Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2021 · dec 2021 »
    add a calendar item
    Radio / Streaming Connect Info
    Radio.StreamingConnectInfo History
    Hide minor edits - Show changes to output
    2013-03-28 17:20 [UTC-7] by Blue Hell -
    Changed line 10 from:
    "song title", "to your likings", "This is also called 'meta data', will be shown in listener's media player"
    to:
    "song title", "to your likings", "Also called 'meta data', will be shown in listener's media player"
    2013-03-28 17:19 [UTC-7] by Blue Hell -
    Changed line 4 from:
    "port number", "see port / password table", "This can be a private port number or a public one, or a DJ (sc_trans) port"
    to:
    "port number", "see port / password table", "This can be a private port, a public one or a DJ (sc_trans) port"
    2013-03-28 17:18 [UTC-7] by Blue Hell -
    Changed lines 3-4 from:
    "server", "electro-music.com", "the server address"
    "port number", "see port / password table", "this can be a private port number or a public one, or a DJ port"
    to:
    "server", "electro-music.com", "The server address"
    Changed line 8 from:
    "username", "public, see port / password table", "or DJ name, only needed for sc_trans (DJ) connection, if at all"
    to:
    "user/DJ-name", "public, see port / password table", "Only needed for sc_trans (DJ) connection, if at all"
    Changed lines 10-11 from:
    "song title", "to your likings", "this is also called 'meta data', will be shown in listener's media player"
    "reconnect time", "not less than 10 s", "automatic client reconnect time (in case the connection got lost)"
    to:
    "reconnect time", "not less than 10 s", "Automatic client reconnect time (in case the connection got lost)"
    2013-03-28 17:17 [UTC-7] by Blue Hell -
    "username", "public, see port / password table", "only needed for sc_trans (DJ) connection"
    to:
    Changed line 11 from:
    "reconnect time", "not less than 10 s", "automatic client reconnect timeout time"
    to:
    2013-03-25 19:53 [UTC-7] by Blue Hell -
    "reconnect time", "10 s", "automatic client reconnect timeout"
    to:
    2013-03-25 19:52 [UTC-7] by Blue Hell -
    Added line 11:
    2013-03-24 20:36 [UTC-7] by Blue Hell -
    Deleted line 0:
    Changed lines 6-10 from:
    "samplerate", "44.100 kHz, "For an sc_trans connection a different samplerate may be used"
    "password", "see port / password table", ""
    ", "not always needed"
    "stream title
    ", "to your likings", "this info will show in the listener's media player"
    "song title", "to your likings", "also called meta data, also shown in listener's media player"
    to:
    "samplerate", "44.100 kHz", "For an sc_trans connection a different samplerate may be used"
    "password", "see port / password table", "password needed to connect to the server"
    "stream title", "to your likings
    ", "This info will show in the listener's media player"
    2013-03-24 20:34 [UTC-7] by Blue Hell -
    Added lines 1-12:
    (:data:)
    "field", "usual value", "description"
    "bitrate", "128 kbps", "For an sc_trans connection a different bitrate may be used"
    "username", "public, see port / password table", "not always needed"
    "stream title", "to your likings", "this info will show in the listener's media player"
    (:dataend:)
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-03-28 17:20 [UTC-7] - 1015 views
