  Twyndyllyngs Live - back after 3 weeks Chez Mosc
Q960 clone light
Page 1 of 1 [20 Posts]
Pehr
PostPosted: Mon Mar 03, 2008 9:36 am    Post subject: Q960 clone light
Subject description: ideas
Of what I have seen, the Q960 Sequential Controller seems really awesome.
What I really like about it is the skip step function.
So, why do I not buy one? Well, despite the low $ currency, it is too expensive for a poor meteorologist like me... Crying or Very sad
I've been wondering how it would be possible to make a sort of 'clone' of it, or perhaps better words for it is a light version. Very Happy
What I'm after is:
* 8 or 16 steps with pitch setting for each step.
* Gate on/off for each step
* skip step for each step
I have not made any schematics or block-schematics yet, but I have some ideas.
If one use a CD4029 counter as a core and let it drive a CD4067 for the steps (up to 16 if you like). Wouldn't it be possible to check the skip switch at each step, and if it is set to skip, the CD4029 is jammed to the next step (with the jam inputs) that is not set to skip? (oh, what a nice sentence Rolling Eyes )
If I'm not totally wrong here it could easily be done with logic chips to check the skip function.
Any ideas?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Pehr
PostPosted: Mon Mar 03, 2008 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or is it even more simple?
How about a 8-step 4013-shift register where the skip switch just shorts the active step to the next?
EDIT: Like the MFOS 8 Channel Expandable Analog Sequencer, where the Q output of one step either goes to the next stage or the next after that. I think I'll go for that sollution, thanks everybody! Rolling Eyes Laughing
YouTube channel
flickr photostream
Danno Gee Ray
PostPosted: Mon Mar 03, 2008 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funny to say this but...Absolutely glad to have done nothing at all to help you and or make you happy....er, uh, You're welcome! Wink
neandrewthal
PostPosted: Mon Mar 03, 2008 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey! Quit hogging all the glory. I did nothing too!
Pehr
PostPosted: Tue Mar 04, 2008 12:15 am    Post subject: Reply with quote  Mark this post and the followings unread
YouTube channel
flickr photostream
neandrewthal
PostPosted: Thu Dec 18, 2008 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I finally have something to add, but I don't know how valuable it is Wink
Ever since this thread popped up I've been drooling over the skip function and wishing I could add it to the MFOS seq in the backlog that's waiting to be built. I've come up with one way, and would appreciate some feedback on whether it sounds feasible or not.
Ok, so here's the plan. It involves changing the gate switches to on-off-on and adding a daughterboard. Would It work if I wired it up so that flipping the switch for a particular stage one direction causes the clock pulse that activates that stage to be doubled by a second one, in such quick succession that you never even notice that the stage you want to skip was ever active? Flipping it the other direction would send the gate from that stage to the gate buss as normal.
Rykhaard
PostPosted: Thu Dec 18, 2008 10:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Pehr. Did you work out the solution to the Skip function with Ray's CD4013 setup? I think I might have worked out the logic of the Skip using the FF's tonight at work. I then though remembered that the Moog Q960 used FF's for each step and had the Skip; Rest; Play (or something) switch steps. I'll have to find my Moog modular blueprints and see if there was a 960 in my former bud's machine. Smile
I don't NEED the Skip function in my sequencers now as the function can be taken care of, but - I'd like to have it as WELL. Wondering if you've worked out the solution and if so - what it be. Smile
neandrewthal
PostPosted: Fri Dec 19, 2008 12:58 am    Post subject: Reply with quote  Mark this post and the followings unread
How do you take care of skip enternally? I NEED skip Very Happy
Funky40
G2 patch files: 5
PostPosted: Fri Dec 19, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
my dreammachine is something like the Q960 with 20 steps !
Then you can have 4 steps skipped to get a 16step Sequenze Cool
REALLY cool i mean !
it would be sooooooo great to have a Q980 Wink ------------> 20stepper
The q960 uses ( waht i can read ):
74HC32 (3x) ( QUAD 2-INPUT OR GATE - ETC)
http://www.alldatasheet.com/datasheet-pdf/pdf/147760/ETC/74HC32.html
74HC74 (5x) (Dual D-type flip-flop with set and reset; positive-edge trigger )
http://category.alldatasheet.com/index.jsp?semiconductor=D-type
74HCT14 ( 4x ) ( Hex inverting schmitt trigger )
http://www.alldatasheet.com/view.jsp?sSearchword=74HCT14
this is a flip flop construction as the MFOs expandable 8stepper is, isn't it ?
btw.: the Q960 has skip/normal/stop/reset(as option) + inputjack and outputjack per step.
the main features for me are skip and reset inputs per step
On a 20 stpe ( or so) engine the reset inputs might be from less importance. I don't know.
Rykhaard
PostPosted: Fri Dec 19, 2008 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
My Quadatrix sequencers are driven by Bit input. 2 bits for the 4 step horizontal sequencers and 3 bits for the 8 step vertical sequencers. Using that stepping method, any step points in the sequencers can be played, whenever, depending on the bit input data. Smile
(Any combination of horizontal and vertical sequencers can be chained together in serial format as well, for as long as forward and/or reverse playback choice, as desired.
Of course, I only HAVE 4 x horizontal 4 step sequencers at the moment, for 16 different steps, but ...... Wink As soon as I build more of them, I'll have more steps, ability. Very Happy )
The Q960 Skip function though, I really like it in IT's function. It'd be nice to have it, as well.
Studying Ray Wilson's expandable 8 step sequencer yesterday at lunch, it looks like it would be only a matter of hooking up the Q to D chains by switch, to determine whether the next step is 1, or 2 steps after Q.
neandrewthal
PostPosted: Fri Dec 19, 2008 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="Rykhaard"]
Now I want those too Twisted Evil What do you use to drive them? I'm interested in learning about bit pattern generators to use in an upcoming 2 bit sequencer I'm designing. So far I've just got a 4516 which counts from 1-4, and reverse, but I'd love some wacky patterns as well Very Happy
Rykhaard
PostPosted: Fri Dec 19, 2008 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm currently driving them with 2 of Ken Stone's original Master Divider (both extended from 6 bit divisions to 7 bit divisions) as well as 2 of his new Master Divider.
I have 1 of 2 planned, 1 input / 2 output VC'd switches built and still have to build the 2 input / 1 output VC switch. Those will both give much more mangling ability for which bits are going to where.
I can't rem'ber at the mo' whether I have the schematics for the sequencers up on my web page. If I don't, I'll get them and the PCB layouts uploaded to my Blog (which I'm now using, until I can remember the password, for allowing me to edit my web page again. Surprised )
As far as the Triggers / Gates, I'm currently using 3 of Ray Wilson's MFOS Sequencer, for driving them. (1 of which will soon be modded for an additional 64 steps, configurable through a Vertical sequencer in any combination of sets of 16 steps.)
neandrewthal
PostPosted: Fri Dec 19, 2008 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, neat! So, to create for example, a linear 8 step sequence, you just patch the divide by 2, 4, and 8 to the 3 bit inputs. Then you could do it again with the 90 degree out of phase outputs, and mess around with what goes where using VC switches. That sounds exciting! Why aren't all sequencer made like that?
You know what else would go great with your setup? Instead of just 2-1 and 1-2 switches, some 2-2 switches Cool
Rykhaard
PostPosted: Fri Dec 19, 2008 10:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Exactly! Smile In 1 of my videos (IIRC), I have the 4 x 4 step horizontal sequencers chained together (passing the 2 bits THRU to the next 4 step; passing again THRU the next; etc.).
The outputs of them are cycled through, with the 3 bit vertical sequencer, to give me 16 steps.
Now - if the bit order is changed, with the 16 steps, you can get a far longer non-repeating pattern. Smile
(And each step in the 4 step horizontals, use 12 position switches for 1V/oct. tuning. Same thing with the Octave version of the 4 step. The final version will have either 4 or 6 position rotaries. The 1 finished 4 step Octave, currently has 3 position rotaries.)
2 x 2 switch! YES! Definitely! Complete redirection of the 2 bits!
Once I have the 2nd 1 input / 2 output switch done, I'll be able to do that. Smile
When I come to building the next set of Quadatrix sequencers, I'll more than likely include a few more switches, for redirecting the bits. Smile
There'll be more video examples in the future. My main projects right now though are getting the Liquid HiHat testing finished for production and I'm working on the design for a completely new 'drum voice' as well. Keeping quiet about it though, until it's at least up to testing abilities. Wink
And soon of course, the 64 step expansion.
neandrewthal
PostPosted: Fri Dec 19, 2008 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just went back and watched the quadatrix videos again(now that I understand it) and I see one of these in my future now. I MUST have one, but I still gotta build the MFOS, Klee, RYK 185 and CGS programmer. I'll squeeze it in somewhere Laughing I'm extremely impressed at the patterns you can do with just 4 notes. If you wanted to do the same thing on a regular sequencer, it would take 16 steps or more and a lot more fiddling, and even once you've got it down, you wouldn't be able to switch it up so easily. I'm convinced this is the true path to sequencer nirvana salut
Rykhaard
PostPosted: Sat Dec 20, 2008 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Hahaha. It is SO cool to see your enthusiam!! Very Happy
Now try to imagine my side of desire, for, this type of sequencer - since 1982 (almost continuous) when I first heard Tangerine Dream! Shocked If I am not mistaken - I finally HAVE the beginnings of a sequencer, that work in many of the ways that TD used their sequencers. Except - my design is 1V/octave.
I have been so busy with building since the middle of June, I've had barely any time to actually play with my sequencers. Sad The power of the Quadatrix though, allows you to play any step, whenever you want, triggering it as many times as you want. It's all due to the the Bit input values. Forward, backward, diagonally, changing octaves - and THEN you can easily change the actual note on each step by just turning the rotary switch to select 1 of the 12 notes in the octave, or change the octave of a step's note by switching the related octave rotary switch. Smile
One thing that they ARE missing though is PORTAMENTO! Sad I never even thought of it when I was designing the sequencer and building them. The next versions will be including at least 1 linear portamento, for sure. Surprised
Now - scratch WHAT is a RYK 185?? Smile ??
neandrewthal
PostPosted: Sat Dec 20, 2008 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.electro-music.com/forum/topic-27157.html
I'm excited about this one too bounce
Rykhaard
PostPosted: Sat Dec 20, 2008 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aye! THAT is one of the coolest new sequencers that I've seen in a LONG time. Most impressive (to me) since I saw the MIDIbox SEQ sequencers a couple of years ago. (Though, that end were originally leaning more towards MIDI. I still haven't completed my V2.00 unit and wont be, sadly. I'm FAR more modular than MIDI based, in my desires.)
Pehr
PostPosted: Wed Dec 24, 2008 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I haven't built it yet, but I think it is possible with some PCB trace cutting and on-off-on switches.
off for stop (since the chain is broken), up and down for next step and skip step. Cool
However, it would be nice with gateable skip/stop/next Rolling Eyes
YouTube channel
flickr photostream
Rykhaard
PostPosted: Wed Dec 24, 2008 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Mmmm. My not yet brain just thought of:
Q to Window Comparator; High = next step; between = stop; Low = step after next step. Manual switch for the same. ?? (If that function would work. Would have to be tested manually, first.) Smile
