loss1234
Rykhaard
Posted: Thu Nov 22, 2007 1:31 pm Post subject:
Re: PCB layouts for chaos circuits? |
loss1234 wrote: | I just made my first PCB (ray wilsons noise cornucopia) and now i am ready to start making lots of pcbs. I am hoping to find some "out there" circuits and I have a real interest in the chaos circuits or any other unique things. So if anyone has a pcb print out, please let me know.
thanks |
Major congrats on your first! Which method did you use?? What with?
I've done oddball stuff but no PCB layouts (that are transferrable. Everything I do is "poor man's surface mount". No hole drilling! Woo hoo! lol ) |
loss1234
Posted: Thu Nov 22, 2007 5:56 pm Post subject:
i used the press n peel kit from small bear. worked out great BUT drilling sucks. what is poor mans surface mount? do you mount on the same side as the copper like bernie hutchins recommends?
i have a cheap hand drill and i have already BROKEN 5 bits!!! (#60 and #65) these are the bits i bought from small bear and they are steel not carbide and they dont work too well with a hand drill. after ten holes they start getting weak and SNAP.
so now i have about 5 holes left and my drill needs to be recharged. anyone know if a dremel works better? _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
http://www.soundclick.com/lossnyc.htm http://www.indie911.com/dan-snazelle |
crashlander42
Joined: Oct 21, 2006 Posts: 292 Location: Orlando, FL (US)
Posted: Thu Nov 22, 2007 6:15 pm Post subject:
I broke a million of those bits when I first started making PCB's. I eventually got a small drill press (on sale for $40ish at Harbor Frieght when I got it. They seem to go on sale every other weekend), and that seems to do the trick. The trick to not breaking them is coming in and pulling out perfectly straight. _________________ When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr |
Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Posted: Thu Nov 22, 2007 7:14 pm Post subject:
crashlander42 wrote: | I eventually got a small drill press |
I used to do it with a big hand held drill, and eventually got quite good at it - drinking 'exactly' one beer helped
The drill has to run continuously, and you hold it up with two hands supporting it from below, then let it come down on it's weight and push it up again. That way the bit won't bend for some reason. It actually worked better than a dremel thingy. _________________ Jan
loss1234
slo
Joined: Feb 18, 2007 Posts: 204 Location: Victoria, BC
Posted: Thu Nov 22, 2007 8:43 pm Post subject:
Quote: | and is it ok to put the dissolver material back in the bottle to use again? |
If it's ferric chloride, then the answer is yes. I reuse mine a lot, which brings up the question of how to know when it's done. If it's not ferric cholride then sorry, I don't know about reuseability.
George |
crashlander42
Posted: Thu Nov 22, 2007 9:25 pm Post subject:
Blue Hell wrote: |
The drill has to run continuously, and you hold it up with two hands supporting it from below, then let it come down on it's weight and push it up again. That way the bit won't bend for some reason. It actually worked better than a dremel thingy. |
I used to do exactly that before I got the drill press. Beer works but coffee's a bad idea. _________________ When they plug me in the lights go down in Hong Kong.
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Fri Nov 23, 2007 12:28 am Post subject:
Quote: | which brings up the question of how to know when it's done. |
I usually replace it when etching starts taking noticably longer. It also changes colour as it gets saturated with copper.
Quote: | I used to do exactly that before I got the drill press. |
I couldn't work without a drill press anymore... _________________ http://www.casia.org/modular/ |
Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Fri Nov 23, 2007 3:08 am Post subject:
how do people dispose of their ferric chloride? I need to solidify my etchant as I work in a over 100 year old building and the pipes would probably dissolve. I tried putting plaster in it once, because I had a kit once with plaster like neutraliser in it - amazing reaction but not the same as the neutraliser just went foamy and sandy! I read that sodium carbonate ( baking powder ) neutralises it. I hate ferric chloride, going to move to the transparent stuff when I use mine up.
this isnt a chaos circuit, but it creates interesting patterns
http://electro-music.com/forum/topic-18191.html _________________ Clacktronics.co.uk |
toppobrillo
Joined: Dec 10, 2005 Posts: 766 Location: oakland, ca
Posted: Fri Nov 23, 2007 3:25 am Post subject:
i have to whole-heartedly recommend the hydrogen peroxide/muriatic acid solution over FeCl- it is less expensive (and fast! and clear!) than both that and the other stuff(ammonium persulfate?) it is a bit more caustic though. gloves, handling utensils and ventilation required! also, always acid into water when mixing (slowly!). never the other way around. i just remember it alphebetically.
josh |
bubblechamber
etaoin
Posted: Sun Nov 25, 2007 11:30 pm Post subject:
Mr Clack wrote: | how do people dispose of their ferric chloride? |
Chemical waste depot of the local council. They come and collect hazardous waste twice a year for free. _________________ http://www.casia.org/modular/ |
hodad
Posted: Mon Nov 26, 2007 6:36 pm Post subject:
re drilling: There's a drill press accessory that goes with the Dremel tools that's fairly cheap. Makes for great PCB drilling. Takes up a lot less space than a real drill press, & if you already have a Dremel, it's definitely cheaper. |
crashlander42
Posted: Mon Nov 26, 2007 9:52 pm Post subject:
Etaoin wrote: | Mr Clack wrote: | how do people dispose of their ferric chloride? |
Chemical waste depot of the local council. They come and collect hazardous waste twice a year for free. |
On the back of my ferric chloride it says "Discard used solution into toilet bowl and flush". This doesn't seem like the best idea too me, but who am I to argue with the bottle? I do know the water treatment plants use it (to remove phosphorus i think) in their treatment process.
My used ferric chloride is actually sitting in a milk bottle in my garage. Right next to my used motor oil I haven't disposed of. _________________ When they plug me in the lights go down in Hong Kong.
