Recent Changes - Search:
go to the forum
Contents
Site
Help
« mar 2021 · jul 2021 »
    add a calendar item
    Radio / Connect Info Edcast
    Radio.ConnectInfoEdcast History
    Hide minor edits - Show changes to output
    2013-04-02 18:59 [UTC-7] by Blue Hell -
    Changed line 1 from:
    <|[[Radio/ConnectionInfo]]|>
    to:
    <|[[Radio/ConnectionDetails]]|>
    2013-03-30 09:33 [UTC-7] by Blue Hell -
    Added lines 8-15:
    >>bgcolor=#dee3e7 border='0px solid gray' padding=5px<<
    The Edcast / Oddcast tooling has been discontinued, and then re-continued as [[http://code.google.com/p/edcast-reborn/|Edcast reborn]] - many people still have an older version.
    Edcast is available for Windows, either as a standalone progrom or as a plugin for Winamp. There also is a Linux version which is commandline based.
    For windows the standalone version is easier to use, but the plugin version may give some more routing flexibility.
    Deleted lines 22-29:
    2013-03-29 16:50 [UTC-7] by Blue Hell -
    Changed line 16 from:
    >>bgcolor=#f0f9ff border='1px solid gray' padding=5px<<
    to:
    2013-03-29 16:35 [UTC-7] by Blue Hell -
    Added line 52:
    >>center<<
    Changed lines 54-55 from:
    to:
    Added line 62:
    >>center<<
    Changed lines 64-65 from:
    to:
    Added line 70:
    >>center<<
    Changed lines 72-73 from:
    to:
    Added line 78:
    >>center<<
    Changed lines 80-81 from:
    to:
    Added line 92:
    >>center<<
    Changed lines 94-95 from:
    to:
    Added line 106:
    >>center<<
    Changed lines 108-109 from:
    to:
    Added line 140:
    >>center<<
    Changed lines 142-143 from:
    to:
    Added line 149:
    >>center<<
    Changed lines 151-152 from:
    to:
    Added line 167:
    >>center<<
    Changed lines 169-170 from:
    to:
    Added line 173:
    >>center<<
    Added line 175:
    2013-03-29 16:33 [UTC-7] by Blue Hell -
    Added line 37:
    >>center<<
    Added line 39:
    2013-03-29 16:31 [UTC-7] by Blue Hell -
    Changed lines 16-17 from:
    >>bgcolor=#f0f9ff border='1px solid gray'<<
    to:
    Deleted line 21:
    2013-03-29 16:30 [UTC-7] by Blue Hell -
    >>bgcolor=#f0f9ff border='1px solid gray' padding=5px%<<
    to:
    %block bgcolor=#f0f9ff border='1px solid gray' padding=5px%[@
    to:
    Changed lines 23-24 from:
    to:
    2013-03-29 16:27 [UTC-7] by Blue Hell -
    to:
    Added line 23:
    Added lines 15-16:
    2013-03-28 18:42 [UTC-7] by Blue Hell -
    Added lines 19-20:
    2013-03-28 18:41 [UTC-7] by Blue Hell -
    Changed line 156 from:
    Jasper's LineIn plugin for WinAmp can be a very usefull addition. It enables you to select other sound sources than the primary line in or microphone in as the source for broadcasing. For instance not all sound 'cards' nay be used without it.
    to:
    Jasper's LineIn plugin for WinAmp can be a very usefull addition. It enables you to select other sound sources than the primary line in or microphone in as the source for broadcasing. For instance not all sound 'cards' may be used without it.
    2013-03-28 18:40 [UTC-7] by Blue Hell -
    Changed line 132 from:
    * Click on the Connection button to bring up the settings for the SHOUTcast DNAS you will be  connecting to.  Enter the URL radio.electro-music.com under Address. Use the Port number, broadcasting password set on the server, and select 2 under the Encoder pulldown menu. (Yes, that's right - Output 1 uses Encoder 2, and Output 2 uses Encoder 1. It's a quirk with Winamp - sorry.) Enter the first port number and password given to you by MOSC.
    to:
    * Click on the Connection button to bring up the settings for the SHOUTcast DNAS you will be  connecting to.  Enter the URL radio.electro-music.com under Address. Use the Port number, broadcasting password set on the server, and select 2 under the Encoder pulldown menu. (Yes, that's right - Output 1 uses Encoder 2, and Output 2 uses Encoder 1. It's a quirk with Winamp - sorry.) Enter the first port number and password given to you by a stream operator.
    Changed line 137 from:
    * If you want this station to appear in the Station listings for Shoutcast.com, Winamp radio, and Apple Computer's iTunes, check the Make this server public checkbox.
    to:
    * If you want this station to appear in the Station listings for Shoutcast.com, Winamp radio, and Apple Computer's iTunes, do '''not''' check the Make this server public checkbox.
    Changed line 147 from:
    * Make sure the electro-music.com DNAS is running, that the soundcard input and mixers are correctly configured and that you are using Soundcard Input mode. Then click  '''Connect''' (button on upper right) to connect to your server and start broadcasting.  If you elected to make your server public, it will appear in the directory within 15 minutes of starting broadcasting.
    to:
    2013-03-28 18:38 [UTC-7] by Blue Hell -
    Changed lines 145-147 from:
    to:
    Attach:out-conn-1.jpg Attach:out-conn-2.jpg
    2013-03-28 18:37 [UTC-7] by Blue Hell -
    Changed lines 129-131 from:
    to:
    Attach:encode-1.jpg Attach:encode-2.jpg
    2013-03-28 18:34 [UTC-7] by Blue Hell -
    Changed lines 124-127 from:
    Note: on the windows below, we set up two outputs and two encoders - one for 64 kbs and one for 24 kbs:
    * Click on the Encoder tab, select '''Encoder 1''' on the left, and select the bitrate options '''128 kbs - stereo'''.
    * Click on the Encoder tab again, select '''Encoder 2''' on the left, and select the bitrate options '''44.1 kbs - stereo'''.
    to:
    Note: on the windows below, we set up two outputs and two encoders - one for 128 kbps and one for 24 kbps:
    * Click on the Encoder tab, select '''Encoder 1''' on the left, and select the bitrate options '''128 kbps - stereo'''.
    * Click on the Encoder tab again, select '''Encoder 2''' on the left, and select the bitrate options '''44.1 kbps - stereo'''.
    2013-03-28 18:32 [UTC-7] by Blue Hell -
    Changed lines 122-123 from:
    http://electro-music.com/images/winamp/input.jpg
    to:
    Changed lines 129-132 from:
    http://electro-music.com/images/winamp/encode-1.jpg
    http://electro-music.com/images/winamp/encode-2.jpg
    to:
    Changed lines 147-150 from:
    http://electro-music.com/images/winamp/out-conn-1.jpg
    to:
    Attach:
    Changed line 153 from:
    http://electro-music.com/images/winamp/main.jpg
    to:
    2013-03-28 18:28 [UTC-7] by Blue Hell -
    Changed line 166 from:
    For this the Shoutcast plugin for WinAmp must be configured a bit different from what was outlined so well above. Under Input configuration/Input device you'd want to select "WinAmp (reccomened)" instead of the usual "SoundCard input" selection. The Line In plugin will run your selected input through WinAmp.
    to:
    For this the Shoutcast plugin for WinAmp must be configured a bit different from what was outlined above. Under Input configuration/Input device you'd want to select "WinAmp (reccomened)" instead of the usual "SoundCard input" selection. The Line In plugin will run your selected input through WinAmp.
    Added lines 156-168:
    !!!!Additional tooling
    See : http://home.hccnet.nl/th.v.d.gronde/dev/lineinWA2/doc/index.html
    Once you have that plugin installed it will show up amongst WinAmp's Input plugins. When you double click on it you should be able to select all of your sound devices, and it's even possible to make presets.
    The drawback of this is that when WinAmp is installed as your default music player and you click on some music link or file that one will open up in WinAmp and you'll be streaming that instead of what you intended to stream. So it could be useful to set up another media player as your default music player when you are streaming out using WinAmp.
    2013-03-28 18:21 [UTC-7] by Blue Hell -
    Added lines 96-106:
    !!!!Installation
    First download and install the latest version of '''WinAmp''' onto your '''Windows''' computer. As of this writing, 5.12 is the newest. You don't need the PRO version; the free version has all the features you'll need. Get '''WinAmp''' here: http://www.winamp.com/player/ You can find installation '''WinAmp'''instructions on that site.
    In order to broadcast to a running '''SHOUTcast''' server using the winamp plugin, you will need the '''SHOUTcast Source for Winamp 2.x DSP Plug-in''', a piece of software which adds SHOUTcast broadcast ability to the Winamp software. (Don't worry about the word ''source'' in that title, it is pre-compiled and ready to run). The DSP Plug-in acts as a bridge between your Winamp software and a SHOUTcast DNAS server (which electro-music.com is running to broadcast).
    To obtain the latest copy of the plugin, please [[http://www.shoutcast.com/downloads/shoutcast-dsp-1-9-0-windows.exe | click here]]. Instructions are included with the installer. Installing the plug-in is easy, configuring it is a bit tricky. One tip, make sure Winamp is ''not'' running when you install the plugin. Use the default installation options.
    The following is from the plug-in configuration instructions, but edited a bit to be more relevant for electro-music.com streaming:
    Changed lines 109-155 from:
    { [[http://electro-music.com/forum/viewtopic.php?highlight=connect+radio&t=9065]] }
    to:
    Once you've installed Winamp and the DSP, you're ready to configure the plug-in.
    * After the plug-in has been installed, launch Winamp.
    * Enter the Winamp preferences menu by pressing Ctrl-P or using the pull-down menu.
    * Click on the DSP/Effect section in the left pane of the preferences window.
    * Select Nullsoft SHOUTcast Source DSP v1.8.2 [dsp_sc.dll] on the right.
    * A window pops up labeled SHOUTcast source.
    * Click Close on the Preferences window to close the Winamp Preferences window.
    * Bring the SHOUTcast source window to the front by clicking on its titlebar.
    * Click on the Input tab and ensure that the correct Input Device is selected, in our case use '''Soundcard - NOT Winamp'''. This is because we will use the soundcard for our live broadcasts.
    (It isn't necessary to use the soundcard mixer in the bottom part of this configuration window. This works only for commercial PC sound cards. If you have a professional audio interface, like a Firewire MOTU 828 or something, that mixer section won't even work.)
    * Click on the Output tab, then select '''Output 1''' on the left.
    * Optionally, place a checkbox in Automatic Reconnection on Connection Failure if you want the DSP to reconnect in the event of a Internet connection failure. (recommended).
    * Click on the Yellowpages button above to change the description information for this server.
    * Enter a Description of the station you're broadcasting (make this relevant to your jam/performance, a URL of a website with more information about your music, and the Genre(s) (electro-music) your server is broadcasting.
    * Optionally, you may enter an AIM name if you use AOL Instant Messenger, your ICQ # if you use ICQ, and an IRC channel if you use EfNet IRC.  This information helps listeners locate you as a broadcaster.
    * If you want the DSP to connect to the server whenever Winamp starts, check the Connect at Startup item above. (not reccommended)
    * Click again on the Output tab, then select Output 2 on the left and repeat the above steps for the Output 2. Use the 2nd port number you were given, and use Encoder 1 (yes, Output 1 uses encoder 2). Be sure to change the Yellowpages fields as well.
    Hopefully, these screen scans will help a bit...
    Note: the port numbers you will be given are most probably not the one shown on these screen shots.
    http://electro-music.com/images/winamp/out-conn-2.jpg
    There is more information in the README file that comes with the plugin. Read it if you are interested.
    2013-03-28 18:03 [UTC-7] by Blue Hell -
    Added lines 26-28:
    !!!!Installation
    Added lines 38-40:
    !!!!Configuration
    2013-03-28 17:57 [UTC-7] by Blue Hell -
    Changed lines 30-31 from:
    http://electro-music.com/images/lame-get.png
    to:
    Changed lines 40-41 from:
    http://electro-music.com/images/oddcast-scr0.png
    to:
    Changed lines 48-49 from:
    http://electro-music.com/images/oddcast-scr2.png
    to:
    http://electro-music.com/images/oddcast-scr3.png
    to:
    Changed lines 60-61 from:
    http://electro-music.com/images/oddcast-scr4.png
    to:
    http://electro-music.com/images/oddcast-scr5.png
    to:
    Changed line 84 from:
    http://electro-music.com/images/oddcast-scr6.png
    to:
    2013-03-28 17:52 [UTC-7] by Blue Hell -
    Deleted lines 14-29:
    For edcast (oddcast = edcast) setup there is some more help [[http://electro-music.com/forum/viewtopic.php?t=13780 | there]] to be merged into this article.
    extra info to be merged in:
    How to set up a song title.
    In the main Edcast/Oddcast window enter some meta information (Click on the Edit button, fill in the Metadata field, set external metadata disabled, and do not check grab metadata from window title). This information will be used as the song title. Unfortunately the program will have (half) forgotten this info after a restart, so it has to be set again then.
    Another option is to have the meta data in a text file, in this case set External metadata on, select the file option and give the full name and path for the text file, the first line from that file will be used for the song title then.
    Changed lines 40-67 from:
    This pertains to edcast for Windows standalone, but may also pertain to oddcast.  It is not a comprehensive setup how-to.  The main purpose of this entry is to document the settings needed to connect to an electro-music.com shoutcast server.
    !!!!Configuration
    Open edcast.
    Select an audio interface in the left Live recording combo box. Connect your audio source to that input - the VU meters should show a signal, if not try to click on the VU meter (they may be disabled). Make sure the slider is set all the way to the left (it can be used to mix in a microphone signal by sliding it to the right).
    Create an encoder entry by clicking on the Add Encoder button.
    Right click on the added encoder and select "configure".
    The above image shows the proper configuration when using the "open" broadcast port.
    For festivals and events, the Server port will be assigned.  The Server port shown is for the "open" broadcast port (which may not be what you have).  Change this value to the port number you've been given.
    The mountpoint field doesn't matter for electro-music.com.
    All of the other fields should be set as shown in the image.
    !!!!Meta data
    You can set your meta data by clicking the meta data edit button, fill in some text there.
    to:
    These directions should work for Edcast as well as the older Oddcast standalone version in Windows.
    Run the installer.
    After you accept the license agreement, be sure to click that you wish to install the LAME encoder so you can stream MP3 file format.
    You will be directed to a web page for the Lame encoder. I suggest you download the latest non-alpha or non-beta "bundle" and install it in your Program Files directory which is usually on the C: drive.
    After Edcast is finished installing, copy the file '''lame_enc.dll''' from your Lame installation to the directory where Edcast was installed.
    Now you are ready to test out your Edcast installation. Click on the Edcast icon that is on your desktop or run the standalone exe file in the Edcast directory.
    You will see a screen like this:
    Select the audio device you want to use for your stream. It may be different from the MOTU device shown on my example. You can see the meters operate if you have a signal. Sometimes when the device is configured incorrectly or there is no input to the device you'll see the meters at full scale. Ignore the Live Recording button and the slider unless you have a standard Windows sound card with DXI drivers.
    When the VU meters do not show any signal you may have to click in them to make them work.
    Then click on the '''Add Encoder''' button and a line will appear in the text area below the Encoder Settings heading. Double click on that new line and the configuration windo will appear, looking like this:
    Note, your port number and password will be different. Clear out the Mountpoint field because it is not used for MP3. Make sure the Encoder Type is MP3 Lame and the server type is Shoutcast.
    Now click on the YP Settings Tab at the top of the configuration window. You'll see this:
    You can use a different stream name if you wish, to describe your event.
    Next, click on the '''Advanced Settings''' tab:
    This is optional, but if you check of the two check boxes and include a directory you will be able to make a simultaneous recording of your stream. If you don't click Save as WAV it will save the MP3 file.
    Next, click '''OK''' and return to the main Edcast window. Click on the Connect button and see if you connect to the server. If it keeps trying and not getting through, then recheck your settings making sure you have the port and password correct. There is a chance that the http://radio.electro-music.com server is down. To check, use this URL http://radio.electro-music.com:8070 but replace 8070 by your port number. You should see the Shoutcast D.N.A.S. screen.
    Almost finished now...
    If everything is working, check the AutoConnect box. This will automatically reconnect if something causes a disconnect during your stream.
    Finally, Click on the Edit button next to the word Metadata near the top of the window. This is where you put in the title of your performance. Put that in the Metadata field - leave the rest of the stuff alone.
    You can edit the metadata anytime you want while you are streaming. If you are streaming a concert you may want to make the metadata identify who is performing.
    Changed lines 96-100 from:
    Please put something about your content in this file.  I put a shortcut to that file on my desktop.
    to:
    When all is working well, you will see something like this:
    2013-03-25 20:20 [UTC-7] by Blue Hell -
    Changed lines 21-23 from:
    2 How to set up a song title.
    In Edcast/Oddcast :
    to:
    2013-03-25 20:19 [UTC-7] by Blue Hell -
    Added lines 18-29:
    In Edcast/Oddcast :
    2013-03-25 20:17 [UTC-7] by Blue Hell -
    [@For edcast (oddcast = edcast) setup there is some more help [[http://electro-music.com/forum/viewtopic.php?t=13780 | there]] to be merged into this article.
    to:
    2013-03-25 20:16 [UTC-7] by Blue Hell -
    Added lines 15-19:
    2013-03-24 19:31 [UTC-7] by Blue Hell -
    Changed line 32 from:
    Select an audio interface in the left Live recording combo box. Connect your audio source to that input - the VU meters should show a signal, if not try to click on the VY meter (they may be disabled). Make sure the slider is set all th way to the left (it can be used to mix over to a microphone signal).
    to:
    2013-03-24 19:30 [UTC-7] by Blue Hell -
    to:
    2013-03-24 19:29 [UTC-7] by Blue Hell -
    Added lines 31-32:
    2013-03-24 18:43 [UTC-7] by Blue Hell -
    Added lines 6-7:
    !!How to connect up to the electro-music stream using Edcast or Oddcast.
    Deleted lines 14-15:
    Changed lines 12-14 from:
    [[<<]]!!How to connect up to the electro-music stream using Edcast or Oddcast.
    to:
    2013-03-24 18:42 [UTC-7] by Blue Hell -
    Changed lines 6-12 from:
    to:
    >>lframe font-size:smaller<<
    !!Contents
    (:toc:)
    (:indent:)
    2013-03-24 18:41 [UTC-7] by Blue Hell -
    Changed line 24 from:
    Select an encoder by clicking on the Add Encoder button.
    to:
    2013-03-24 18:40 [UTC-7] by Blue Hell -
    Added lines 11-12:
    Added line 13:
    Added lines 16-17:
    !!!!Configuration
    Changed lines 36-37 from:
    to:
    !!!!Meta data
    Changed lines 47-48 from:
    to:
    Changed lines 50-51 from:
    to:
    !!!!Configuration
    Changed lines 54-59 from:
    !!!The Linux version
    to:
    !!!!Configuration
    2013-03-24 18:38 [UTC-7] by Blue Hell -
    Changed lines 19-21 from:
    Select an encoder from the lower box.\\
    Right click and select "configure".\\
    to:
    Added line 32:
    Added lines 34-38:
    Alternatively you can use a file to specify your meta data.
    Added line 42:
    2013-03-24 18:35 [UTC-7] by Blue Hell -
    Changed lines 15-18 from:
    Open edcast.\\
    to:
    Open edcast.
    2013-03-24 18:30 [UTC-7] by Blue Hell -
    Added line 20:
    2013-03-24 16:35 [UTC-7] by Blue Hell -
    Added lines 35-37:
    2013-03-21 22:07 [UTC-7] by JovianPyx -
    Changed line 13 from:
    to:
    2013-03-21 21:54 [UTC-7] by JovianPyx -
    Changed line 18 from:
    to:
    2013-03-21 21:53 [UTC-7] by JovianPyx -
    Changed lines 15-17 from:
    Open edcast.
    to:
    Open edcast.\\
    2013-03-21 21:51 [UTC-7] by JovianPyx -
    Changed line 15 from:
    Open edcast
    to:
    Open edcast.
    2013-03-21 21:50 [UTC-7] by JovianPyx -
    2013-03-21 21:47 [UTC-7] by JovianPyx -
    Added line 31:
    2013-03-21 21:46 [UTC-7] by JovianPyx -
    Changed lines 26-29 from:
    to:
    2013-03-21 21:45 [UTC-7] by JovianPyx -
    Changed lines 22-24 from:
    For festivals and events, the port will be assigned.  The port shown is for the "open" broadcast port.  Change this value to the port number you've been given.
    to:
    2013-03-21 21:40 [UTC-7] by JovianPyx -
    Added line 18:
    Changed lines 20-23 from:
    to:
    Changed line 30 from:
    Put something about your content in this file.  I put a shortcut to that file on my desktop.
    to:
    2013-03-21 21:34 [UTC-7] by JovianPyx -
    to:
    2013-03-21 21:32 [UTC-7] by JovianPyx -
    [attach:EM_open_port_edcast_configuration.jpg]
    to:
    2013-03-21 21:29 [UTC-7] by JovianPyx -
    [[attach:EM_open_port_edcast_configuration.jpg]]
    to:
    to:
    2013-03-21 21:27 [UTC-7] by JovianPyx -
    Added lines 16-20:
    2013-03-21 21:00 [UTC-7] by JovianPyx -
    Added lines 15-20:
    Open edcast
    The location of the stream title metadata is in the file C:\Program Files\edcast\streamtitle.txt
    2013-03-21 20:51 [UTC-7] by JovianPyx -
    Added lines 13-15:
    2013-03-21 20:27 [UTC-7] by Blue Hell -
    Added lines 1-3:
    2013-03-21 20:06 [UTC-7] by Blue Hell -
    Changed lines 5-13 from:
    to:
    !!!The windows standalone version
    !!!The Winamp plugin
    2013-03-21 20:00 [UTC-7] by Blue Hell -
    Changed lines 3-5 from:
    to:
    2013-03-21 19:47 [UTC-7] by Blue Hell -
    Added lines 1-3:
    {_stub_}
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-04-02 18:59 [UTC-7] - 4586 views
