See the cookbook recent changes page for additional updates and activity by other developers, or join the PmWiki mailing lists to discuss feature development with us.
Version 2.2.46 (2013-01-07)
- Add third parameter to fixperms() explicitly setting the permissions.
- Add
$UploadPermAdd and $UploadPermSet variables.
- Update documentation.
Version 2.2.45 (2012-12-02)
- Cleanup some PHP notices (PITS:01304).
Version 2.2.44 (2012-10-21)
- Better display of whitespace in page histories.
- Fix definition for PageTextVariables containing a dash (PITS:00978).
Version 2.2.43 (2012-09-20)
- Allow for HTML attribute names to contain dashes, eg. data-transition, data-role etc.
- Remove warning when previewing Site.EditForm.
Version 2.2.42 (2012-08-20)
- Convert the line-endings in the docs/ directory to \r\n compatible with Windows.
- Modify PHSC() to call htmlspecialchars() with a single-byte encoding argument.
Version 2.2.41 (2012-08-12)
- Change $KeepToken to "\034\034" which is compatible with more encodings.
Version 2.2.40 (2012-07-21)
- Add PHSC() helper function as a replacement of htmlspecialchars() for PHP 5.4 (PITS:01292).
Version 2.2.39 (2012-06-25)
- Fix URL encoding of attachment links.
Version 2.2.38 (2012-05-21)
- Fix "Wrong parameter count for utf8_decode" warning, reported by Simon.
Version 2.2.37 (2012-05-01)
- Add page filename encoding functions.
- Better handling of dots in
[[#anchor_1.2]] sections (PITS:01285).
- Expand PageVariables in PageList template defaults (PITS:01282).
- Add test for iconv() and mb_convert_encoding(), refactor recode().
Version 2.2.36 (2011-12-28)
- Add $EnableOldCharset variable and $page["=oldcharset"] entry.
- Refactor PageStore->recode() to recover Windows-1252 characters.
- Add exit line to xlpage-iso-8859-2.php (PITS:01275).
- Fix difference in defining and removing "invisible" PTVs.
Version 2.2.35 (2011-11-11)
- Fix critical PHP injection vulnerability (PITS:01271, reported by Egidio Romano).
- Important change: Disable script loading from XLPage().
- Move the processing of
[[link|+]] inside LinkPage() and delete markup rule from stdmarkup.php.
- Modify MakeLink() to better handle link titles.
- Add optional $LinkTitleFunction allowing recipes to customize the link titles.
- Fix ReadTrail() to better handle links with titles.
- Add title attributes for the HTML templates in the
$LinkPage*Fmt variables.
- Add upload extensions svg, xcf, ogg, flac, ogv, mp4, webm, odg, epub.
- Minor optimization for the MarkupExpressions for UTF-8 strings.
- Minor optimization of the rendering of page history.
Version 2.2.34 (2011-10-10)
- Add MarkupExpressions replacements for UTF-8.
- Reset timestamps of Site(Admin).AuthUser to 1000000000, used in upgrades.php.
Version 2.2.33 (2011-09-23)
- Fix locked states for Site and SiteAdmin GroupAttributes (reported by Brijesh Kothari).
- Fix intermap.txt entries PITS: and Wikipedia: to point to their current locations.
- Fix refcount.php to produce valid HTML (PITS:01266).
Version 2.2.32 (2011-09-18)
- Add required html xmlns attribute to the print skin template.
- Add PageStore->recode() function.
- Add $DefaultPageCharset array.
- Optimize for speed the inline diff for page history when too many lines were added or deleted.
- Update and convert to UTF-8 the documentation.
Note: Due to a manipulation error, a version 2.2.31 was created before it was ready for a release.
Version 2.2.30 (2011-08-13)
- Fix $Charset definition in iso-8859-*.php files.
- Add $EnableRangeMatchUTF8, set it to 1 to enable range matches in UTF-8.
Version 2.2.29 (2011-07-24)
- Fix Attach links that were broken with the Path fix in 2.2.28.
- Add $IMapLocalPath array containing InterMap prefixes that should be treated as local.
Version 2.2.28 (2011-07-24)
- Fix potential XSS vulnerability in refcount.php (PITS:01262).
- Fix bug in Path: links (PITS:01260).
- Fix potential XSS vulnerability in custom SitePreferences (PITS:01263).
Version 2.2.27 (2011-06-19)
- Add block WikiStyle %justify% (PITS:01253).
- Remove unused <vspace> after a redirection (PITS:01255).
- Add ?nodiff=1 parameter for page history to disable diff rendering and show only restore links.
Version 2.2.26 (2011-05-21)
- Fix ReadTrail(), redundant replacing of hashes, already done in MakePageName().
Version 2.2.25 (2011-03-22)
Version 2.2.24 (2011-02-15)
- Add
{$$PageTrailDepth} pseudovariable for pagelist templates.
- Fix PageVar(), add $authpage array for an authenticated page data, removed
$EnablePageVarAuth .
Version 2.2.23 (2011-01-25)
Version 2.2.22 (2011-01-16)
Version 2.2.21 (2010-12-14)
- Fix potential XSS vulnerability, reported by DFaure.
- Fix invalid HTML for simple table captions, reported by JL.
- Fix WikiStyles could work not properly if a value was empty like accesskey="".
Version 2.2.20 (2010-12-14)
- Fix Pagelist {$$variable} didn't work in template none (PITS:01212).
- Fix interface access keys in browse mode (PITS:01188).
- Add PmL10n: intermap prefix for the Localization/ group on pmwiki.org (PITS:01180).
- Fix AuthUser excluding members didn't work (PITS:01201).
Version 2.2.19 (2010-11-10)
Version 2.2.18 (2010-09-04)
- Fix $SaveAttrPatterns to skip nested conditionals (reported by RandyB).
- Fix RecentChanges when an edit summary contains the dollar sign (PITS:01217).
- Fix RDF feed number of elements (PITS:01198).
Version 2.2.17 (2010-06-20)
- Add tabindex as a valid form attribute (PITS:01190).
- Collapse adjacent insertions in DiffRenderSource (PITS:01192).
- Fix HandleDownload to flush() output before exit (PITS:01199).
- Fix HandleDownload to respect
$EnableIMSCaching (PITS:01191).
- Add $PostConfig functions and scripts, loaded after stdconfig.php (PITS:01132).
- Add $AuthUserPat variable for the regexp pattern in AuthUserId() (PITS:01202).
- Pass $authlist as last parameter to $AuthUserFunctions (PITS:01197).
- Fix "exists" conditional to work with old link markup.
Version 2.2.16 (2010-05-10)
- Allow "exists" conditional to accept wildcards (PITS:01184)
- Fix GUI button %center% which didn't work correctly.
- Fix incorrectly parsed quote in PQA(), possible script injection (discovered by Hanno Boeck).
Version 2.2.15 (2010-03-27)
- Add
(Auth|Edit)Form to auto-translated titles.
- Fix
(:if auth LEVEL:) to respect $HandleAuth (PITS:01164).
- Skip loading of the second half of draft.php if $action!="edit".
- Fix bug with
(:template none:) introduced in 2.2.14, reported by Holger.
- Fix HandleDownload() to use binary file-read.
Version 2.2.14 (2010-02-27)
- Fix inline styles in WikiTrails (PITS:01121).
- Add a negation parameter to pagelist first/last templates (PITS:01127).
- Refactor FPLTemplateFormat(), move repeated code blocks into FPLExpandItemVars().
- Add
$EnableUndefinedTemplateVars allowing to hide or show undefined template/include {$$variables} (PITS:01152).
- Add "title" attribute to external links (PITS:00657).
- Add FmtPageTitle() to allow automatic i18n titles for RecentChanges and other technical pages (PITS:01157).
Version 2.2.13 (2010-02-21)
- Replace deprecated in PHP 5.3 function split() with explode().
- Add $WordDiffFunction default to PHPDiff().
- Use existing border colors as highlighting background.
- Refactor/optimize DiffRenderSource(), merge with DiffRenderInline().
- Change default history to show word-level highlighting.
- Fix bug with
$DiffKeepNum which kept less revisions than it should.
- Fix RetrieveAuthPage() call from HandleDiff().
Version 2.2.12 (2010-02-17)
- Allow a custom $DiffHTMLFunction to skip the line rendering if it returns false.
- Add
$EnableDiffInline , simple word-level diffs (PITS:00571).
Version 2.2.11 (2010-02-14)
- Break PrintDiff() into customizable functions (PITS:01106).
- Add anchors to individual diffs (PITS:00796).
- Remove unused $RecipeInfo definition in markupexpr.php (reported by P.Bowers).
- Add (:head:) and (:headnr:) table directives (PITS:00535).
- Fix
$GroupPattern and $NamePattern in xlpage-utf-8.php.
Version 2.2.9, 2.2.10 (2010-01-17)
- Fix i18n string in PasswdVar(), reported by SteP.
- Fix sample-config.php with correct information about
$EnableWSPre (PITS:01145).
- Fix range searches for wikis in UTF-8 (reported by Maxim).
- Fix global variable $StringFolding in scripts/xlpage-utf-8.php.
- Fix markup for italics in creole.php.
- Fix previews for PTVs, Pagelist templates and included sections (PITS:01098).
- Add
$DiffKeepNum - number of revisions kept, even if older than $DiffKeepDays .
- Add Yandex to robots.php.
- Change default
$EnableRelativePageVars to 1 (PITS:01145).
- Add fifth parameter to SetProperty() : keep existing property.
- Add
$EnablePageTitlePriority (PITS:00266, PITS:00779).
Version 2.2.8 (2009-12-07)
- Fix apostrophes in Author field (PITS:01155).
- Fix Condition "exists" for PHP 5.3 (PITS:01156).
Version 2.2.7 (2009-11-08)
- Fix GlobToPCRE() to work with !excl and -excl with PHP 5.3 (PITS:01149).
- Fix HandleDownload() correctly quote the filenames (PITS:01150).
- Fix SessionAuth() for PHP 5.3, the $_REQUEST array doesn't contain the $_COOKIE array (PITS:01141).
- Fix default timezone for PHP 5.3 (PITS:01141).
Version 2.2.6 (2009-10-04)
- Escape apostrophes for multiline textarea/hidden form fields.
- Fix global unset of $MarkupRules in Markup() and DisableMarkup(), reported by D.Faure.
- Fix call to BuildMarkupRules() in MarkupToHTML(), suggested by Pm.
- Allow disabling of $PageListFilters and $FPLTemplateFunctions if set to -1 and thus allow replacing a core function with a custom one.
- Fix DRange() returned timestamps +1min or +1day when it shouldn't (PITS:01125).
- Add $MarkupWordwrapFunction to allow custom
(:markup:) line width for multibyte wikis (PITS:00703).
- Add
$MakeUploadNamePatterns to allow custom filename normalization for uploads.
- Add a fourth argument to PostRecentChanges() to allow this function to be called with a custom
$RecentChangesFmt array.
- Add
$RecentUploadsFmt , to allow logging of new uploads to the RecentChanges pages (PITS:00088).
- Fix Notify for some installations in safe_mode (PITS:00976).
- Add
$HTMLHeaderFmt ['guiedit'] variable in guiedit.php to allow customization (PITS:01146).
Version 2.2.5 (2009-08-25)
- Add *.7z as accepted upload extension (PITS:00813).
- Fix global variable $HandleAttrFmt in HandleAttr (PITS:01126).
- Allow brackets in input element names (PITS:01131).
- Fix CSS class applied twice (PITS:01071).
- Fix Not-Modified headers could prevent caching (PITS:00802).
- Break FPLTemplate() into configurable sub-parts (PITS:01102).
- Add
(:template none:) section for Pagelist templates.
- Fix attr-protected page could be deleted with edit permissions (PITS:00238).
Version 2.2.4 (2009-07-16)
- Fix bug with page attributes, which somehow didn't make it in the 2.2.3 release.
- Fix bug with HTML entities in XLPages introduced earlier today in 2.2.3 (reverted, PITS:01114).
Version 2.2.3 (2009-07-16)
- Fix action=logout could incorrectly set a session cookie (PITS:01062).
- Fix page history trim in vardoc.php (PITS:01103).
- Add
$EnableUploadGroupAuth , use group password for downloads (PITS:01104).
- Fix recursive PTV loops, added
$MaxPageTextVars (PITS:00915, PITS:01099).
- Fix mkdirp() messages for absolute paths (PITS:00396).
- Fix sample-config.php order for urlapprove.php (PITS:01037).
- Fix broken signature links on preview.
- Fix crypt.php (action=crypt) could malfunction for passwords with quotes or apostrophes.
- Fix
@_site_* passwords to work in GroupAttributes (PITS:00836, PITS:00998).
- Fix possible XSS vulnerabilities, reported by Michael Engelke.
Version 2.2.2 (2009-06-21)
- Fix class in pages not on the breadcrumbs trail, reported by Ed W.
- Fix
tabindex and onclick to guiedit buttons.
- Fix
$GroupPrintHeaderFmt in print.php (PITS:01073).
- Fix global vars in xlpage-utf-8.php (PITS:00980).
- Fix $txt in LinkPage (reported by Eemeli Aro).
- Add
$EnableNotifySubjectEncode for international wikis (Cookbook:UTF-8).
- Fix international message in Abort().
- Fix security bug with AuthUser, reported by Eemeli Aro. See Release notes.
- Fix $ActionTitleFmt for login and upload, reported by Eemeli Aro.
Version 2.2.1 (2009-03-28)
- Fix $FPLTemplateMarkupFunction which somehow didn't get in the 2.2.0 archive.
- Fix wikitrails to work cross-group (PITS:00407).
- Add
$EnableRedirectQuiet variable (PITS:00919).
- Fix {$Title} could display global variables (reported by HansB).
- Fix reloaded form submissions could lose values (reported by DaveG).
- Fix preview while restoring a version from history (PITS:01081).
- Fix relative links with international characters (reported by G. Hermanowicz).
- Add in sample-config.php example call to xlpage-utf-8.php (PITS:01066).
- Fix guiedit.php to produce valid HTML.
Version 2.2.0 (2009-01-18)
- Convert beta series to official release series.
- Add $FPLTemplateMarkupFunction (PITS:00984, requested by John Rankin).
Version 2.2.0-beta68 (2008-08-14)
- Fix E_NOTICE errors reported by Dominique Faure.
- Enable
(:redirect:) directives in pagelists.
Version 2.2.0-beta67 (2008-07-13)
- Add {$LastModifiedTime} page variable.
- Add
$EnableSessionPasswords variable to control session password usage.
- Add
$SessionEncode and $SessionDecode variables to specify functions for encoding/decoding sensitive session data.
- Updated httpauth.php to use SessionAuth instead of poking in session guts directly.
Version 2.2.0-beta66 (2008-07-04)
- Add content-type/charset to Abort() output (suggested by Petko).
- Close minor XSS vulnerability (PITS:01030).
- Add "nested if" capability.
- Fix bug in $Transition handling that would enable all transitions if any were set (reported by John Rankin).
Version 2.2.0-beta65 (2007-11-17)
- Fix SiteAdmin.AuthList so that it defaults to list=all (reported by Roman).
- Fix pmwiki skin to include xmlns= attribute in <html> tag (PITS:00989, reported by Mateusz Czaplinski and Petko Yotov).
Version 2.2.0-beta64 (2007-11-13)
- Add times to PmWiki date parsing (e.g., 2007-08-09T12:22:04).
- Suppress warning from ini_set in diag.php (suggested by Petko).
- Fix handling of -> links in trails (reported by Eemeli Aro).
- Add .kml and .kmz as valid attachment types.
- Fix handling of & in markup (PITS:00988, reported by Stirling Westrup).
- Fix duplication of language markers in
$XLLangs (PITS:00987, reported by Stirling Westrup).
- Correct typo in DRange() call in stdmarkup.php (reported by Stirling Westrup).
- Turn on error displays when diagnostics are enabled.
- Default PHP's pcre.backtrack_limit to at least 1000000.
Version 2.2.0-beta63 (2007-07-31)
- Added $SkinDirectivesPattern to allow adjustments to available skin directives (requested by Petko).
- Fix default permissions on Site.AuthUser and Site.AuthList (reported by Scott Connard).
- Add "monospace" to pmwiki.css default (reported by Joshua Timberman, with assistance from H. Fox)
- Fix problem with slashes in wildcards to name= and group= parameters (reported by Ian MacGregor).
Version 2.2.0-beta62 (2007-07-21)
- Fix bug in trails introduced by beta61 (reported by charlequin).
Version 2.2.0-beta61 (2007-07-19)
- Add ability to grab trails by section.
- Add an "ontrail" condition (from suggestions by charlequin).
Version 2.2.0-beta59, 2.2.0-beta60 (2007-07-18)
- Fix problem with upgrade.php on wiki farms (reported by Scott Connard).
- Fix problem with distributed version of Site.AuthUser (reported by Jon Haupt).
Version 2.2.0-beta58 (2007-07-17)
- Significant change: Site.AuthUser, Site.Blocklist, Site.ApprovedUrls, and Site.NotifyList now appear in the SiteAdmin group by default.
- Abort if ldap: authentication requested and libraries aren't present.
- Added "upgrades.php" script to handle various migration issues.
- Current PmWiki version is now held in SiteAdmin.Status .
- Fix ?action=postupload to follow ?action=upload settings.
- Improvements to SiteAdmin.AuthList page (suggestions and fixes from Ian MacGregor).
- Allow leading underscores in attachment names (requested by Christophe David).
Version 2.2.0-beta57 (2007-06-15)
- Fix AsSpacedUTF8() to work like AsSpaced() (reported by Petko).
- Qualify page links that contain parentheses (reported by Petko).
- Fix bug in
(:input default $:var ... :) (reported by Crisses).
Version 2.2.0-beta56 (2007-06-13)
- Fix AsSpaced() to not add spaces before leading digit, and treat hyphenated digits as complete numbers.
- Fix infinite recursion in self-referencing page text variables (PITS:00915).
- Fix bug introduced in beta55 not handling end anchors correctly (reported by Roman).
Version 2.2.0-beta55 (2007-06-11)
- Fix attributes to
(:input e_form:) (PITS:00387, re-reported by Crisses).
- UpdatePage() now calls StopWatch() to record posting.
- Display stopwatch output as part of redirect.
- Fix wiki styles bug when
$EnableLinkPageRelative is set (reported by Petko).
- Revise TextSection() code to hopefully avoid pcre limits (reported by Kathryn Andersen, Knut Alboldt).
- Add wrap=inline and wrap=none options to page list.
Version 2.2.0-beta53, 2.2.0-beta54 (2007-06-02)
- Improve error message reporting for markup rules (suggestion by Knut Alboldt).
- Clean up more E_NOTICE warnings (reported by Ian MacGregor).
- Add focus= option to (:input:) controls.
- Added CSS
.faqtoc class, to be able to display only the questions coming from the #includefaq page list template.
- Changed PmWiki.FAQ to use .faqtoc class.
- Fix bug in TextSection (PITS:00935, reported by Jean-Fabrice).
- Fix bug in page list caching of trails.
Version 2.2.0-beta52 (2007-05-26)
- Add per-PageStore attributes (from a suggestion by Tobias Thelen).
- Add
{$PasswdRead} , {$PasswdEdit} , etc. to display page password settings.
- Add Site.AuthList to display all password permissions on a site.
- Reorder $PageListFilters slightly.
- Add "passwd=" option to page list, to return only those pages that have some sort of password attribute on them.
- Add line numbers to StopWatchHTML output.
- Clean up handling of $AuthCascade.
Version 2.2.0-beta51 (2007-05-23)
- Add fmt=count to page list (reminder from Hans).
- Ignore hidden files in skin directories when searching for .tmpl (suggestion by Stephan Becker).
- Clean up queuing of pages to be updated in .pageindex .
- Reset $LinkTargets() at beginning of each UpdatePage() sequence.
Version 2.2.0-beta50 (2007-05-22)
- Fix HTML cache when drafts are enabled, or other recipes using CondAuth().
- Prevent page lists with protected pages from HTML cache.
Version 2.2.0-beta48, 2.2.0-beta49 (2007-05-21)
- Fix spurious value= attribute in <textarea> tag generated by
(:input textarea ... :) .
- Allow either
(:input default ...:) or (:input defaults ...:) .
- Fix problem with page text variable handling in
(:input defaults:) .
- Allow either
(:template default:) or (:template defaults:) in page list templates.
- Fix a bug handling dates with suffixes (reported by Crisses).
Version 2.2.0-beta47 (2007-05-20)
- Fix bug with quote handling in
(:include:) options (reported by Hans).
Version 2.2.0-beta46 (2007-05-19)
- Moved $PageTextVarPatterns definition from scripts/stdmarkup.php to pmwiki.php.
- Ignore Markup() rules that have unresolved $when parameters.
- Fix issue in authuser.php when $auth array isn't set (contributed by Ben Stallings).
- The
(:include:) directive now performs template argument processing on the included text.
- Optimized
(:pagelist:) slightly when sorting on page variables.
- Refactored
(:input ... :) markups.
- Added HandleDispatch(), which allows action handlers to easily redispatch to other actions (and add messages).
- Added FmtTemplateVars(), to perform various template-substitutions.
Version 2.2.0-beta45 (2007-05-02)
- Update pmwiki's date parsing to use a common routine, recognizing dates within strings and restricting range to 1900-2039.
- Add additional parameter to "date" conditional.
- Add if= option to page list (suggested by Crisses).
- Refactor code to use TextSection() and RetrieveAuthSection() functions.
- The value= parameter to
(:input textarea:) now works properly (including values loaded from $InputValues).
- The
(:input default:) directive now allows loading input control defaults from another page via the source= parameter.
- Remove automatic call to FmtPageName() in
$ROSPatterns . Add $ROEPatterns (from suggestions by JB and others).
- Fix minor variable bugs in scripts/crypt.php.
- Remove E_NOTICE errors (reported by Hans).
- Fix handling of page variables when pagename is empty or not provided.
- Add
$EnableLinkPageRelative configuration option.
- Clean up handling of arguments to
{(ftime ...)} .
- Remove mailposts.php call in stdconfig.php (reported by Christophe David).
Version 2.2.0-beta44 (2007-04-16)
- Fix case conversion of U+027D and U+026B (reported by Petko).
- Add
$FTimeFmt to set default formatting for {(ftime)} .
- Add %s conversion to
{(ftime)} for systems that don't have it by default.
- Report an error if edit form cannot be read (suggested by Hans).
- Don't report ?cannot acquire lockfile when simply browsing pages.
- Add $EnableReadOnly flag to signal when PmWiki is to be run in read-only mode.
Version 2.2.0-beta43 (2007-04-15)
- Update drafts code to add
$EnablePublishAttr and change button labels when drafts are enabled (PITS:00755).
- Removed no-longer-needed 'compat1x.php' and 'mailposts.php' from distribution.
- Added
$DraftRecentChangesFmt .
- Added "markup expressions"
{(...)} into the core.
- Added charset= attribute to saved pages.
- Update pagelist.php and xlpage-utf-8.php to handle case-insensitive searches.
- Added some optimizations to phpdiff.php script to produce more useful history information.
Version 2.2.0-beta42 (2007-03-27)
- Fix a bug with order=title in pagelists (reported by Anno).
Version 2.2.0-beta41 (2007-03-26)
- Added
$EnableWSPre option, which allows easy adjustment of the "leading space -> preformatted text" (or "whitespace") rule.
- Added a new "pre" wikistyle, to designate blocks that are to be treated as preformatted text.
Version 2.2.0-beta40 (2007-03-24)
- Fix bug with order=title in pagelists when using $Titlespaced (PITS:00906, reported by Feral).
- Report state of allow_url_fopen when downloads fail in blocklist.php.
Version 2.2.0-beta39 (2007-03-23)
- Allow page variable filters to appear as options in
(:template defaults:) (reported by SteP).
- Updated Site.PageListTemplates to use
(:template:) directives.
- Remove '#wikileft h1' and '#wikileft h5' from pmwiki default stylesheet.
Version 2.2.0-beta38 (2007-03-22)
- Strip control characters from $ChangeSummary.
- Fix problem with count=m..n where m..n is outside the range of available pages (reported by SteP).
- Allow
(:template default ...:) to specify a class= option.
- Redirect pagename can now include an anchor (PITS:00558)
Version 2.2.0-beta37 (2007-03-16)
- Allow an optional space after comma separators in wildcard patterns (reported by Han Baas).
Version 2.2.0-beta36 (2007-03-16)
- Allow nested page text variables to work, remove extraneous ENT_NOQUOTES parameter.
- Add new
(:template ...:) directives for pagelist templates.
- Modify count= option to pagelists to allow for alternate ranges.
Version 2.2.0-beta35 (2007-03-05)
Version 2.2.0-beta33, 2.2.0-beta34 (2007-03-01)
- Refactor wildcard handling into its own GlobToPCRE function.
- Allow negated wildcards for page variable filters in pagelists (PITS:00878, reported by Jiri)
- Fix wildcards so that spaces no longer separate patterns (use commas).
- Fix handling of '&' prior to
(:input:) and other directives (reported by Luigi).
- Adjust position of
%define=...% wiki styles to occur after ampersands.
- Adjust copyright dates on many files.
- Allow spaces around text variable names in page text variable markups.
Version 2.2.0-beta32 (2007-02-28)
- Fix erroneous $EnableCreole item in docs/sample-config.php (reported by Sigurd).
- Added
(:elseif:) and (:else:) markups (PITS:00787).
- Fix global $Skin variable handling when using SetSkin from within markup.
- Make sure directives aren't treated like page text variables (reported by Petko).
- Remove call to ResolvePageName() from authuser.php .
- Simplify LDAP authentication for Active Directory sites.
- Cache lowercase/uppercase patterns in AsSpacedUTF8().
Version 2.2.0-beta31 (2007-02-11)
Version 2.2.0-beta29, 2.2.0-beta30 (2007-02-09)
- MakePageName now uses the first matching entry of
$PagePathFmt as the home page of groups without a home page.
- Add AsSpacedUTF8() to handle title spacing in utf-8 (PITS:00875, contributed by Petko, Celok)
- Fix $RequestedPage when running with utf-8.
- Add <meta> content-type tag for utf-8.
- Add an experimental caching system for pagelists.
- Fix $SuffixPattern and link suffixes for utf-8 (PITS:00881, reported by ppip).
Version 2.2.0-beta28 (2007-02-03)
- Update blocklist.php so that all posted fields are checked for block values (PITS:00850).
Version 2.2.0-beta27 (2007-01-25)
- Fix markup processing sequence for
(:input default:), (:input select:) , etc. (problem noted by Marc).
- Fix default value of
order= parameter to MakePageList().
Version 2.2.0-beta26 (2007-01-23)
- Fix a bug where pagelist list= option had no effect when reading from trails (from an rss problem noted by Russ Fink).
Version 2.2.0-beta24, 2.2.0-beta25 (2007-01-22)
- Add a scripts/creole.php module for Creole markup (http://www.wikicreole.org/).
- Move WikiWords out of the core defaults -- can be enabled via
$EnableWikiWords .
- Fix handling of WikiWords following & or #, as in Æ and #FFFF00 (reported by Moni Kellermann).
- Adjust FormatTableRow() to support Creole-style tables (using single |'s).
- Update docs/sample-config.php with new configurations and options.
- Added code to allow Abort() to refer to additional information on pmwiki.org.
- Added $EnableSkinDiag, which checks templates for required <!--HTMLHeader--> and <!--HTMLFooter--> directives.
- Removed deprecated $BasicLayoutVars support from skins.php.
Version 2.2.0-beta22, 2.2.0-beta23 (2007-01-17)
- Added $EnableActions, to allow pmwiki.php to be included without generating output (from a suggestion by Wouter Groeneveld).
- Fix bug in "order=" option to
(:pagelist:) (reported by Mike Bishop).
- Change DisplayStopWatch() function to StopWatchHTML().
- Allow multiple lines for markup:, wiki:, and page: template directives (reported by Marc)
Version 2.2.0-beta21 (2007-01-12)
- Fix <vspace> bug in searchresults output (PITS:00846, reported by M. Czaplinski, marc, and others).
- Fix numerous E_NOTICE warnings and incorrect constants (PITS:00853, contributed by AndrewFyfe).
Version 2.2.0-beta20 (2007-01-11)
- $FeedPageListOpt needs to be declared global in feeds.php.
- Add "404 Not Found" status code to ?invalid page name aborts (PITS:00854, suggested by Athan).
- Remove stale entries from $PageExistsCache when a new PageStore is added (reported by Hans).
Version 2.2.0-beta19 (2006-12-29)
- Have blocklist check $_POST['text'] only when it is set (from a report by Simon).
Version 2.2.0-beta18 (2006-12-28)
- Change $pagename parameter in UpdatePage() to be passed by reference (suggestion by J. Meijer).
- Fix $EnableRobotsCloakActions so that it works again with page variables.
- Add "XML Sitemaps" to $RobotPattern.
- Change
$MetaRobots to return "nofollow,noindex" for non-existent pages.
- Prefer "404 Not Found" to "403 Forbidden" for robots attempting to do invalid actions on non-existent pages.
- Add rel='nofollow' to "create attachment" links.
- Added class='inputbox' to select boxes (suggested by Hans).
- Added .odt, .ods, and .odp file extensions to allowed uploads (suggested by Algis Kabaila, Robin Sheat, and others).
- Clean up some error warnings (PITS:00801, contributed by psvo).
- Set
$ScriptUrl to 'https:' when accessed via SSL link (suggestions from C. Ridderström, H. Fox, PITS:00410, PITS:00527, PITS:00595).
- Fix bug in link= and trail= options to
(:pagelist:) (reported by C. Ridderström).
Version 2.2.0-beta17 (2006-12-13)
- Fix spurious hidden field in
(:searchbox:) output (reported by Hans).
- Fix $CaseConversions array for \xc4\xb1 and \xc5\xbf (reported by Petko Yotov).
- Refactor
(:input:) markup handling.
- Add
(:input select ...:) markup (PITS:00567).
- Add
(:input default ...:) markup -- may change before 2.2.0 release.
- Add ability to set defaults for radio/checkbox/select controls.
Version 2.2.0-beta16 (2006-11-10)
- Fix problem with
(:e_preview:) directive when viewing an edit form (reported by Dominique Faure).
- Fix out-of-memory problem in scripts/compat1x.php when dealing with large pages to be converted (contributed by Donald Gordon).
- Fix problem of Variable: lines immediately followed by newline (reported by Hans).
- Fix uninitialized variable errors in FormatTableRow() (reported by Bob Sanders).
- Fix second argument of MakeBaseName() (provided by Stirling Westrup).
Version 2.2.0-beta15 (2006-10-16)
- Fix bug with displaying multi-line
(:var:value:) page text variables (reported by Pico).
- Improve PageStore ls() method slightly, to restrict pagename searches to directories of a given depth (based on an issue reported by Chris Cox).
- Added $IsBlocked status variable to scripts/blocklist.php.
- Added $UnapprovedLink array to report unapproved links.
- Added $TimeISOFmt, $TimeISOZFmt, and $CurrentTimeISO variables.
- Switched scripts/feeds.php to use $TimeISOZFmt instead of $ISOTimeFmt.
- Added
request= option to (:pagelist:) , switched pagelist to default to not use url/form parameters.
- Fixed bug with array
{$$options} in pagelist.
Version 2.2.0-beta14 (2006-10-06)
Version 2.2.0-beta13 (2006-10-04)
- Fix handling of angle brackets (and potential XSS) in pagelists combined with page text variables (noted by Pico).
Version 2.2.0-beta12 (2006-10-03)
- Added the UpdatePage() function into the core.
Version 2.2.0-beta11 (2006-10-03)
- Added ability to automatically create targets.
- Added sample code to docs/sample-config.php for automatic generation of Category.* pages.
- Fixed character escapes in pagelist
{$$option} variables.
Version 2.2.0-beta10 (2006-10-02)
- Added
{$$option} variables to get option values from (:pagelist:) (based on a recipe from Martin Fick).
- Changed
{$PageCount}, {$GroupPageCount}, and {$GroupCount} to be {$$PageCount}, {$$GroupPageCount}, and {$$GroupCount} .
- Added
{$BaseName} page variable and $BaseNamePatterns .
Version 2.2.0-beta9 (2006-10-01)
- Fix bug with
$EnablePageListProtect (reported by Brent Zupp).
- Added ability to select based on page variables in
(:pagelist:) .
Version 2.2.0-beta8 (2006-09-30)
- Update scripts/blocklist.php to check only $_POST['text'] instead of entire markup text.
- Fix bug in pagelist.php that wouldn't return correctly formatted array in certain circumstances (noted by Florian Fischer and JDem).
Version 2.2.0-beta7 (2006-09-30)
- Added scripts/blocklist.php to core.
- Updated handling of $PageTextVarPatterns.
- Eliminated need for extra flush() steps in notify.php, pagelist.php.
Version 2.2.0-beta6 (2006-09-27)
- Fix bug with initialization of $FeedPageListOpt in scripts/feeds.php (reported by Roman).
- Fix bug with over-eager
(:textvar:value:) markup (from a bug reported by Chris Cox).
Version 2.2.0-beta4, 2.2.0-beta5 (2006-09-27)
- Fix bug with name= option in pagelist (reported by Ben Wilson).
- Fix bug with array_merge under PHP 5 (reported by Kathryn Andersen).
Version 2.2.0-beta3 (2006-09-26)
- Remove extra <!----> comment at end of table directives (noted by Ben Stallings).
- Fix directive form of page text variables (reported by Kathryn Andersen).
- Add first version of new modular pagelist code.
Version 2.2.0-beta2 (2006-09-25)
- Add support for
{$:var} page text variables, and (:var:...:) markup.
- Fix default setting of
$EnableRelativePageVars in docs/sample-config.php .
Version 2.2.0-beta1 (2006-09-25)
- Added
{*$var} page variables (always the currently browsed page).
- Convert link and page variable handling in (:include:) to be relative to the included page.
- Added
$EnableRelativePageVars and $EnableRelativePageLinks variables, as well as transition options.
- Added basepage= option to (:include:).
- Updated
$GroupHeaderFmt and $GroupFooterFmt to use basepage= option.
- Adjusted
$MakePageNamePatterns to automatically strip any #... or ?... from the end of a pagename input string (solution to a problem reported by J. Meijer).
Version 2.1.27 (2006-12-11)
- Backport in bug fix for TableRowFormat (from 2.2.0-beta16).
- Add support for
{*$Variable} syntax (from 2.2.0 page variables).
Version 2.1.26 (2006-09-11)
- Fix a bug with variable referencing that caused feeds.php to get a confused PCache (reported by Helge Larsen).
Version 2.1.25 (2006-09-08)
- Fixed a bug in authuser.php that would fail if $AuthUser isn't defined (reported by Hans Huijgen).
- Added <!--XMLHeader--> and <!--XMLFooter--> aliases to <!--HTMLHeader--> and <!--HTMLFooter--> directives in skin templates (suggested by John Rankin).
- Added $PageExistsCache (suggested by John Rankin).
Version 2.1.24 (2006-09-06)
- Fixed a bug in authuser.php that had trouble dealing with non-array entries in $AuthUser (reported by Udo).
- Can now specify authorization groups using $AuthUser['@group'] entries.
- Can now specify an Apache .htgroup-formatted file for authorization groups via $AuthUser['htgroup'].
Versions 2.1.21, 2.1.22, 2.1.23 (2006-09-05, 2006-09-06)
- Close a potential security hole with
$FarmD when register_globals is set "On".
- Correct a syntax error in feeds.php (noted by Ben Wilson).
- Fix a bug that prevented PmWiki from reading page files generated by versions prior to 0.5.6 (discovered by Milan Avramovic).
Version 2.1.20 (2006-09-04)
- Fixed a bug in
(:attachlist:) when passed a wikiword argument (reported by Kathryn Andersen).
- Changed
$HTMLStylesFmt ['markup'] to honor config.php setting (reported by Hans).
Version 2.1.19 (2006-08-30)
- Corrected a bug in the pageindex code that was causing the .pageindex to not update as quickly as it should.
- Slightly changed the handling of 'width' and 'height' in wikistyles.php, so that they can be be applied as attributes to <object> and <embed> tags.
- Updated the Keep() function to recognize closing block tags as being in the 'B' block pool.
- Fixed a bug with wikistyles and form tags.
Version 2.1.18 (2006-08-28)
- Closed a potential cross-site scripting vulnerability in table markups (reported by JB).
- Added
(:input image:) markup (requested by JB).
- Fixed problem with ?action=print failing to set
{$Action} (reported by Bart).
Version 2.1.17 (2006-08-26)
- Added some improvements to IMS caching to better handle logout and authorization actions (PITS:00573, reported by floozy and Henrik Bechmann).
Version 2.1.16 (2006-08-26)
- Added
$SkinLibDirs variable, to select filesystem and url locations where skins may be found (resolves PITS:00708, as reported by Hagan Fox, with additional suggestions from Ben Wilson).
- Changed
<!--HeaderText--> to <!--HTMLHeader--> in skin templates, and added an optional <!--HTMLFooter--> directive (PITS:00767).
- Adjusted the pmwiki and print skins to use the new directives.
Version 2.1.15 (2006-08-25)
- Fixed issue dealing with order of
@_site_* passwords (reported by Jean-Fabrice and others).
- Added
$LocalDir variable (requested by John Rankin).
- Removed an unnecessary setting of
$DefaultPage in scripts/pgcust.php (it's now handled by ResolvePageName() ).
- Added some variables and changes in wikistyles.php to better support wikipublisher (contributed by John Rankin).
- RetrieveAuthPage (PmWikiAuth) now recognizes a $level of 'ALWAYS' as indicating that access should always be allowed, regardless of current passwords or identities.
- Added filter specifier for AuthUser LDAP authentication (contributed by Balu).
Version 2.1.13, 2.1.14 (2006-08-15, 2006-08-16)
- Updated scripts/authuser.php to allow ldaps://... authentications (contributed by Michael Brenner).
- Fixed problem with numeric passwords introduced in 2.1.beta20 (reported by Christophe David and Dirk Blaas).
Version 2.1.12 (2006-08-07)
- Corrected typo in Site.SideBar file (reported by Judith Zacharie).
- Suppressed warning message for search on sites without a wikilib.d/ directory.
- Added capability for nested divs.
- Use $Transition['nodivnest'] to restore previous non-nesting div/table behavior.
- Including authuser.php now automatically resolves pagename.
- Added
(:noaction:) directive to turn off actions.
- Fixed bug in wikistyles prior to image blocks.
- Added white-space as allowed wikistyle (suggested by C. Ridderström).
- Allow colons, hyphens, and dots in id= tags.
Version 2.1.11 (2006-06-09)
- Fixed generation of empty paragraphs around
%define=...% wikistyles (PITS:00753).
Version 2.1.10 (2006-06-04)
- Added a <span> around the RecentChanges link in the pmwiki skin (PITS:00750, suggested by Hagan Fox).
- Changed the $Action variable to $ActionTitle (PITS:00749, reported by Hagan Fox).
- Changed
$FPLTemplatePageFmt to be an array of pages to be searched for page templates, enabled searching of current page and Site.LocalTemplates page.
- Updated .vspace margin in sidebar for pmwiki skin (PITS:00751, by Hagan Fox).
Version 2.1.9 (2006-06-02)
- Fixed a bug with
[[~Author]] links (PITS:00530 reported by Klonk, PITS:00611 reported by weijang, PITS:00671 reported by Stirling Westrup, and helpful clues provided by Clayton Curtis).
Version 2.1.8 (2006-06-01)
- Added ability to specify notification entries from local/config.php as well as Site.Notify (suggested by Christophe David).
- Fixed $Transition['vspace'] from 2.1.7.
Version 2.1.7 (2006-05-31)
- Adjusted width of edit form for IE browsers (contributed by Roman and H. Fox).
- Suppress authentication failure error from LDAP (PITS:00739).
- Fixed problem with invalid page names resulting in redirect loop (PITS:00723, reported by jojoo).
- Added "Group." and "Group/" page name syntax, resolving PITS:00736 (from a suggestion by Pico).
- Changed handling of "vspace" paragraphs.
- Fixed some XSS vulnerabilities in uploads.php and url links (reported by Moritz Naumann, http://moritz-naumann.com).
- Added notify.php script, allowing finer control of email notifications.
Version 2.1.6 (2006-05-22)
- Optimized performance of urlapprove.php.
- Added
(:if auth xyz PageName:) syntax.
- Corrected XSS bug in trails.php.
- Slightly improved performance of free links.
- Restore ability to use hyphens in InterMap links (reported by Henrik Bechmann).
Version 2.1.4, 2.1.5 (2006-03-29)
- Fixed problem with pagelist-based feeds (PITS:00709, reported by Jon Haupt).
- Added
{$Action} page variable. (PITS:00696, reported by Sebastian Pipping).
- Added stripmagic() around variables submitted to authuser.php.
- Fixed problem with multi-term searches containing special characters (PITS:00713, reported by Leo).
- Switched
(:attachlist:) to use a natural case sort (suggested by H. Fox).
Version 2.1.3 (2006-03-17)
- Re-fixed problem with PHP 5.1.1 and lines= option to
(:include:) (PITS:00620).
- Fixed empty LDAP password issue (reported by Thomas Lederer).
Version 2.1.2 (2006-03-16)
- Fixed <h1>/<h2> tag mismatches (PITS:00702, reported by Martin Hason).
- Fixed bug with $AllowPassword and "nopass" (reported by M. Weiner and bram brambring).
- Improved the speed of RSS and other web feeds when
$EnablePageListProtect is not set.
Version 2.1.1 (2006-03-13)
- Fixed a bug with multiple authorization groups as a password (PITS:00699, reported by Ari Epstein).
- Updated the authorization code to be a bit more liberal with password/group settings.
- Updated PmWiki.FAQ page to be able to grab FAQ items from other pages in the documentation.
Version 2.1.0 (2006-03-12)
- Many many documentation updates (special thanks to many authors).
- Allow trailing underscores in upload names (requested by Hans).
- Fixed 'ak_print' problem causing accesskey='a' for print (noted by Pico).
- Added code to make sure each anchor is generated only once per page (for XHTML validity).
- Added a $BlockPattern variable to recognize block HTML tags.
- Made an adjustment to Keep() so that it places strings with block HTML into the 'B' pool.
- Adjusted stdmarkup.php to not produce paragraphs for keep blocks in the 'B' pool.
- Corrected a variety of i18n phrases.
- Added class='escaped' to distinguish @@...@@ from [@...@] (from a comment by Hans).
- Slightly changed styling of .faq divs.
- Made the edit textarea a couple of rows smaller to better fit on smaller displays (suggested by H. Fox).
ChangeLog Archive - changes prior to version 2.1.0.
