<on air> Howard Moscovitz Chez Mosc - No show tonight - sorry
Controlling Chaos for evolving patterns
Page 1 of 3 [51 Posts]
Goto page: 1, 2, 3 Next
iPassenger
G2 patch files: 78
PostPosted: Sun Apr 15, 2007 2:28 am    Post subject: Controlling Chaos for evolving patterns
Subject description: How to create semi random evolving sounds/patterns
Hi all,
Just wondered if we could start a thread on how to make interesting and controlled random patterns/sounds. Following a brief quiz with Jan on the subject yesterday, he advised me to post something up on here n see how u all do it.
I have managed to get my head round quite a lot of the sound synthesis aspects of the Nord but I am struggling with the evolving concepts (such as complex arrangements of logic n sequencers), i find i am having to do the leg work with controllers, rather than getting the nord to do the labour.
A couple of pics below: 1st one is a really basic couple of controlled random modules, the lfo one, is quite cool cos u can get it to make repeatable random seqs rather than usinhg the random pattern module.
second one: the nearest i have got to a self controlled machine.
 Filesize:  608.98 KB
 Viewed:  8069 Time(s)
 Filesize:  793.59 KB
 Viewed:  8054 Time(s)
iP (Ross)
Audio files: 116
G2 patch files: 317
PostPosted: Sun Apr 15, 2007 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Ross, could you post the patches as well ? Would save me some time in copying Very Happy
To me the sequencer approach usually does not work out very well, as it keeps on looping around forever doing the same. It doesn't even matter very much how long the sequences are, after a few loops it will be obvious anyway.
What I sometimes do to get some life in itis to set some of the loop lengths to odd numbers like 11 or 13. Usually the sequencer reset is tied to the clock's sync output and you can play a bit with when things get synced.
Alternatively some post processing could be used, either on the looped control signals or on the audio signals resulting from it.
On the other hand, plain random doesn't do the trick either, there has to be some order to make it attractive.
It's a bit hard to be specific about this as basically I just try stuff till I'm pleased by the results. To illustrate I'll add an example patch that I made based on this thread. I picked this one because it's a relativly simple patch.
This a a bit of a funny way of turning things around, the basic sequence is a random one, but when it would play the same note an alternative selection is used. The funny thing is that altough I would have expected the output to be more random instead a new order seems to be imposed by the switching process itself. A sort of a lucky find.
 Filesize:  137.43 KB
 Viewed:  281 Time(s)
rnd-lfo-ex-001.pch2
 Filename:  rnd-lfo-ex-001.pch2
 Filesize:  2.22 KB
 Downloaded:  761 Time(s)
Audio files: 107
PostPosted: Sun Apr 15, 2007 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I suggest you check out the many patches submitted by megerov, http://electro-music.com/g2patches.php?owner=megerov
Especially look at the Mandelbrot and fractal patches. These have a knack of sounding repetitive but never repeating exactly.
After a lot of study with these, I find it is difficult to understand intuitively, but just use them as pattern generators and forget about understanding them. Laughing
Audio files: 107
PostPosted: Sun Apr 15, 2007 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
It's one thing to get these nice sequences, but if the rhythm is ignored, then it just sounds like a note generator spiting out notes on every beat. I'm interested in rhythm generators too.
Audio files: 107
PostPosted: Sun Apr 15, 2007 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a variation of Jan's patch. I added a rhythm trick. I use event sequencers and a random selector. So at any clock tick, there is about a 25% chance that a given event sequence will fire. By selecting a beat on all four selectors, you are going to get 100% notes on that beat. So you can sorta control the probability of each one of the 16 beats.
autorhythm.pch2
A simple patch for generation an automatic rhythm of some interest. Based on a melody generator by Blue Hell. The rhythm part is the 4 modules on the lower left.
 Filename:  autorhythm.pch2
 Filesize:  3.02 KB
 Downloaded:  1090 Time(s)
Audio files: 211
G2 patch files: 92
PostPosted: Sun Apr 15, 2007 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like to experiment with a couple of pre-made patterns that get randomly selected by a mux. Here is something I knocked together to show the principle (with a static drum line and bass note) - I would probably tweak it some more.
For the melody line there are no pre-made patterns, rather one of 8 different values are selected by the mux (the purple modules) for each note, the selections are random values, the bass line, the bass line offset by 7 half notes, the fourth or sixth latest note (taken from the delay shift register), or the mean value of the last and the seventh last note.
Edit: Noticed that my pattern thingie is a slightly different take on Mosc's rythm generator.
/Stefan
sbt_muxes.pch2
 Filename:  sbt_muxes.pch2
 Filesize:  5.85 KB
 Downloaded:  728 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Sun Apr 15, 2007 11:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great ideas folks but there must be many takes on this, I certainly like the controlling the probability thro multiple sequencer approach.
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Mon Apr 16, 2007 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
One of my versions of Megerov's chaos works.
My Algo 2.pch2
 Filename:  My Algo 2.pch2
 Filesize:  1.85 KB
 Downloaded:  722 Time(s)
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Mon Apr 16, 2007 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
and a poly synth with semi random seqs:
Dirty Poly Seq2.pch2
 Filename:  Dirty Poly Seq2.pch2
 Filesize:  7.08 KB
 Downloaded:  656 Time(s)
iP (Ross)
Audio files: 107
PostPosted: Mon Apr 16, 2007 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like that poly synth thingie. Very nice.
Audio files: 116
G2 patch files: 317
PostPosted: Mon Apr 16, 2007 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
All good patches and all demonstrating their purpose, and all good in their way, but still all those damned sequencers, get rid of 'm Laughing
drummies.pch2
no sequencers
 Filename:  drummies.pch2
 Filesize:  2.92 KB
 Downloaded:  793 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Mon Apr 16, 2007 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is awesome Blue.
iP (Ross)
Audio files: 116
G2 patch files: 317
PostPosted: Mon Apr 16, 2007 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ross, but the point is: get rid of those sequencers, they are boring and they are not needed Laughing ... well it depends on what music you want to make of course, but they are over-used and over-rated IMHO Very Happy
The patch above uses a bunch of LFO's with feedback. In this case, to get something of a steady pace, in it I used sample & holds to sync the outputs to a clock, The amount of feedback used, together with the speed of the LFO's determines an amount of randomness vs staticness. Putting slow random LFO's on that to modulate it gives some variation over time. When you want it to be more messy leave out the synching.
Here is a tribal-like variation, same idea as above. anyway, you can make it as nuts as you like, or tame it instead.
drummies-2.pch2
 Filename:  drummies-2.pch2
 Filesize:  3.79 KB
 Downloaded:  828 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Mon Apr 16, 2007 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, well ... thought that this could be a nice way to sequence maybe, doing some stuff on different time scales.
sequnce-1.pch2
 Filename:  sequnce-1.pch2
 Filesize:  2.71 KB
 Downloaded:  833 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Mon Apr 16, 2007 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, i do see yr point, it requires a different way of thinking/approach in order to work in this way.
I will try constructing my own, lfo driven rhythm device. If I can suss it out, will post it up.
R.
iP (Ross)
Audio files: 116
G2 patch files: 317
PostPosted: Tue Apr 17, 2007 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
In the above I might have given the suggestion of saying bad things about other's patches. This was not my intention, I just wanted to stress other possibilities and got carried away in that a bit. I found all contributions here useful and interesting.
Please keep on posting your patches, without other's ideas I'd run around in circles as well.
iPassenger
G2 patch files: 78
PostPosted: Tue Apr 17, 2007 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
No worries Blue, I knew what you were getting at.
A quick experiment based on yr principle
Weird Seqs.pch2
 Filename:  Weird Seqs.pch2
 Filesize:  3.17 KB
 Downloaded:  697 Time(s)
iP (Ross)
Audio files: 107
PostPosted: Tue Apr 17, 2007 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't worry. No bad intention came through. Sequencers have their uses and I agree, they tend to be over used. When it comes to "variations on a theme" techniques, they are very handy.
Audio files: 107
PostPosted: Tue Apr 17, 2007 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
This is excellent! It has a classical music feel to it. Maybe because it sounds like pizzicato strings.
Audio files: 116
G2 patch files: 317
PostPosted: Tue Apr 17, 2007 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shall listen later today, for now just : http://electro-music.com/forum/post-116460.html - not NM patches but an interesting approach to sequencing.
Audio files: 107
PostPosted: Tue Apr 17, 2007 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's something that I've been working on for the last year or so. This is NM specific. I think there is considerable value in making note generators in one slot that control sound generators in other slots. This keeps the process of generation and sound separate.
iPassenger
G2 patch files: 78
PostPosted: Tue Apr 17, 2007 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers.
Funny you say that, cos it started out with a string osc but I couldn't get it to behave the way I wanted it to.
With regard to keeping the SEQ/CONTROL and SYNTH seperate, I agree. This is a smart approach, It allows for two sets of mutators to be run n this can then result in some seriously bizarre patches.
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Tue Apr 17, 2007 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not quite ready for this kinda stuff yet, am only just getting my head round the nord.
But it looks cool anyway.
iP (Ross)
Audio files: 116
G2 patch files: 317
PostPosted: Tue Apr 17, 2007 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks.
And I looked into the patch and agree with Howard, excellent. I like variation 1 best.
Audio files: 116
G2 patch files: 317
PostPosted: Tue Apr 17, 2007 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wait a sec ... http://electro-music.com/forum/post-90461.html
People didn't like it very much apparently, but it's an interesting sequncer nevertheless.
