| Author | Message |
| fredw
|  Posted: Thu Jan 29, 2009 9:46 pm    Post subject:
Frequency Shifter Subject description: Frequency Shifter - cables and connectors
| I'm almost finished stuffing the FS-1A.  I have the 2-pin, 3-pin, and 5-pin connectors.  How do I make cables to connect to them?  Do I have to buy a special crimping tool?  (Probably expensive?  And which one?) or can I solder something together?  I don't quite know how to start in this area.
 Thanks much,
 Fred
 Berkeley, CA.
| Back to top |  |
| Luka
| Back to top |  |
| Funky40
 G2 patch files: 5
|  Posted: Fri Jan 30, 2009 3:13 am    Post subject:
Re: Frequency Shifter Subject description: Frequency Shifter - cables and connectors
|  	  | fredw wrote: |  	  | I'm almost finished stuffing the FS-1A.  I have the 2-pin, 3-pin, and 5-pin connectors.  How do I make cables to connect to them?  . |
 hmm, the connectors mentioned on Jürgens Boms are coming with the counterpart = socket with allready connected cables.
 if you got partkits from Tobias, you should have those
 ( i assume the FS1A have the same connectors as all JH boards )
 you can see them here,( and order too. paypal, good/human shipping conditions )
 http://www.banzaieffects.com/PCB-Connectors-c-1076.html
 ............................................ OT
 Ha 555 , lucky post.
 I wish a new module:
 the interpolating distributor.
   ( i will post in a own thread later )
| Back to top |  |
| jhaible
|  Posted: Fri Jan 30, 2009 10:29 am    Post subject:
|  	  | Funky40 wrote: |  	  |  	  | fredw wrote: |  	  | I'm almost finished stuffing the FS-1A.  I have the 2-pin, 3-pin, and 5-pin connectors.  How do I make cables to connect to them?  . |
 The connectors I have in my BOMs do not have cables attached. (But tehre are very similar connectors that come with cables - true.)
 I simply solder the wires to the contacts, and then insert the contacts in to plastic part of the connector.
 JH.
| Back to top |  |
