff); the admin stuff proper is still left to forum admins only.
    # [[~Blue Hell]] 2013-02-16 17:03 [UTC-7] ~ {-look into automatic talk page link management.-}<br><br>[[~Blue Hell]] 2013-02-16 17:58 [UTC-7] added it to the page  menu as a Discuss link.
    # [[~Blue Hell]] 2013-02-17 14:52 [UTC-7] ~ had managed to fuck up the calendar and the new toc thingie .. seems ok again now.
    # [[~Blue Hell]] 2013-02-17 16:22 [UTC-7] ~ Forum
    # [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ {-the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the
    # [[~Blue Hell]] 2013-02-17 20:50 [UTC-7] ~ Something MOTD like
    # [[~Blue Hell]] 2013-02-19 14:38 [UTC-7] ~ html5 canvas support? see; http://www.pmwiki.org/wiki/Cookbook/HTML5Extensions - this has some security implications for clients ... also the recipe would define a canvas, but I don't see how it would be controlled without allowing general JavaScript ... and I'm not sure I'd want that ... maybe for WikiAdmins only ... if such protection could be set. <br><br>Group membership can be checked, added some stuff to config.php to do it [[Help.SiteSpecificMarkup  | easier]], and added [[Help.Memberships | this page]] to help sort out membership issues.<br><br>So in PHP code user's rights can be checked to decide upon inclusion of certain features ... like inclusion of html and javascript in markup. Will also need some html headers to be changed/changeable to allow for some .js file inclusions.
    # [[~Blue Hell]] 2013-02-19 17:57 [UTC-7] ~ Formulas ... see http://www
    to:
    # brackets in
    2013-02-19 20:48 [UTC-7] by Blue Hell -
    Changed line 41 from:
    # [[~Blue Hell]] 2013-02-19 14:38 [UTC-7] ~ html5 canvas support? see; http://www.pmwiki.org/wiki/Cookbook/HTML5Extensions - this has some security implications for clients ... also the recipe would define a canvas, but I don't see how it would be controlled without allowing general JavaScript ... and I'm not sure I'd want that ... maybe for WikiAdmins only ... if such protection could be set. <br><br>Group membership can be checked, added some stuff to config.php to do it easier, and added [[Help.Memberships | this page]] to help sort out membership issues.<br><br>So in PHP code user's rights can be checked to decide upon inclusion of certain features ... like inclusion of html and javascript in markup. Will also need some html headers to be changed/changeable to allow for some .js file inclusions.
    to:
    2013-02-19 20:40 [UTC-7] by Blue Hell -
    Added line 45:
    # [[~Blue Hell]] 2013-02-19 18:40 [UTC-7] ~ tagging ... that is classifying pages .. and auto indices for that ... maybe http://www.pmwiki.org/wiki/Cookbook/Tagger or something alike.
    2013-02-19 19:57 [UTC-7] by Blue Hell -
    Added lines 42-43:
    # [[~Blue Hell]] 2013-02-19 17:57 [UTC-7] ~ Formulas ... see http://www.pmwiki.org/wiki/Cookbook/Formula
    2013-02-19 18:58 [UTC-7] by Blue Hell -
    Changed line 23 from:
    # [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] ~ {-see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this needs a fix.-}<br><br>I've added Disallow: /wiki/pmwikiki.php?n=*?logdate=*$ to /home/mosc/electro-music.com/html/robots.txt - let's see if that works ... [[~Blue Hell]] 2013-02-11 13:02 [UTC-7] :: also see [[http://support.google.com/webmasters/bin/answer.py?hl=en&answer=76401]] .. ok made some changes to wikilog.php to get in a couple of rel='nofollow' thingies.<br><br>[[~Blue Hell]] 2013-02-12 15:09 [UTC-7] seems to work mow.
    to:
    2013-02-19 18:57 [UTC-7] by Blue Hell -
    Changed lines 17-18 from:
    # [[~Blue Hell]] 2013-02-03 ~ {-get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 [[~Blue Hell]] working on a manual thing now ... didnt like the cookbook stuff yet see [[Albums.Albums | Albums]] - all the images are in now, index work to do and captions ...-}<br><br>[[~Blue Hell]] 2013-02-10 17:28 [UTC-7] done for now.
    to:
    # [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] ~ {-see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this needs a fix. I've added Disallow: /wiki/pmwikiki.php?n=*?logdate=*$ to /home/mosc/electro-music.com/html/robots.txt - let's see if that works ... [[~Blue Hell]] 2013-02-11 13:02 [UTC-7] :: also see [[http://support.google.com/webmasters/bin/answer.py?hl=en&answer=76401]] .. ok made some changes to wikilog.php to get in a couple of rel='nofollow' thingies.-}<br><br>[[~Blue Hell]] 2013-02-12 15:09 [UTC-7] seems to work mow.
    to:
    2013-02-19 18:55 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-04 ~{-try add support for color electroblue-}<br><br>done 2013-02-02 [[~Blue Hell]]
    # [[~Blue Hell]] 2013-02-02 ~ {-support for inlined audio ... some sort of a player thing - maybe html5 will be good enough-}<br><br>done 2013-02-04 [[~Blue Hell]]
    to:
    2013-02-19 18:54 [UTC-7] by Blue Hell -
    Changed line 5 from:
    to:
    Changed line 7 from:
    # [[~Blue Hell]] 2013-02-02 ~{-support for inline video ... some sort of a player thing - maybe html5 will be good enough-}<br><br>2013-02-03 [[~Blue Hell]]
    to:
    2013-02-19 18:51 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-19 14:38 [UTC-7] ~ html5 canvas support? see; http://www.pmwiki.org/wiki/Cookbook/HTML5Extensions - this has some security implications for clients ... also the recipe would define a canvas, but I don't see how it would be controlled without allowing general JavaScript ... and I'm not sure I'd want that ... maybe for WikiAdmins only ... if such protection could be set. <br><br>Group membership can be checked, added some stuff config.php to do it easier, and added [[Help.Memberships | this page]] to help sort out membership issues.<br><br>So in PHP code user's rights can be checked to decide upon inclusion of certain features ... like inclusion of html and javascript in markup. Will also need some html headers to be changed/changeable to allow for some .js file inclusions.
    to:
    2013-02-19 18:49 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-19 14:38 [UTC-7] ~ html5 canvas support? see; http://www.pmwiki.org/wiki/Cookbook/HTML5Extensions - this has some security implications for clients ... also the recipe would define a canvas, but I don't see how it would be controlled without allowing general JavaScript ... and I'm not sure I'd want that ... maybe for WikiAdmins only ... if such protection could be set. <br><br>Ok, group membership can be checked, added some stuff config.php to do it, and added [[Help.Memberships | this page]] to help sort out membership issues.<br>So in PHP code user's rights can be checked to decide upon inclusion of certain features ... like inclusion of html and javascript in markup. Will also need some html headers to be changed/changeable to allow for some .js file inclusions.
    to:
    2013-02-19 18:48 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-19 14:38 [UTC-7] ~ html5 canvas support? see; http://www.pmwiki.org/wiki/Cookbook/HTML5Extensions - this has some security implications for clients ... also the recipe would define a canvas, but I don't see how it would be controlled without allowing general JavaScript ... and I'm not sure I'd want that ... maybe for WikiAdmins only ... if such protection could be set. <br><br>Ok, group membership can be checked, added some stuff config.php to do it, and added [[Help.Memberships | this page]] to help sort out membership issues. So .. in PHP code I check a user's rights to decide upon inclusion of certain features ... like include html and javascript in markup. Will also need some html headers to be changed/changeable to allow for some .js file inclusions.
    to:
    2013-02-19 18:46 [UTC-7] by Blue Hell -
    Changed line 39 from:
    # [[~Blue Hell]] 2013-02-17 20:50 [UTC-7] ~ Something MOTD like ... or get that from the forum.
    to:
    # [[~Blue Hell]] 2013-02-17 20:50 [UTC-7] ~ Something MOTD like ... or get that from the forum. The forum markup around MOTD things would not make much sense here.
    2013-02-19 18:44 [UTC-7] by Blue Hell -
    Changed lines 3-8 from:
    # [[~Blue Hell]] 2013-02-04 ~{-try add support for color electroblue-} :: done 2013-02-02 [[~Blue Hell]]
    # [[~Blue Hell]] 2013-02-02 ~ {-support for inlined audio ... some sort of a player thing - maybe html5 will be good enough-} :: done 2013-02-04
    # [[~Blue Hell]] 2013-02-02 ~{-support for inline video ... some sort of a player thing - maybe html5 will be good enough-} :: done 2013-02-03 [[~Blue Hell]]
    to:
    Changed lines 13-14 from:
    # [[~Blue Hell]] 2013-02-02 ~ {-finish the donate [[http://electro-music.com/wiki/pmwiki.php?n=Main.Donate | thingie]]-} :: done 2013-02-04 [[~Blue Hell]]
    to:
    Changed lines 17-28 from:
    # [[~Blue Hell]] 2013-02-03 ~ {-get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 [[~Blue Hell]] working on a manual thing now ... didnt like the cookbook stuff yet see [[Albums.Albums | Albums]] - all the images are in now, index work to do and captions ...-} :: [[~Blue Hell]] 2013-02-10 17:28 [UTC-7] done for now.
    -02-04 ~ {-on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187-} :: [[~Blue Hell]] 2013-02-05 18:29 [UTC-7] solved, see next item.
    # [[~Blue Hell]] 2013-02-04 ~ {-on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save-} :: [[~Blue Hell]] 2013-02-05 18:29 [UTC-7] Solved, some other warnings and notices killed too, grep source code for blue_hell.
    # [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] ~ {-see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this needs a fix. I've added Disallow: /wiki/pmwikiki.php?n=*?logdate=*$ to /home/mosc/electro-music.com/html/robots.txt - let's see if that works ... [[~Blue Hell]] 2013-02-11 13:02 [UTC-7] :: also see [[http://support.google.com/webmasters/bin/answer.py?hl=en&answer=76401]] .. ok made some changes to wikilog.php to get in a couple of rel='nofollow' thingies.-} [[~Blue Hell]] 2013-02-12 15:09 [UTC-7] seems to work mow.
    # [[~Blue Hell]] 2013-02-14 18:20 [UTC-7] ~ {-fix the random page thingie in that it shows the actual page instead of Site / Random Page-} [[~Blue Hell]] 2013-02-16 16:24 [UTC-7] fixed by installing the power tools' plist and random thingies.
    # [[~Blue Hell]] 2013-02-15 14:15 [UTC-7] ~ {-page history was generating warnings from pagerev.php.-} [[~Blue Hell]] 2013-02-15 14:15 [UTC-7] Fixed now, had to change the code a bit.
    to:
    Changed lines 31-32 from:
    # [[~Blue Hell]] 2013-02-16 17:03 [UTC-7] ~ {-look into automatic talk page link management.-} [[~Blue Hell]] 2013-02-16 17:58 [UTC-7] added it to the page  menu as a Discuss link.
    to:
    Changed line 37 from:
    # [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ {-the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed.-} [[~Blue Hell]] 2013-02-17 19:46 [UTC-7] ~ seems to work now .. see [[SiteAdmin.Blocklist]] - needs some cleanup and a check to see if it is not user editable ... the word **extremely_very_dirty word_that_really_needs_to_be_blocked** can not be entered now ... not without the space anyway.
    to:
    # [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ {-the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed.-}<br><br>[[~Blue Hell]] 2013-02-17 19:46 [UTC-7] ~ seems to work now .. see [[SiteAdmin.Blocklist]] - needs some cleanup and a check to see if it is not user editable ... the word **extremely_very_dirty word_that_really_needs_to_be_blocked** can not be entered now ... not without the space anyway.
    2013-02-19 18:40 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-19 14:38 [UTC-7] ~ html5 canvas support? see; http://www.pmwiki.org/wiki/Cookbook/HTML5Extensions - this has some security implications for clients ... also the recipe would define a canvas, but I don't see how it would be controlled without allowing general JavaScript ... and I'm not sure I'd want that ... maybe for WikiAdmins only ... if such protection could be set. Ok, group membership can be checked, added some stuff config.php to do it, and added [[Help.Memberships | this page]] to help sort out membership issues. So .. in PHP code I check a user's rights to decide upon inclusion of certain features ... like include html and javascript in markup. Will also need some html headers to be changed/changeable to allow for some .js file inclusions.
    to:
    2013-02-19 18:39 [UTC-7] by Blue Hell -
    Changed line 1 from:
    to:
    2013-02-19 18:38 [UTC-7] by Blue Hell -
    to:
    2013-02-19 16:49 [UTC-7] by Blue Hell -
    to:
    2013-02-19 16:46 [UTC-7] by Blue Hell -
    to:
    2013-02-19 16:38 [UTC-7] by Blue Hell -
    Added line 41:
    2013-02-17 22:50 [UTC-7] by Blue Hell -
    Changed lines 37-40 from:
    to:
    2013-02-17 22:47 [UTC-7] by Blue Hell -
    2013-02-17 22:04 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ {-the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed.-} [[~Blue Hell]] 2013-02-17 19:46 [UTC-7] ~ seems to work now .. see [[SiteAdmin.Blocklist]] - needs some cleanup and a check to see if it is not user editable ... the word **extremely_very_dirty word_that_really_needs_to_be_blocked** can not be entered now ... not without space anyway.
    to:
    2013-02-17 22:02 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ {-the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed.-} [[~Blue Hell]] 2013-02-17 19:46 [UTC-7] ~ seems to work now .. see [[SiteAdmin.Blocklist]] - needs some cleanup and a check to see if it is not user editable ... the word extremely_very_dirty word_that_really_needs_to_be_blocked can not be entered now ... not without space anyway.
    to:
    2013-02-17 22:01 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ {-the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed.-} [[~Blue Hell]] 2013-02-17 19:46 [UTC-7] ~ seems to work now .. see [[SiteAdmin.Blocklist]] - needs some cleanup and a check to see if it is not user editable ... the word x a n a x can not be entered now ... not without spaces anyway.
    to:
    2013-02-17 21:49 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed. [[~Blue Hell]] 2013-02-17 19:46 [UTC-7] ~ seems to work .. see [[SiteAdmin.Blocklist]] - needs some cleanup and a check to see if it is not user editable ... the word x a n a x can not be entered now ... not without spaces anyway.
    to:
    2013-02-17 21:48 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed. [[~Blue Hell]] 2013-02-17 19:46 [UTC-7] ~ seems to work .. see [[SiteAdmin.Blocklist]] - needs some cleanup and a check to see if it is not user editable.
    to:
    2013-02-17 21:47 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-17 18:24 [UTC-7] ~ the blocklist stuff does not work, one blocklist server times out, the other does not exists; for now I removed the blocklist stuff, added a new one in siteadmin ... will have to figure out the syntax for it .. so it can be done manually if needed. [[~Blue Hell]] 2013-02-17 19:46 [UTC-7] ~ seems to work .. see [[SiteAdmin.BlockList]] - needs some cleanup and a check to see if it is not user editable.
    to:
    2013-02-17 21:46 [UTC-7] by Blue Hell -
    to:
    2013-02-17 21:44 [UTC-7] by Blue Hell -
    2013-02-17 20:24 [UTC-7] by Blue Hell -
    Added line 37:
    2013-02-17 18:22 [UTC-7] by Blue Hell -
    Added lines 34-35:
    # [[~Blue Hell]] 2013-02-17 16:22 [UTC-7] ~ Forum user names with brackets ("[" and/or "]") in them are not properly handled by the standard [=[[~user name]]=] markup, this also means that the tilde expansions do not work properly on such names.
    2013-02-17 16:53 [UTC-7] by Blue Hell -
    Changed line 29 from:
    # [[~Blue Hell]] 2013-02-16 14:22 [UTC-7] opened up the wiki to be editable by all forum members, members of the forum's WikiAdmin group can now use the '''?attr''' links (so they can set passwords and stuff); the admin stuff proper is still left to forum admins only.
    to:
    2013-02-17 16:52 [UTC-7] by Blue Hell -
    Added lines 32-33:
    2013-02-16 19:58 [UTC-7] by Blue Hell -
    Changed line 31 from:
    # [[~Blue Hell]] 2013-02-16 17:03 [UTC-7] ~ look into automatic talk page link management.
    to:
    2013-02-16 19:08 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-16 14:22 [UTC-7] opened up the wiki to be editable by all forum members, members of the wiki admin group can now use the '''?attr''' links (so they can set passwords and stuff); the admin stuff proper is still left to admins only.
    to:
    2013-02-16 19:06 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-16 14:22 [UTC-7] opened up the wiki to be editable by all forum members, members of the wiki admin group can now use the '''?attr''' links; the admin stuff proper is still left to admins only.
    to:
    2013-02-16 19:05 [UTC-7] by Blue Hell -
    Deleted lines 2-3:
    Added lines 29-30:
    Added line 32:
    2013-02-16 19:03 [UTC-7] by Blue Hell -
    Added lines 30-31:
    2013-02-16 18:24 [UTC-7] by Blue Hell -
    Changed line 27 from:
    # [[~Blue Hell]] 2013-02-14 18:20 [UTC-7] ~ fix the random page thingie in that it shows the actual page instead of Site / Random Page
    to:
    2013-02-16 16:23 [UTC-7] by Blue Hell -
    [[~Blue Hell]] 2013-02-16 14:22 [UTC-7] opened up the wiki to be editable by all forum members, members of the wiki admin group can now use the ?attr links; the admin stuff proper is still left to admins only.
    to:
    2013-02-16 16:22 [UTC-7] by Blue Hell -
    Added lines 1-4:
    2013-02-15 16:16 [UTC-7] by Blue Hell -
    Changed line 25 from:
    # [[~Blue Hell]] 2013-02-15 14:15 [UTC-7] ~ page history was generating warnings from pagerev.php. [[~Blue Hell]] 2013-02-15 14:15 [UTC-7] Fixed now, had to change the code a bit.
    to:
    2013-02-15 16:15 [UTC-7] by Blue Hell -
    Changed lines 23-25 from:
    to:
    2013-02-14 20:21 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-14 18:20 [UTC-7] ~ fix the random page thingie in that it shows the actual page instead of Site / RandomPge
    to:
    2013-02-14 20:20 [UTC-7] by Blue Hell -
    Added lines 22-23:
    2013-02-13 19:23 [UTC-7] by Blue Hell - we should summarize more ;-)
    2013-02-13 19:09 [UTC-7] by Blue Hell - we should use summaries more ;-)
    2013-02-12 17:09 [UTC-7] by Blue Hell -
    Changed line 21 from:
    # [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] ~ see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this needs a fix. I've added Disallow: /wiki/pmwikiki.php?n=*?logdate=*$ to /home/mosc/electro-music.com/html/robots.txt - let's see if that works ... [[~Blue Hell]] 2013-02-11 13:02 [UTC-7] :: also see [[http://support.google.com/webmasters/bin/answer.py?hl=en&answer=76401]] .. ok made some changes to wikilog.php to get in a couple of rel='nofollow' thingies.
    to:
    2013-02-11 16:07 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] ~ see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this may need a fix. I've added Disallow: /wiki/pmwikiki.php?n=*?logdate=*$ to /home/mosc/electro-music.com/html/robots.txt - let's see if that works ... [[~Blue Hell]] 2013-02-11 13:02 [UTC-7] :: also see [[http://support.google.com/webmasters/bin/answer.py?hl=en&answer=76401]] .. ok made some changes to wikilog.php to get in a couple of rel='nofollow' thingies.
    to:
    2013-02-11 16:06 [UTC-7] by Blue Hell -
    to:
    2013-02-11 15:10 [UTC-7] by Blue Hell -
    to:
    2013-02-11 15:03 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] ~ see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this may need a fix. I've added Disallow: /wiki/pmwikiki.php?n=*?logdate=*$ to robots.txt - let's see if that works ... [[~Blue Hell]] 2013-02-11 13:02 [UTC-7]
    to:
    2013-02-11 15:02 [UTC-7] by Blue Hell -
    to:
    2013-02-10 19:29 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] see [[Calendar.20130204]] ... googlebot is googolplexed a bit .. this may need a fix.
    to:
    Changed line 15 from:
    # [[~Blue Hell]] 2013-02-03 ~ {-get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 [[~Blue Hell]] working on a manual thing now ... didnt like the cookbook stuff yet see [[Albums.Albums | Albums]] - all the images are in now, index work to do and captions ...-) :: [[~Blue Hell]] 2013-02-10 17:28 [UTC-7] done for now.
    to:
    2013-02-10 19:28 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-03 ~ get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 [[~Blue Hell]] working on a manual thing now ... didnt like the cookbook stuff yet see [[Albums.Albums | Albums]] - all the images are in now, index work to do and captions ...
    to:
    2013-02-10 19:27 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-10 17:23 [UTC-7] see [[Calendar.20130204]] ... googlebot is googlolplexed a bit .. this may need a fix.
    to:
    2013-02-10 19:23 [UTC-7] by Blue Hell -
    to:
    2013-02-05 20:29 [UTC-7] by Blue Hell -
    Changed lines 17-19 from:
    # [[~Blue Hell]] 2013-02-04 ~ {-on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187-} :: 2013-02-06 [[~Blue Hell]] - this one was solved
    ~ {-on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save-} :: 2013-02-06 [[~Blue Hell]] Solved, some other warnings and notices killed too, grep source code for blue_hell.
    to:
    # [[~Blue Hell]] 2013-02-04 ~ {-on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187-} :: [[~Blue Hell]] 2013-02-05 18:29 [UTC-7] solved, see next item.
    2013-02-05 20:28 [UTC-7] by Blue Hell -
    Added line 2:
    Added line 4:
    Added line 6:
    Added line 8:
    Added line 10:
    Added line 12:
    Added line 14:
    Added line 16:
    Added line 18:
    2013-02-05 20:27 [UTC-7] by Blue Hell -
    # [[~Blue Hell]] 2013-02-04 -< ~ {-on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187-} :: 2013-02-06 [[~Blue Hell]] - this one was solved
    to:
    to:
    2013-02-05 20:26 [UTC-7] by Blue Hell -
    Changed line 2 from:
    # [[~Blue Hell]] 2013-02-02 {-support for inlined audio ... some sort of a player thing - maybe html5 will be good enough-} :: done 2013-02-04
    to:
    Changed lines 5-6 from:
    # [[~Blue Hell]] 2013-02-02 a tool to import avatar images from the forum
    # [[~Blue Hell]] 2013-02-02 {-finish the donate [[http://electro-music.com/wiki/pmwiki.php?n=Main.Donate | thingie]]-} :: done 2013-02-04 [[~Blue Hell]]
    to:
    2013-02-05 20:25 [UTC-7] by Blue Hell -
    Changed lines 3-5 from:
    # [[~Blue Hell]] 2013-02-02 [[~Blue Hell]] {-support for inline video ... some sort of a player thing - maybe html5 will be good enough-} :: done 2013-02-03 [[~Blue Hell]]
    # [[~Blue Hell]] 2013-02-02 a tool to import forum posts
    to:
    # [[~Blue Hell]] 2013-02-02 ! a tool to import avatar images from the forum
    # [[~Blue Hell]] 2013-02-02 {-Get the colors to better match the forum style-} :: done 2013-02-02 [[~Blue Hell]]
    to:
    Changed line 10 from:
    # [[~Blue Hell]] 2013-02-04 {-on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save-} :: 2013-02-06 [[~Blue Hell]] Solved, some other warnings and notices killed too, grep source code for blue_hell.
    to:
    # [[~Blue Hell]] 2013-02-04 ~ {-on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save-} :: 2013-02-06 [[~Blue Hell]] Solved, some other warnings and notices killed too, grep source code for blue_hell.
    # # 2013-02-04 [[~Blue Hell]] ~{-try add support for color electroblue-} :: done 2013-02-02 [[~Blue Hell]]
    to:
    2013-02-05 20:24 [UTC-7] by Blue Hell -
    Changed lines 1-10 from:
    # 2013-02-02 [[~Blue Hell]] {-try add support for color electroblue-} :: done 2013-02-02 [[~Blue Hell]]
    # 2013-02-02 [[~Blue Hell]] {-support for inlined audio ... some sort of a player thing - maybe html5 will be good enough-} :: done 2013-02-04 [[~Blue Hell]]
    # 2013-02-02 [[~Blue Hell]] {-support for inline video ... some sort of a player thing - maybe html5 will be good enough-} :: done 2013-02-03 [[~Blue Hell]]
    # 2013-02-02 [[~Blue Hell]] a tool to import forum posts
    # 2013-02-02 [[~Blue Hell]] a tool to import avatar images from the forum
    # 2013-02-02 [[~Blue Hell]] {-finish the donate [[http://electro-music.com/wiki/pmwiki.php?n=Main.Donate | thingie]]-} :: done 2013-02-04 [[~Blue Hell]]
    # 2013-02-02 [[~Blue Hell]] {-Get the colors to better match the forum style-} :: done 2013-02-02 [[~Blue Hell]]
    # 2013-02-03 [[~Blue Hell]] get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 [[~Blue Hell]] working on a manual thing now ... didnt like the cookbook stuff yet see [[Albums.Albums | Albums]] - all the images are in now, index work to do and captions ...
    # 2013-02-04 [[~Blue Hell]] {-on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187-} :: 2013-02-06 [[~Blue Hell]] - this one was solved
    # 2013-02-04 [[~Blue Hell]] {-on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save-} :: 2013-02-06 [[~Blue Hell]] Solved, some other warnings and notices killed too, grep source code for blue_hell.
    to:
    2013-02-05 20:21 [UTC-7] by Blue Hell -
    Deleted line 12:
    [[~Blue Hell]] 2013-02-05 18:21 [UTC-7]
    Added lines 11-13:
    2013-02-05 20:20 [UTC-7] by Blue Hell -
    Changed line 8 from:
    # 2013-02-03 [[~Blue Hell]] get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 working on a manual thing now ... didnt like the cookbook stuff yet see [[Albums.Albums | Albums]] - all the images are in now, index work to do and captions ...
    to:
    2013-02-05 20:18 [UTC-7] by Blue Hell -
    # 2013-02-04 [[~Blue Hell]] {-on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save-} :: 2013-02-06 Solved, some other warnings and notices killed too, grep source code for blue_hell.
    to:
    2013-02-05 20:17 [UTC-7] by Blue Hell -
    Getting some PHP messages on the site still
    -on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187-} :: 2013-02-06 - this one was solved
    * {-on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save-} :: 2013-02-06 Solved, some other warnings and notices killed too, grep source code for blue_hell.
    to:
    2013-02-05 20:15 [UTC-7] by Blue Hell -
    # 2013-02-03 [[~Blue Hell]] get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 working on a manual thing now ... didnt like the cookbook stuff yet sse [[Albums.Albums | Albums]]
    to:
    2013-02-05 20:14 [UTC-7] by Blue Hell -
    Changed lines 12-13 from:
    * on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187
    * on saving edits : [04-Feb-2013 13:09:26] PHP Warning:  Cannot modify header information - headers already sent in Unknown on line 0 : twice for each save
    to:
    * {-on watching the Site.AllRecentChanges page ?? [04-Feb-2013 12:54:20] PHP Notice:  Undefined offset:  7 in /home/mosc/electro-music.com/html/wiki/scripts/pagerev.php on line 187-} :: 2013-02-06 - this one was solved
    2013-02-05 20:11 [UTC-7] by Blue Hell -
    # 2013-02-03 [[~Blue Hell]] get the photo gallery back ... have a look at http://www.pmwiki.org/wiki/Cookbook/ThumbList :: 2013-02-06 working on a manual thing now ... didnt like the cookbook stuff yet sse [[Albums.Albums]]
    to:
    to:
    2013-02-05 20:10 [UTC-7] by Blue Hell -
    to:
    2013-02-04 15:33 [UTC-7] by Blue Hell -
    2013-02-04 15:13 [UTC-7] by Blue Hell -
    Added lines 9-13:
    2013-02-03 20:04 [UTC-7] by Blue Hell -
    Changed lines 2-3 from:
    # 2013-02-02 [[~Blue Hell]] support for inlined audio ... some sort of a player thing - maybe html5 will be good enough
    # 2013-02-02 [[~Blue Hell]] {-support for inline video ... some sort of a player thing - maybe html5 will b e good enough-} :: done 2013-02-03 [[~Blue Hell]]
    to:
    Changed line 6 from:
    # 2013-02-02 [[~Blue Hell]] finish the donate [[http://electro-music.com/wiki/pmwiki.php?n=Main.Donate | thingie]]
    to:
    2013-02-03 18:00 [UTC-7] by Blue Hell -
    # 2013-02-02 [[~Blue Hell]] {-try add support for color electroblue-} :: done 2013-02-01 [[~Blue Hell]]
    to:
    2013-02-03 17:59 [UTC-7] by Blue Hell -
    Changed line 3 from:
    # 2013-02-02 [[~Blue Hell]] {-support for inline video ... some sort of a player thing - maybe html5 will b e good enough-} :: done 2013-02-01 [[~Blue Hell]]
    to:
    # 2013-02-02 [[~Blue Hell]] support for inline video ... some sort of a player thing - maybe html5 will b e good enough
    to:
    2013-02-03 16:13 [UTC-7] by Blue Hell -
    Added line 8:
    2013-02-02 16:35 [UTC-7] by Blue Hell -
    # 2013-02-02 [[~Blue Hell]] {-try add support for color electroblue-} done 2013-02-01 [[~Blue Hell]]
    to:
    # 2013-02-02 [[~Blue Hell]] {-Get the colors to better match the forum style-} (:nl:)done 2013-02-02 [[~Blue Hell]]
    to:
    2013-02-02 16:34 [UTC-7] by Blue Hell -
    # 2013-02-02 [[~Blue Hell]] {-Get the colors to better match the forum style-} \\done 2013-02-02 [[~Blue Hell]]
    to:
    # 2013-02-02 [[~Blue Hell]] {-Get the colors to better match the forum style-} //done 2013-02-02 [[~Blue Hell]]
    to:
    # 2013-02-02 [[~Blue Hell]] {-Get the colors to better match the forum style-} done 2013-02-02 [[~Blue Hell]]
    to:
    2013-02-02 16:33 [UTC-7] by Blue Hell -
    to:
    to:
    2013-02-02 15:55 [UTC-7] by Blue Hell -
    to:
    # 2013-02-02 [[~Blue Hell]] Get the colors to better match the forum style
    to:
    2013-02-02 15:53 [UTC-7] by Blue Hell -
    # 2013-02-02 [[~Blue Hell]] try add support for color electroblue
    to:
    2013-02-02 09:23 [UTC-7] by Blue Hell -
    Changed lines 1-6 from:
    # 2013-02-02 [[~Blue Hell]] : try add support for color electroblue
    # 2013-02-02 [[~Blue Hell]] : support for inlined audio ... some sort of a player thing - maybe html5 will be good enough
    # 2013-02-02 [[~Blue Hell]] : support for inline video ... some sort of a player thing - maybe html5 will b e good enough
    # 2013-02-02 [[~Blue Hell]] : a tool to import forum posts
    # 2013-02-02 [[~Blue Hell]] : a tool to import avatar images from the forum
    # 2013-02-02 [[~Blue Hell]] : finish the donate [[http://electro-music.com/wiki/pmwiki.php?n=Main.Donate | thingie]]
    to:
    2013-02-02 08:42 [UTC-7] by Blue Hell -
    Added line 6:
    2013-02-02 08:38 [UTC-7] by Blue Hell -
    Changed lines 3-4 from:
    # 2013-02-02 [~Blue Hell]] : support for inline video ... some sort of a player thing - maybe html5 will b e good enough
    # 2013-02-02 [~Blue Hell]] : a tool to import forum posts
    to:
    2013-02-02 08:37 [UTC-7] by Blue Hell -
    Changed lines 1-5 from:
    * try add support for color electroblue
    * support for inline video ... some sort of a player thing - maybe html5 will b e good enough
    to:
    2013-02-02 08:35 [UTC-7] by Blue Hell -
    Added lines 1-5:
    * support for inlined audio ... some sort of a player thing - maybe html5 will be good enough
    * a tool to import forum posts
    * a tool to import avatar images from the forum
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-04-14 17:04 [UTC-7] - 6396 views
