Minimum / Maximum level recordor
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Fri Jan 16, 2009 6:54 pm    Post subject: Minimum / Maximum level recordor
Subject description: A simple min / max tracker patch
I hacked this together to see what some levels were coming out of an LFO I was shaping, etc. It may have been done before, but if so, I missed it searching on the forum.
Instructions are in the patch. The tracker itself is in the FX area so you can copy it into other patches you are building (MIDI CC values of your patch permitting.) There is also a small sequencer set up in the instrument area in as a demo of how it works.
Go to page A1 to see the controls. You will have to turn it on with the first knob there, then turn on the sequencer in the patch with the editor on the computer.
The tracker will reset if you disable "MainInput". There are also individual resets for min or max so you can reset them on the fly.
MaxMinTracker.pch2
 Filename:  MaxMinTracker.pch2
 Filesize:  3.14 KB
 Downloaded:  1840 Time(s)
