Main / Wiki Swimming Pool
Main.WikiSwimmingPool HistoryHide minor edits - Show changes to output Changed line 10 from:
{_playlist_schedule to:
{_playlist_schedule_} Changed line 5 from:
to:
(:include JavaScript.RadioSchedule:) Changed lines 5-6 from:
{_live_schedule_} to:
{_live_schedule_test_} Changed line 9 from:
{_playlist_schedule_} to:
{_playlist_schedule_test_} Changed lines 2-33 from:
Below is the redirect coding used for random pages (commented out now) [=(:redirect {(random (plist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum) )} quiet=1 :)=] Below is code to view all page template variables and their contents (commented out now) [={(allptvs (plist group=*))}=] The following code shows which authentication groups you are a member of: (commented out now) [={_user_info_}=] The following is meant to include a clock, once it works - ok it does (commented out now): [={_clock_}=] [[~Luftballon]] 2013-02-23 08:39 [UTC-7] ~ The following includes a [[JavaScript.TestPage | test]] page that uses JavaScript to draw on a canvas. (:include JavaScript.TestPage:) try direct html ... [:html:] <p>test direct html </p> [:htmlend:] ok, non admins can not do that, good. Now fix it so WikiAdmins can do this too ... ok .. this may be fixed. [[~Blue Hell]] ~ fixed indeed; see [[Help.SiteSpecificMarkup#ntoc19 | Site specific markup]] for more on this. to:
----- [+Live show schedule+] {_live_schedule_} [+Playlist schedule+] {_playlist_schedule_} Changed line 19 from:
[[~Luftballon]] to:
[[~Luftballon]] 2013-02-23 08:39 [UTC-7] ~ The following includes a [[JavaScript.TestPage | test]] page that uses JavaScript to draw on a canvas. Changed line 19 from:
[[~Luftballon]] to:
[[~Luftballon]] <span name='xldt'>2013-02-23 08:39 [UTC-7]</span> ~ The following includes a [[JavaScript.TestPage | test]] page that uses JavaScript to draw on a canvas. Changed lines 25-26 from:
to:
[:html:] Changed line 29 from:
to:
[:htmlend:] Changed line 33 from:
[[~Blue Hell]] fixed indeed; see [[Help.SiteSpecificMarkup#ntoc19 | Site specific markup]] for more on this. to:
[[~Blue Hell]] ~ fixed indeed; see [[Help.SiteSpecificMarkup#ntoc19 | Site specific markup]] for more on this. Changed lines 31-33 from:
ok, non admins can not do that, good. Now fix it so WikiAdmins can do this too ... ok .. this may be fixed. to:
ok, non admins can not do that, good. Now fix it so WikiAdmins can do this too ... ok .. this may be fixed. [[~Blue Hell]] fixed indeed; see [[Help.SiteSpecificMarkup#ntoc19 | Site specific markup]] for more on this. Changed lines 25-26 from:
to:
(:html:) Changed line 29 from:
to:
(:htmlend:) Changed lines 19-20 from:
The following includes a [[JavaScript.TestPage | test]] page that uses JavaScript to draw on a canvas. to:
[[~Luftballon]] 2013-02-23 08:39 [UTC-7] ~ The following includes a [[JavaScript.TestPage | test]] page that uses JavaScript to draw on a canvas. Changed line 31 from:
ok, non admins can not do that, good. Now fix it so WikiAdmins can do this too ... to:
ok, non admins can not do that, good. Now fix it so WikiAdmins can do this too ... ok .. this may be fixed. Changed line 31 from:
ok, non admins can not do that, good. to:
ok, non admins can not do that, good. Now fix it so WikiAdmins can do this too ... Changed lines 23-24 from:
direct html ... to:
try direct html ... Changed lines 29-31 from:
[:htmlend:] to:
[:htmlend:] ok, non admins can not do that, good. Changed lines 25-26 from:
to:
to:
[:htmlend:] Changed line 27 from:
<p>test direct to:
<p>test direct html </p> Changed line 27 from:
<p>test direct to:
<p>test direct ht </p> Changed line 27 from:
<p>test direct html to:
<p>test direct html hmmm </p> Changed line 27 from:
<p>test direct html</p> to:
<p>test direct html </p> Changed lines 21-29 from:
(:include JavaScript.TestPage:) to:
(:include JavaScript.TestPage:) direct html ... (:html:) <p>test direct html</p> (:htmlend:) Added lines 18-19:
The following includes a [[JavaScript.TestPage | test]] page that uses JavaScript to draw on a canvas. Changed lines 17-19 from:
[={_clock_}=] to:
[={_clock_}=] (:include JavaScript.TestPage:) Changed lines 15-17 from:
The following is meant to include a clock, once it works: {_clock_} to:
The following is meant to include a clock, once it works - ok it does (commented out now): [={_clock_}=] Changed line 15 from:
The following is meant to include a to:
The following is meant to include a clock, once it works: Changed lines 13-17 from:
[={_user_info_}=] to:
[={_user_info_}=] The following is meant to include a clock {_clock_} Changed lines 11-13 from:
The following code shows which authentication groups you are a member of: to:
The following code shows which authentication groups you are a member of: (commented out now) [={_group_list_}=] Changed lines 7-8 from:
Below is code to view all page template variables and their contents to:
Below is code to view all page template variables and their contents (commented out now) Changed line 11 from:
to:
The following code shows which authentication groups you are a member of: Changed lines 9-13 from:
[={(allptvs (plist group=*))}=] to:
[={(allptvs (plist group=*))}=] Group membership test {_group_list_} Changed lines 7-9 from:
to:
Below is code to view all page template variables and their contents [={(allptvs (plist group=*))}=] Changed line 7 from:
{(allptvs (plist group= to:
{(allptvs (plist group=*))} Changed line 7 from:
{(allptvs (plist group=Articles))} to:
{(allptvs (plist group=Main,Articles,Radio,Schematics,Help,Forum))} Changed line 7 from:
{(allptvs (plist to:
{(allptvs (plist group=Articles))} Changed lines 1-6 from:
to:
This is a test page for trying some new stuff Below is the redirect coding used for random pages (commented out now) [=(:redirect {(random (plist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum) )} quiet=1 :)=] Changed line 1 from:
(:redirect {(random (plist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum) )} :) to:
(:redirect {(random (plist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum) )} quiet=1 :) Changed line 1 from:
to:
(:redirect {(random (plist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum) )} :) Changed line 1 from:
{(random to:
{(random (plist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum) )} Changed line 1 from:
{(random {(pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum to:
{(random {(pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum list=normal)} )} Changed lines 1-3 from:
( to:
{(random {(pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal)} )} Changed line 1 from:
(:redirect {(random pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal )} :) to:
(:redirect {(random {(pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal)} )} :) Changed lines 1-4 from:
(:redirect :) to:
(:redirect {(random pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal )} :) Changed line 2 from:
{(random to:
{(random pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal Changed lines 1-4 from:
(:redirect {(random {(pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal)} )} :) to:
(:redirect {(random {(pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal)} )} :) Changed line 1 from:
(:redirect to:
(:redirect '{(random {(pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal to:
(:redirect '{(random {(pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal)})}':) Added lines 1-3:
(:redirect '{(random {(pagelist name=-RecentChanges,-Main,-Articles,-Radio,-Schematics,-Help,-Forum group=Main,Articles,Radio,Schematics,Help,Forum count=1 order=random list=normal fmt=#include)})}':) |
Edit - History - Print - Recent Changes - Search Page last modified on 2013-03-03 10:53 [UTC-7] - 1804 views
