 Forum index » Clavia Nord Modular » G2 Patches - Completed » Drum
NM conversion: ChemicalBeats.pch
Page 1 of 1 [2 Posts]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Sep 13, 2004 12:39 am    Post subject: NM conversion: ChemicalBeats.pch Reply with quote  Mark this post and the followings unread
This is a G2 conversion of the chemicalbeats NM patch by DigiSoundCab found at: http://pch.zevv.nl/dl.php?patch=8296feaa5760be165d0443f7184d038f
I converted this with help from sebber's module reference page (http://www.sebastianberweck.de/G2/MRTprint.htm)
I was originally hoping it was a decent version of the acid lead from the song 'Chemical Beats', but it's some filtered noise drums triggered by some pattern generators. Still kindof cool though. Variation 1 is the original parameters. Variations 2-4 are my own attempts to get this sounding a bit more interesting whilst staying within the confines of the original setup.
There are a few interesting things going on in the structure of this one though. First up the LFO's going through the glide modules to obtain a more rounded control signal for the filters. Also, to give the Percussion osc's a distorted feel, noise modulates the pitch input. Changing the colour of the noise varies the timbre of the drums nicely.
Chemical Beats.pch2
Conversion of the NM1 patch ChemicalBeats.pch
 Filename:  Chemical Beats.pch2
 Filesize:  2.65 KB
 Downloaded:  2269 Time(s)
modular
G2 patch files: 72
PostPosted: Mon Sep 13, 2004 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice Work Afrokid thumleft
I've added A Reverb triggered by the SeqEvent module.The gate of Reverb is controlled by the ControlSend module triggered with the second bar in the SeqEvent.
I think this is an interesting way to automate and control effects in a sequence linked in time with the Master Tempo. Usually LFO do it but with indipendent LFO's Wave time.
Chemical Beats R.pch2
The same Afrokid patch with added Triggered Reverb
 Filename:  Chemical Beats R.pch2
 Filesize:  3 KB
 Downloaded:  1955 Time(s)
