Sampling Osc
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Jul 04, 2007 3:31 am    Post subject: Sampling Osc
Subject description: crude wavetable-style osc with (non-volatile) sampling function
Hi, just came up with this while procrastinating the morning away instead of working Embarassed Wink Laughing, maybe it can be of use to someone.
It's an oscillator whose waveform is represented by 16 steps, stored in a NoteSequencer. This gives you the possibility of (admittedly very crude) sampling new waveforms via the "Rec"-input of the NoteSequencer. Non-volatile sampling, at last! Laughing
Controls: Coarse + Fine tuning, waveform sampling gate (connected to a manual switch in this example).
Technically, it's based on a DYI sawtooth osc, which is used in a not-so-intuitive Wink way to drive the NoteSequencer properly. Unfortunately, the tuning is not perfect, sorry.
SamplingOsc TK.pch2
Oscillator whose waveform is represented by 16 steps, stored in a NoteSequencer. This gives you the possibility of (admittedly very crude) sampling new waveforms via the "Rec"-input of the NoteSequencer. Non-volatile sampling, at last! :lol:
 Filename:  SamplingOsc TK.pch2
 Filesize:  1.66 KB
 Downloaded:  1386 Time(s)
