Schulte Compact A Phasing
Page 2 of 26 [649 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 24, 25, 26 Next
PostPosted: Mon Sep 10, 2007 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
An LDR...?
Like this one?;
58-0132.pdf
 Filename:  58-0132.pdf
 Filesize:  85.08 KB
 Downloaded:  259 Time(s)
ACHTUNG!
Evan
PostPosted: Mon Sep 10, 2007 5:35 am    Post subject: Re: Schulte Compact A Phasing Reply with quote  Mark this post and the followings unread
jhaible wrote:
I discovered his early works rather late in life: Apocalypse, Earth, 666.
Has 666 been released on CD?
I no longer have a record player (actually I have one, but no needle), and would like to listen to this again.
PostPosted: Mon Sep 10, 2007 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hang on- I'm mixing "See you later" up with "The Dragon" Laughing
ACHTUNG!
moosapotamus
PostPosted: Mon Sep 10, 2007 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool! Cool I would love to build one of these!
The 'original' schemo always kind of baffeled me...
Compact Phasing A scheme
A while ago I spent some time redrawing it in a form that made more sense to me...
SCP'A' Audio Signal Path
SCP'A' LFO Section
SCP'A' Power Supply
But, I never figured out what connections that DIN jack in the LFO section was supposed to make, and how to get rid of it.
So, count me in!
~ Charlie
moosapotamus.net
"I tend to like anything that I think sounds good"
PostPosted: Mon Sep 10, 2007 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you think that this connection was for foot controlled speed? Schaller's phaser used a similar configuration- that a foot control was used for the speed.
ACHTUNG!
moosapotamus
PostPosted: Mon Sep 10, 2007 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know for sure, but I think it might have been like a footswitch for 'high' and 'low' for the speed range... maybe?
~ Charlie
moosapotamus.net
jhaible
PostPosted: Mon Sep 10, 2007 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
An LDR...?
Like this one?;
The NORPS-12 is quite expensive, but it's probably a candidate.
I'd prefer smaller LDRs without plastic package, though.
JH.
jhaible
PostPosted: Mon Sep 10, 2007 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
~ Charlie
All kind of switching.
I've transformed some of tehse functions into something with a better interface on the Compact Clone - may need another redesign for new LDR types.
Manual Mode is very very nice on the CC, too.
JH.
jhaible
PostPosted: Mon Sep 10, 2007 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
This runs from +/-16V and needs a lot of current.
Therefore it _should_ be a standalone box, not a module for a synthesizer.
(Plus, if you ever played one, you want this on the desktop, not in a rack. Honestly.)
Anybody has a problem if it needs a 2 * 18V transformer?
JH.
Norman Phay
PostPosted: Mon Sep 10, 2007 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
As a dedicated Phaser Phanatic, count me in on this one, please!
PostPosted: Mon Sep 10, 2007 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm with you there Norman Very Happy Phasers? I can't get enough of them! Cool
Jurgen, personally I would prefer this to be a standalone unit anyway. I really dig the original case design too Very Happy
ACHTUNG!
germaniac
PostPosted: Mon Sep 10, 2007 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Peake wrote:
It makes the world just that much more acceptable to me.
LOL! This sentiment has been on the tip of my tongue just about all my life. Thank you for actually putting it into words!
RE: Shulte Compact A, yes please!
Regards,
Joe
germaniac
PostPosted: Mon Sep 10, 2007 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
What's your favorite shop in the USA to buy LDRs and incandescent lamps?
I've used the Silonex NSL-6112 from Allied on phasers and univibe-type circuits with great success. See here:
http://www.alliedelec.com/Search/SearchResults.asp?N=0&Ntk=Primary&Ntt=NSL-6112&sid=46E489003D5B617F
Below, that's an LED in the middle of those LDR cells.
Regards,
Joe
 Filesize:  591.49 KB
 Viewed:  142 Time(s)
PostPosted: Mon Sep 10, 2007 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
That looks nice. That's an incandescent inside?
edit; any chance of reposting this? As the actual LDR section is out of focus. (the camera seems to have focussed on the socket instead
ACHTUNG!
PostPosted: Mon Sep 10, 2007 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
PS Listening to Scott Walker right now. Fantastic production!!
ACHTUNG!
germaniac
PostPosted: Mon Sep 10, 2007 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, sorry for my lousy photographic skills. These pix were done a long while ago, and by now the little module is all packaged in shrink tube and happily phasing away in a four-stage phaser. FWIW, here are a couple more pix from that build:
 Filesize:  857.25 KB
 Viewed:  112 Time(s)
 Filesize:  648.83 KB
 Viewed:  107 Time(s)
 Filesize:  364.6 KB
 Viewed:  117 Time(s)
PostPosted: Mon Sep 10, 2007 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice Cool
But that's with an LED. I'm trying to think how we can do this with a filament bulb- which can be replaced if necessary- although apparently the chances of the bulb 'blowing' are remote.
ACHTUNG!
PostPosted: Mon Sep 10, 2007 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does the bulb thingie need cooling ?
germaniac
PostPosted: Mon Sep 10, 2007 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right, an LED. For my purpose at the time (a battery-powered stompbox) it was all about keeping current consumption low. But since that's no concern for something mains powered, I'd guess the smoother response of the incandescent bulb is preferable. Or in any case, it's more authentic to the original Schulte design, right? Smile
Joe
Peake
PostPosted: Mon Sep 10, 2007 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a clever setup.
Has anyone seen pics of the four lamps/detectors/joysticks Buchla used in the 204, IIRC? Although a wonderful idea, it was a bit messy on the board.
vtl5c3
PostPosted: Mon Sep 10, 2007 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. They're still online, right here:
http://www.synthtech.com/pix/buchla/b219/
Peake
PostPosted: Mon Sep 10, 2007 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, the 204. Grant Richter or someone had pics up of the mess on the PCB.
http://buchla.com/historical/b200/index.html
jhaible
PostPosted: Mon Sep 10, 2007 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Nice Cool
It's even easier with an incandescent lamp. Put the sensitive surface of 4 LDRs directly on the glass surface of the bulb (long wires ..). Wrap it with a sturdy black adhesive tape.
JH.
jhaible
PostPosted: Mon Sep 10, 2007 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
No. You run it at undervoltage.
JH.
PostPosted: Mon Sep 10, 2007 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just knocked this up in SolidWorks. It shows a film cannister (in blue and transparent- just to help viewing btw) with holes drilled through the sides for the LDR's to fit (also do to exact dimensions for now). Inside is a standard bulb holder and bulb. The idea is that this could be mounted on veroboard with the LDR's surrounding the bulb, through the cannister 'windows' and soldered to the veroboard. With slight modification, this could be adapted so that the bulb could be replaced if needed- ie just by opening up the film cannister. The lid of course is bolted using M2 or M3 bolts- whatever the hole diameter is on the bulb holder.
Any thoughts?
 Filesize:  50.46 KB
 Viewed:  9359 Time(s)
ACHTUNG!
AmbiphonicDSP
