Styroflex (polyestireno) VS Silver Mica Caps for Yusynth VCO
Page 1 of 2 [41 Posts]
Sebo
PostPosted: Tue Nov 13, 2007 7:07 am    Post subject: Styroflex (polyestireno) VS Silver Mica Caps for Yusynth VCO
Subject description: Temperature Coefficient Differences
Hi:
I'm collecting parte to build some Yusynth VCOs. Yves told me that I
should use Styroflex or Silver Mica Caps with a Temp Coeff less than 70 ppm/C.
I have the choice to buy Styroflex 1% with a Temp coeff ±:+110ppm/°C, -50ppm/°C,
and Silver Mica 1% with a Temp coeff ±:+70ppm/°C, -0ppm/°C.
Silver mica are a little more expensive, but seems to be better, but
most of the time I ses VCO designs that uses Styroflex (Polyestirene) caps.
What is better?
Thanks.
Sebo
My Music:
yusynth
PostPosted: Tue Nov 13, 2007 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Sebo
Styroflex 1% are OK, no problem, in my case I chose Silver Mica 1% because it was easier for me to source them.
Yves
Sebo
PostPosted: Tue Nov 13, 2007 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Yves:
Thanks a lot for the help.
I'm going to build 4 VCOs, but I'm going slowly (little time/small budget).
Sebo
My Music:
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Jul 21, 2008 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Where in europ I can find styroflex caps?
yusynth
PostPosted: Mon Jul 21, 2008 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
In France www.selectronic.fr has styroflex caps.
Otherwise silver mica are good alternatives :
http://www.musikding.de/forums.html/cat/c95_Silver-Mica.html
Yves
Sebo
PostPosted: Mon Jul 21, 2008 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I bought mine at Farnell.
Sebo
My Music:
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Jul 21, 2008 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
thnx guys.
So in place of styroflex I can use silver mica any time?
I'm looking at Buchla 281 and TH VCO 1 for next builds..looking for parts Smile
scriptstyle
PostPosted: Mon Jul 21, 2008 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
i just ordered some Polyestirene caps from futrlec.com for my vco-1 project i think they ship from thailand but i honestly dont remeber.
etaoin
PostPosted: Mon Jul 21, 2008 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
www.banzaieffects.com
http://www.casia.org/modular/
etaoin
PostPosted: Mon Jul 21, 2008 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, they ship from Bangkok.
But where on their site did you actually find polystyrene caps? They only list polyester.
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Jul 21, 2008 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thnx I know banzai. But they have no values I need (47n) for CGS Utility LFO. Or I can use silver mica for those? Yeah?
crashlander42
PostPosted: Mon Jul 21, 2008 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used polystyrene caps in my Yusynth VCO and my VCO-1 and they are extremely stable. In fact my Yusynth VCO and VCO-1 are the most stable all the VCOs I've built so far.
I ordered mine from Mouser. I noticed that in the two pages of polystyrene caps they had in stock that none of them were ROHS. That may be part of the problem with obtaining them in Europe.
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
etaoin
PostPosted: Mon Jul 21, 2008 10:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
As far as I know polystyrene (styroflex) doesn't come larger than 10nF.
You can use almost anything in an LFO, especially when using large values. Are you going to tell the difference between a 1 second and 1.01 second cycle?
etaoin
PostPosted: Mon Jul 21, 2008 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
That might also be because few are still in active production, most will probably be old stock.
The LRC boxed type polystyrene seem to be reasonably common. But there is still plenty of old Siemens styroflex about.
a.b.o.z.
G2 patch files: 4
PostPosted: Tue Jul 22, 2008 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I suppose not :-/
But on Ken's pages I've seend picture of utility LFO and those caps looks like styroflex to me. Oh well. Thnx anyway.
Ivan
scriptstyle
PostPosted: Tue Jul 22, 2008 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
ooo shoot! i could have sworn they where polystirene Confused
frijitz
Audio files: 54
PostPosted: Tue Jul 22, 2008 9:07 am    Post subject: Re: Styroflex (polyestireno) VS Silver Mica Caps for Yusynth
What is better?
Mica is not the best material for VCO caps because of its relative large soakage effect.
http://www.national.com/rap/Application/0,1570,28,00.html
Ian
Sebo
PostPosted: Tue Jul 22, 2008 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian !!!
Sebo
My Music:
scriptstyle
PostPosted: Tue Jul 22, 2008 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow finding .001 polystyrene caps is turning into a nightmare. Mouser has them in there catlog so i put a couple of things together to get and that wasn't the only thing they didnt have. Does anyone know of a place that ships to the US?
Rykhaard
PostPosted: Tue Jul 22, 2008 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll check my stock of Poly caps tomorrow (later today, after I wake up) as I recently took in a whole pile of write-off stuff from work, including a few thousand poly caps of various values. (150nF; 2.2nF; 15nF and possibly a couple of others).
I'll see if I can find out what poly types they are. If they're polystyrene 1nF's, I can mail you down a few for nothin'. Smile
crashlander42
PostPosted: Tue Jul 22, 2008 9:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
They have them at my local surplus shop as well for if you end up unable to find them elsewhere.
My DIY stuff Flickr
etaoin
PostPosted: Tue Jul 22, 2008 11:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got 25 from West Florida Components on eBay at one point. They don't seem to have any listed currently, but might still have some. They ship for almost nothing to EU, so probably even cheaper inside the US.
scriptstyle
PostPosted: Wed Jul 23, 2008 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
your a life saver im going to keep my fingers crossed in hope..
Rykhaard
PostPosted: Wed Jul 23, 2008 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Doh! Shocked All of my poly caps that I have many many of, are MMK types - Metalized Polyester Film.
Now - I don't know how the different poly types stack up compared to each other. Sad I used to have a link to a capacitor site explaining them all but that was before my hard drive crash. Sad Anyone??
_IF_ this type would be ok, I have only about 5-10 of the 1nF's that I could spare. 1.5nF - I have just over 2000, still on tape reel. Smile
etaoin
PostPosted: Wed Jul 23, 2008 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Polypropylene would be an alternative, but polyester usually isn't.
