Recent Changes - Search:
Contents
Site
Help
« aug 2020 · dec 2020 »
    add a calendar item
    Schematics / MFOS Wave Freaker Module
    Schematics.MFOSWaveFreakerModule History
    Hide minor edits - Show changes to output
    2013-02-24 15:01 [UTC-7] by Blue Hell -
    Changed line 1 from:
    [[!DIY]] | [[!Wave Shaping]] | [[!MFOS]] | [[!Ray Wilson]] ! [[Harmonics]]
    to:
    [[!DIY]] | [[!Wave Shaping]] | [[!MFOS]] | [[!Ray Wilson]] | [[!Harmonics]]
    Added lines 1-3:
    Added lines 1-23:
    MFOS Wave Freaker Module by Ray Wilson ,visit the MFOS Synth diy headquarters for details on construction of this module ,demo ,and PCB's . http://www.musicfromouterspace.com
    From the description by Ray Wilson :
    If you're looking for some new waveforms for your synth you've definitely come to the right place. I have been asked several times to come up with a circuit that takes a basic waveform like a triangle or a sine wave and takes it in a new harmonic rich direction. This circuit takes a triangle or sine wave (or other non-square wave) and allows you to turn it progressively inside out yielding a totally cool sound (peak inversion). Additionally the triangle, sine (or ramp/saw) is converted to what I refer to as a step waveform which has a cool hollow harmonic-rich type of sound. The modified triangle or sine wave output is further enhanced by the addition of a mixer for pulse wave, sub octave square wave and sub-sub octave square wave for very interesting harmonic rich sounds. You'll love the dry sounds you get but when put through a resonant filter your ears will get a real treat. Finally some new waveshapes beyond sine, tri, ramp, saw and square.
    Features
    Turns a Triangle or Sine Wave Into a Harmonic-Rich Waveform.
    Provides several waveforms:
    Inverted Peaks Wave (CV modulation capable)
    Stepped Wave (CV modulation capable)
    PWM Rectangle (CV modulation capable)
    Square Sub-octave of fundamental
    Square Sub-Sub-octave of fundamental
    Voltage Controlled Wave Shape Modulation
    Voltage Controlled Step Wave Modulation
    visit the MFOS subforum : http://electro-music.com/forum/index.php?f=99
    %width=95pct% http://electro-music.com/forum/phpbb-files/wavefreakerschematic_schem_115.jpg
    %width=95pct% http://electro-music.com/forum/phpbb-files/wavefreakerschematic2_schem_874.jpg
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 15:01 [UTC-7] - 3383 views
